Grubby AI Humanizer Review
I’m considering using Grubby AI Humanizer to make my AI-written content sound more natural and less detectable, but I’m not sure if it’s actually effective or just marketing hype. Has anyone here tested it for SEO, plagiarism checks, or AI detectors, and did it hurt or help your rankings and readability? I’d really appreciate honest reviews, pros and cons, and any examples of where it worked or failed so I don’t risk my site or content quality.
Grubby AI Humanizer
I spent some time playing with Grubby AI because it claims to have special modes tuned for specific detectors: GPTZero, ZeroGPT, and Turnitin.
Their link with the details and “proof” is here:
Here is what happened when I tried to use it for detector evasion, which seems to be the whole point of the tool.
Detector modes and real tests
They have a “GPTZero Mode” you pick before pasting text. On paper, that sounds nice. In my tests, the output behaved like this with GPTZero:
• Sample 1: 0 percent AI flagged. Passed clean.
• Sample 2: 17 percent AI flagged. Not ideal, but not catastrophic.
• Sample 3: 100 percent AI flagged as AI by GPTZero, using the very mode that is supposed to target it.
So the results jumped all over the place. Same site, same mode, similar length inputs, different detection outcomes. I used straightforward academic style content, nothing crazy.
The weird part was Grubby’s own “Detection” tab. It shows results from multiple detectors and, on my side, every single output came back as “Human 100 percent” on all seven detectors it shows.
When I cross checked with external GPTZero, at least one sample was nailed at 100 percent AI. So their internal detection panel felt more like a cosmetic widget than a real check.
Text quality and quirks
I scored the “humanized” text around 6.5 out of 10 for general writing quality, based on readability and how much manual cleanup I ended up doing.
Stuff it handled decently:
• It strips em dashes entirely. For some people this is a negative, for me it helped since a lot of detectors seem to associate certain punctuation patterns with LLM output. Most humanizers ignore this.
• No fake words, no random gibberish, no broken grammar. So it did not trash the text.
Stuff that bugged me:
• It tends to inflate sentences. The wording drifts into stiff and formal, like something from a student trying too hard to sound “academic”. That style alone can already look suspicious to a professor.
• I spotted awkward substitutions. Example: it used “distinction” where “nuance” obviously fit better. Little things like that force you to re-edit parts of the paragraph if you care about tone.
So you get grammatically sound text, but you will likely need to trim and simplify if you want it to sound like a normal person.
Editor and workflow
One thing I did appreciate is how the editor behaves.
Inside the app:
• You click on a single word and it opens quick synonym options.
• You can rehumanize single sentences or a whole paragraph without leaving the page.
• It feels closer to an inline editor than a “paste here, download, go somewhere else to edit” loop.
For quick tweaking, that saved time. If you are cleaning up phrasing or fixing word choices, the click-to-swap flow is faster than copy pasting between sites.
Pricing
Limits and prices when I used it:
• Free tier: total of 300 words. Not 300 per day, 300 overall. You burn through that in a couple of tests.
• Essential plan: 9.99 dollars monthly, billed annually, only gives access to “Simple” mode. No detector specific modes.
• Pro plan: 14.99 dollars monthly, billed annually, unlocks all modes, including the GPTZero, ZeroGPT, and Turnitin options.
So if you want the detector modes that are advertised everywhere, you end up in the Pro plan.
Comparison with Clever AI Humanizer
Same session, I ran similar samples through Clever AI Humanizer, using their free access.
After multiple runs:
• Clever’s outputs looked more natural with fewer weird word choices.
• Detection results on external tools were more consistent, not perfect, but less erratic than Grubby’s.
• It did not charge anything at the point I tested, which made experiments less stressful.
Grubby AI is not unusable. It produces readable text and the inline editor is handy. For me, the main weak spots were the inconsistent detector results and the formal, slightly off tone.
If your goal is mainly to improve flow or rephrase, the paid plans feel expensive for what you get. If you care about detection rates, I saw stronger and more reliable outcomes using Clever AI Humanizer, with no subscription on top.
I tested Grubby AI on a few real use cases for clients, focused on three things: SEO, plagiarism, and detector evasion.
Short version: it works “ok”, but it is not reliable if your main goal is hiding AI use.
My notes, trying not to repeat what @mikeappsreviewer already covered:
  1. SEO impact
    I ran 10 articles through Grubby AI, then published half “as is” and half with manual edits.
– Rankings and indexing in Google were the same as normal AI content.
– No special gain in CTR or dwell time from the “humanized” versions.
– The tone felt more stiff, so for blog posts I had to simplify sentences a lot.
If your SEO plan depends on it, you are aiming at the wrong problem. Google cares more about usefulness and engagement than detector scores.
  1. Plagiarism checks
    I pushed original AI text through Grubby, then checked with Turnitin and Copyscape.
– Turnitin similarity scores dropped a little when the base text was close to training data.
– Copyscape rarely flagged anything new.
– It did not “clean” obvious near copies of existing web content. You still need to rewrite those by hand.
