Because I’m sticking to a limited gadget budget this year, I don’t want to replace something that still works just because a new model is available. My current earbuds charge normally, but the case has picked up lint from my jeans pocket and the left bud sometimes needs reseating before it connects.
Are the AirPods 5 enough of an upgrade to justify replacing working earbuds, or would I mostly be paying to fix minor annoyances I can already live with?
A charging case with dirty contacts is very different from earbuds with worn-out batteries or frequent audio dropouts. Lint plus a bud that occasionally needs reseating sounds more like a maintenance problem than a reason to replace the whole set.
Clean the case and charging contacts carefully with a dry, soft brush or cotton swab, then reset and pair the earbuds again. If the left bud still holds a normal charge and connects reliably afterward, I’d keep them. A protective case with a port cover could prevent more pocket debris for much less money.
The new model brings better noise cancellation, sound, durability, and some control improvements, but those upgrades matter most if you actively want those features. On a limited gadget budget, replacing otherwise functional earbuds would mostly be paying for convenience. I’d wait until battery life becomes annoying, the connection problem survives cleaning, or repair costs stop making sense.
No, an occasional charging hiccup does not make the whole set ready for replacement. If the case contacts turn out to be damaged rather than dirty, check whether you can replace just the charging case. That keeps the working earbuds in service and avoids paying for another pair.
I’d judge the upgrade by what your current earbuds prevent you from doing. Short battery life that cannot cover your normal use, unreliable calls, or constant connection failures would justify spending. Pocket lint and a quick reseat are annoyances, but on a limited budget they are cheap annoyances. Put the upgrade money aside until the current pair becomes genuinely inconvenient.
Clean the case with a dry, soft brush, then track whether the charging hiccup returns. If it stays reliable, keep your money until a newer pair offers a feature you genuinely need.
A newer pair can win on the spec sheet and still be worse for you if the fit, controls, or sound tuning suit you less. That risk gets ignored when the comparison is “old versus new” instead of “my actual earbuds versus what I would gain.”
I’d compare them around a normal week. Do your current earbuds last through the longest session you regularly have? Are calls clear enough? Do they stay connected once they are out of the case? If the answer is yes, improved noise cancellation or durability may be pleasant, but you would be spending limited gadget money to solve problems you do not currently have.
The charging issue is worth separating from the rest. A bud that occasionally fails to make contact in a linty case is irritating, but it does not say much about speaker quality, battery health, or wireless reliability. Clean it and watch what happens over several charging cycles. If the failure starts happening repeatedly even with clean contacts, then compare the cost of a replacement case with the cost of a full upgrade. I would not buy another case blindly if the earbuds themselves are already showing noticeably reduced runtime.
@grace has the right general standard: judge the purchase by what the old pair stops you from doing. I’d make that standard fairly strict with a limited budget. “The new ones are better” is true of nearly every gadget update. “The old ones interrupt my day” is a much stronger reason to spend.
Unless the AirPods 5 provide a specific feature you have been waiting for, your working pair is still the better value. Set the money aside, keep using them, and let a real limitation make the decision rather than the release cycle.
If your current set is still under warranty or covered by an extended plan, replacing it would be backwards. Report the intermittent charging issue first. A faulty case or contact may qualify for service, and paying for a new generation before checking coverage wastes the protection you already bought.
“Working” is not completely binary, though. A bud that fails to charge once every few months is background irritation. A bud that regularly leaves the case empty right before work, travel, or a call is no longer dependable, even if the speakers and batteries are technically alive. Reliability can justify replacement sooner than sound quality does.
Before spending, run a boring test. Charge both buds fully, use them together for a normal session, and compare their remaining battery levels. Then leave them in the case overnight and confirm that both actually charged. Repeat that a few times. Large battery differences point toward an aging bud. Random overnight failures point more toward the case or contact. Those are different purchases, despite producing the same annoying result.
I would not upgrade for improved specs alone on a restricted budget. New earbuds will still collect pocket debris, their batteries will still age, and there is always a chance you prefer the old fit. Spend when the current pair becomes unreliable for your actual routine, not when its replacement wins a comparison chart. Until then, it is a lint problem with expensive marketing standing nearby.
Don’t scrape the charging wells with a pin or use a wet swab. That can damage the contacts and turn a minor debris problem into a failed case. Use a flashlight, a clean dry brush, and a dry lint-free cloth on the metal end of each earbud.
Then troubleshoot the charging path instead of judging the earbuds by their age. Fully charge the case, insert the troublesome bud, and check whether charging begins immediately. Repeat that several times without pushing or twisting it. If it only registers when held at a certain angle, the contact or spring mechanism may be worn. If it charges normally after cleaning, pocket debris was probably the entire issue.
I’d also leave the case out of your pocket for several days. A clean desk or small pouch makes a useful test environment. If the problem disappears, buy a cheap protective cover that blocks the opening. If it continues, price a replacement case or service before replacing everything.
A new generation may offer features you would enjoy, but it won’t fix a spending decision you already suspect is unnecessary. With working batteries and acceptable sound, the case diagnosis should decide your next move, not the release announcement.
Don’t sell yourself on the upgrade by counting features. Count the calendar. Earbud batteries wear out no matter what, and once they do you can’t swap them, so buying a new pair now just starts that two-or-three-year clock early while your current one is still fine. That’s the piece I think everyone here is circling around but not saying outright.
@lucid_bit’s battery-comparison test is the one bit of advice worth actually doing, because it tells you whether you’re looking at a dying bud or just a grimy case. If it’s the case, you already know the move. If it’s real battery drop, then sure, start thinking about replacement, but even then a lint-clogged case isn’t the signal. Upgrade when the runtime stops covering your day, not when the announcement drops.
Before you blame the case or the bud, check what version the earbuds are actually running. Firmware glitches can throw false charging errors, show a bud as not seating when it is, or misreport battery percentage. I’ve seen this dismissed as hardware more than once when a forced update quietly fixed it. That’s the one diagnostic step missing from this whole thread, and it costs nothing.
On the actual question, I lean the same way most people here do, but for a reason nobody’s said plainly: the money you’d spend now buys you almost none of the noise cancellation or sound improvements in a form you’ll notice during normal use. Those gains show up in a quiet A/B test, not on a bus or at a desk. So unless you specifically listen in situations where cancellation matters, you’re paying for a spec you can’t hear.
Where I’d push back slightly on @hyperpilot3378: the ‘you can’t swap batteries so you start the clock early’ line is true, but it cuts both ways. Working earbuds lose resale value fast too. If you’re genuinely on a tight budget and you already suspect you’ll upgrade within a year anyway, selling a clean working pair sooner gets you more back than selling a tired one later. That doesn’t mean buy now. It means don’t sit on gear you’ve mentally already replaced. For your case, though, you clearly haven’t, so clean it, update it, and keep using it until it fails your day rather than the marketing.
Don’t turn a little pocket lint into a full-price gadget emergency. Set a replacement rule now, such as charging failures disrupting your routine or battery life no longer covering normal use, and ignore the shiny-new-object tax until that happens.
