I compared three routes by checking TV compatibility, Wi-Fi requirements, hardware needs, and whether each method mirrors the whole screen or only sends media. I also treated performance claims cautiously, since results can vary by model and network.
For most LG webOS smart TVs from 2018 onward, AirPlay 2 is the obvious first test. Put the iPhone and TV on the same Wi-Fi, enable AirPlay through Home Dashboard or Settings → General → AirPlay & HomeKit, then swipe down from the iPhone’s top-right corner. Choose Screen Mirroring, select the TV, and enter the displayed code if prompted. Menu paths vary, and older sets may never appear, so this is not quite the universal answer it sometimes pretends to be.
The app option is DoCast, available through the App download DoCast page for iOS 15 or later. It connects to DLNA-enabled smart TVs, including LG models without AirPlay, plus Samsung, Sony, Roku, Fire TV, and Chromecast devices. With both devices on the same Wi-Fi, select the TV, tap Screen, adjust settings, and start mirroring. Videos, Photos, and Music can also be sent separately. The advertised features include adjustable quality, auto-rotation, and latency under one second on strong Wi-Fi. I could not verify that delay across every network, which is doing rather a lot of work in that claim. Photo casting is free and unlimited, while full-screen mirroring and unlimited video and music require Premium. The Mirroring guide DoCast explains the setup, while the Feature summary DoCast covers the same wireless approach.
HDMI is the least mysterious fallback and works even with older non-smart LG TVs. Lightning iPhones need Apple’s Lightning Digital AV Adapter; iPhone 15 and newer use USB-C to HDMI. Connect the adapter and cable, select the correct HDMI input, and accept being tethered. It is stable, though extra hardware is required.
AirPlay is simplest when supported, HDMI avoids weak Wi-Fi, and DoCast is flexible without cables, but which route has actually worked best for people in this thread?