You should still run your own plagiarism scan. Grubby does not handle that for you.
  1. AI detector evasion
    My results were closer to what Mike described, but I saw slightly better averages.
Using their GPTZero mode on 8 samples:
– 3 passed GPTZero with low AI score.
– 3 landed in a gray zone, partial AI flagged.
– 2 hit high AI scores.
ZeroGPT and some random “AI checker” sites were all over the place. Some said 100 percent human, others yelled AI for the same paragraph.
The internal “all green” detector board in Grubby did not match external tools for me either. I would not rely on it.
  1. Text quality in real workflows
    Things that annoyed me:
– Sentence inflation. It loves long, formal constructions.
– Subtle word misuse. Example: using “comprise of” where “consist of” fits. Not wrong enough to fail grammar, but weird to human readers.
– You still need to line edit if you want natural voice.
That said, I liked the inline editing and word replacement. It speeds up light cleanup.
  1. Pricing vs value
    For detector focused modes, you get pushed to the Pro plan. If you write at scale, that adds up fast, and you still do not get consistent evasion.
If you want something similar for testing, Clever Ai Humanizer gave me more natural sounding text, and detector scores were more stable for long form content. For SEO content where I care about user engagement first, Clever Ai Humanizer plus manual editing felt more efficient.
Practical advice if you are on the fence:
– Do not trust any “100 percent human” badge in a tool. Always cross check with at least two external detectors if this is critical for you.
– Use Grubby or Clever Ai Humanizer as a starting point, then rewrite intros, conclusions, and transition sentences by hand.
– For school or academic work, no humanizer is safe. The inconsistency in detectors and style shifts will put you at risk.
– For affiliate or blog SEO, focus on adding your own examples, screenshots, and unique opinions. That matters more for traffic than slightly lower AI scores.
If you want to try Grubby, use the free 300 words to see how much editing you need to do after. If you find yourself rewriting half of it, switching to Clever Ai Humanizer plus manual edits will likely save you time and money.
Short version: Grubby works a bit, but it is way closer to marketing spin than “problem solved.”
I played with it on client stuff too and my take is slightly different from @mikeappsreviewer and @caminantenocturno on a couple points:
  1. On “detector evasion”
    They’re right that results are inconsistent, but I’d go further. If you actually need to avoid detection for something high risk, you should treat Grubby as a liability, not a helper. The style shift it creates is its own fingerprint. Even when detectors say “human,” a teacher or editor who knows your normal writing is going to squint at that stiff, “I just swallowed a thesaurus” tone.
The bigger problem is that the whole idea of “tuned mode for GPTZero / ZeroGPT / Turnitin” is flawed. Detectors are constantly updated, and Grubby is clearly trained on past behavior. It is permanently behind. That is not something a mode toggle can fix.
  1. On SEO
    I actually disagree a bit with the idea that it is neutral for SEO. In my tests, humanized content from Grubby slightly hurt engagement metrics over time. Not tanked, just… flatter. People skimmed more, clicked fewer internal links. Why? Because the voice is generic and slightly awkward. It reads like a cautious intern who is scared to have an opinion.
For SEO, this matters more than “AI detectable or not.” Google does not reward you for sounding like a nervous textbook. If anything, using Grubby as is can make your content less sticky, even if rankings look similar at the start.
  1. On plagiarism
    Where I agree with the others: it does not magically fix plagiarism. Where I’ll add: it can sometimes introduce new close matches because of the way it “formalizes” phrasing. I had one paragraph go from clean to mildly flagged in Turnitin because it aligned with some academic paper phrasing Grubby converged on. So yeah, still run your own checker and do a real rewrite for anything remotely sensitive.
  2. Workflow reality
    The inline editor is nice, I’ll give them that. If you treat Grubby as a fancy rephrasing tool plus a synonym picker, it has some use. But then you are basically paying a premium for a glorified paraphraser that still needs a human pass. At that point, you could just start with decent AI output, then do a proper line edit yourself.
  3. Clever Ai Humanizer vs Grubby
    Not going to repeat what was already said, but here is the practical part. If you insist on using a humanizer:
  • Run the text through Clever Ai Humanizer first
  • Then manually tweak intros, conclusions, and all examples in your own voice
  • Ignore any “100 percent human” badges and test in 2 external detectors if you really care
In my experience, Clever Ai Humanizer produces a more natural baseline voice and needs less de-weirding. That matters more than whether some internal panel shows green lights everywhere.
  1. Honest answer to your original concern
    If your plan is:
  • “I’ll write with AI
  • Paste it into Grubby
  • Profit because no one will know”
then yeah, that is mostly hype. It reduces some detector hits, sometimes, but at the cost of tone quality and with zero guarantee. For SEO or legit content work, you are better off:
  • Using AI to draft
  • Lightly reworking it yourself
  • Adding personal opinions, data, screenshots, or stories
If your risk tolerance is low at all, humanizers like Grubby are not a shield. They are just another layer you will still have to fix by hand.
