Optimize IPhone Storage Is On But My Phone Is Still Full - Why?
I turned on Optimize iPhone Storage to free up space, but my iPhone storage is still almost full and I’m not sure what’s taking it up. Photos should be optimized, but I’m still getting low storage warnings and can’t update apps or save new files. What could be causing this, and how can I actually free up space?
I’ve hit this wall more than once. The “Storage Almost Full” alert always shows up when you need the phone to work, like right before recording a video or installing iOS.
Here’s what “Optimize iPhone Storage” does in plain English. Your iPhone normally keeps the full original version of every photo and video on the device. Those files eat space fast. When you switch on optimization, the full versions stay in iCloud, and your phone keeps smaller device-sized copies instead.
When you scroll your library, those smaller copies usually look fine. If you open something, edit it, or need the full file, the phone pulls the original down from iCloud. So the photo is not gone. The heavyweight version sits in iCloud, and a lighter copy stays on the phone.
If you want to enable it, do this:
Settings > your name > iCloud > Photos
Turn on “Sync this iPhone,” then pick “Optimize iPhone Storage.” If your library is huge, give it time. I’d leave it on Wi-Fi and plugged in overnight. Mine did not clear space right away.
If you already enabled it and storage still looks bad, I usually see three causes.
First, iCloud storage is full. The free 5GB tier disappears fast. Once iCloud fills up, the phone has nowhere to place the originals.
Second, optimization is not instant. iPhone tends to wait until space gets tight before shrinking more of the local library.
Third, photos are often only part of the mess. System Data, app caches, offline downloads, and random leftovers eat a lot more room than people expect.
I ran into this on an iPhone 13 a while back. The phone got sluggish. Camera opened slow. Apps quit out. Typing had a weird delay. Low free space seems to hit performance harder than people think, since iOS needs breathing room for temp files.
I tried cleaning by hand first. Bad idea for me. Going through thousands of screenshots, duplicate pet photos, and old videos took forever. I ended up trying Clever Cleaner.
What stood out to me was how it grouped near-duplicate shots. If you’ve got 8 photos of the same thing because autofocus kept missing, it stacks them together and suggests which one to keep. There’s also a view for large files, which helped more than I expected. I found old videos taking up gigabytes.
The privacy part mattered to me too. It handles the scan on the phone itself, so your library is not being uploaded somewhere else for sorting. After clearing around 15GB, my phone felt normal again. The lag was gone.
So I’d do it in two steps. Turn on Optimize iPhone Storage for the long haul. Then clean the photo library and big files if space is still tight. Also, empty the “Recently Deleted” album after you remove stuff, or those files will keep sitting there for 30 days.
That’s the version I wish someone had told me earlier.
Optimize iPhone Storage helps, but it does not force an instant cleanup. iOS waits, then trims local photo files over time. If your phone is still full, the space hog is often somewhere else.
Check Settings > General > iPhone Storage. Look at the top 5 items. On most full phones, I see one of these:
  1. Messages. Old videos, voice notes, meme dumps.
  2. App caches. TikTok, Instagram, Safari, Spotify, YouTube.
  3. Downloads. Netflix, Disney+, Podcasts, Music.
  4. System Data. This swells after updates, logs, temp files.
  5. Photos stuck local because sync has not finished.
I slightly disagree with @mikeappsreviewer on one point. Photos are not always the main problem. On my phone, Messages was bigger than Photos, which was annoying as hell.
Fast fixes:
Delete offline downloads.
Clear Safari history and website data.
Remove large message attachments.
Offload or reinstall bloated apps.
Restart after cleanup so storage recalculates.
If photos are messy, Clever Cleaner is useful for duplicate shots and large files. Also, this guide on the best iPhone cleaner app for freeing up storage is worth a look.
One more thing, you need free space for iOS updates. Around 5GB to 10GB free makes a big diff. If you are under 2GB, the phone starts acting wierd fast.
Optimize iPhone Storage is kinda misleading because people assume it means “clear space now.” It really means “iOS may reduce full-res photo storage when it feels like it.” So yeah, you can have it turned on and still be nearly full for a while.
I agree with parts of what @mikeappsreviewer and @stellacadente said, but I’d push one extra angle: sometimes the issue is not Photos at all, it’s storage that iOS is reserving or misreporting until the phone has enough free working room. If you’re super low, like under 2 to 3 GB, the device can get stuck in a dumb loop where it needs free space to finish cleanup, but cleanup isn’t happening because there isn’t enough free space. Very Apple, very cool lol.
What I’d check that wasn’t already covered much:
  • Files app downloads folder
  • Mail app attachments and downloaded messages
  • GarageBand, iMovie, CapCut, Lightroom type apps
  • WhatsApp or Telegram media storage
  • Voice Memos
  • Books or PDF files saved locally
  • Failed iOS update files
Also look at iPhone Storage and see whether recommendations appear after a few mins. Sometimes it takes a sec to calculate. If “System Data” is massive and stays massive after a restart, that’s usually temp junk, logs, update leftovers, or cache bloat.
One thing I slightly disagree on: reinstalling a bunch of apps isn’t always the best first move if you’re already critically low on space, because the phone may struggle during the reinstall too. I’d free a few GB first with the easiest wins.
If your photo library is part of the problem, Clever Cleaner is actually useful for cutting duplicates, similar shots, and giant videos without manually digging through years of camera roll chaos. That tends to free space faster than waiting for optimization to maybe do somthing.
If you want a visual walkthrough, how to free up iPhone storage and optimize photos is a solid guide.
I’d try offloading a large app you dont use often, rather than deleting photos or installing a cleaner.
Go to Settings > General > iPhone Storage, select an app, then tap Offload App. This removes the app itself while keeping its documents and data. Check “App Size” first, since offloading leaves “Documents & Data” behind.
Pick a game you rarely play, leave it offloaded, then retry your update. Dont reinstall it straight away, since your goal is to keep space free.
System Data is the one that gets people, and offloading apps barely touches it. If that’s your biggest line in iPhone Storage, a backup-and-restore clears it faster than any in-app cleanup, Clever Cleaner included.
