What Are the Best TV Remote Apps for iPhone in 2026?
My TV remote stopped working, so I need a reliable iPhone replacement. Which top-rated TV remote apps in 2026 are easy to use and compatible with most smart TVs?
If you want the least annoying option, I'd try TVRem first. I looked into these after losing my remote yet again, and all four are free to download with good ratings. The biggest difference is how much they push ads, paid features, and subscriptions.
TVRem supports Samsung, LG, Roku, Fire TV, Android/Google TV, and Apple TV. It has the normal remote controls, a touchpad, shortcuts for apps like Netflix and YouTube, voice input, and phone keyboard support. That last part is especially useful when you need to enter passwords or search for something. There’s no premium tier or pop-up advertising, and it has a 4.8-star rating.
TV Remote – Universal Control from Evolly is probably the most established choice. It has more than half a million ratings, ranks high in the charts, and supports a wider range of brands, including Sony, Vizio, and Hisense. The app itself is solid, but it includes ads and puts some of the better features behind a subscription. Reviews also mention occasional connection drops and billing complaints.
Kraftwerk’s “Universal TV Remote” is another widely used option with a 4.6-star rating. The swipe-based controls are nice, and it can turn on a TV that has already been connected. The free version has ads, though, and useful features like keyboard input and quick app launching require the paid version.
Zap’s “TV Remote – Universal” is more basic, but it’s easy to connect and works well enough if you have a supported TV. Its list includes LG, Roku, Samsung, Sony, and Philips. It has fewer supported brands than the others and comes with ads plus an optional subscription.
My short version: get TVRem Universal remote if you want something free without ads or subscription prompts. Pick Evolly if broad brand support and a large user base matter more, and you’re fine with ads. Kraftwerk and Zap are reasonable backups.
Just keep in mind that these apps are for smart TVs connected over Wi-Fi. Your phone and TV need to be on the same network. If you have an older non-smart TV, you’ll need a physical universal remote instead.
“Universal” is a little misleading because an iPhone has no IR blaster, so these apps only work when the TV is reachable over Wi-Fi. Before installing TVRem or another third-party app, try the TV maker’s official app or your streaming box’s built-in remote, since it’s usually free and less pushy about subscriptions. The catch is that initial pairing, network changes, or disabled network standby may still require the physical remote, so a cheap replacement remote is worth keeping around.
Don’t assume an app that controls the TV menus will control your soundbar, receiver, or cable box too. Volume and power commands can fail when those devices use IR or HDMI-CEC isn’t configured, even though navigation works perfectly over Wi-Fi.
For the TV itself, I’d rank the manufacturer’s app first, then the remote built into Roku, Fire TV, Google TV, or Apple TV. Those usually match the hardware better and avoid subscription screens. Among third-party choices mentioned here, TVRem sounds like the cleaner starting point for common brands, while Evolly makes more sense if TVRem doesn’t recognize your model.
Before paying for anything, check iPhone Settings and make sure the app has Local Network permission. Then test wake-from-standby, volume, keyboard entry, and reconnection after closing the app. That five-minute check matters more than a high App Store rating. If the TV is completely off or disconnected from Wi-Fi, none of these apps will rescue you, so a basic replacement remote is still the dependable fallback.
Realistically, no iPhone app will behave exactly like the original remote in every situation. It may work perfectly once the TV is awake, then fail to find it after a router restart or when the TV enters deep standby. I wouldn’t choose by App Store rating alone.
My setup order would be:
  1. Use the remote built into iOS if you have an Apple TV.
  2. Try the TV manufacturer’s official app.
  3. Try TVRem if you want a clean third-party option for common smart TV platforms.
Before deciding an app is broken, turn off any VPN on the iPhone and confirm both devices are on the main home network. Guest Wi-Fi often blocks devices from seeing each other. Mesh routers and Wi-Fi extenders can cause the same annoyance if device isolation is enabled. Your iPhone should also have Local Network permission for the app. The TV and phone do not necessarily need the same Wi-Fi band, but they do need to be able to communicate through the router.
Then test the functions that matter before subscribing: waking the TV, changing volume, opening apps, typing into search fields, and reconnecting after the phone has been locked. If basic navigation works but power or volume does not, changing remote apps may not fix it. That usually points to standby settings, HDMI-CEC, or separate audio equipment.
For the question as asked, TVRem looks like the simplest first download, while Evolly is the better compatibility fallback. Still, @shadowdev4396edge is right that the official app should get the first attempt. I’d spend five minutes checking those options, then buy an inexpensive physical replacement if the TV regularly drops off Wi-Fi or cannot wake over the network.
Look up the exact TV model number before downloading anything. “Supports Samsung” or “works with LG” does not mean every model year uses the same network controls. App Store ratings will not fix a protocol mismatch.
For a current smart TV, use its official app first. If that feels bloated or requires an account for basic controls, TVRem is the sensible third-party attempt for the major platforms. Evolly is the fallback when model coverage matters more than avoiding ads and subscription prompts.
Test input switching and source selection, not only volume and arrows. Plenty of remote apps handle streaming menus but become useless when you need to switch from HDMI 1 to an antenna or game console. Pairing codes can be another problem if the confirmation window appears briefly on the TV.
Whatever you install, cancel any trial immediately if you do not plan to keep it. A remote app should not become a recurring household bill. If your exact model remains unreliable, buy the matching replacement remote by model number rather than another vaguely “universal” app.
Nobody’s flagged that most TVs ship with network standby turned off, so before you blame any app, dig into the TV’s power settings and enable wake-on-LAN or whatever it’s called on your brand. TVRem being clean doesn’t matter if the set is dead to the network the second it sleeps.
A TV that is already connected to your home network is an easy app replacement case. A TV that has been reset, changed routers, or forgotten the Wi-Fi password is a completely different problem, because no remote app can reach it to complete setup.
If you are stuck in that second situation, check whether the TV has an Ethernet port. Temporarily connecting it directly to the router may put it back on the network so the iPhone app can find it. Some TVs will accept a USB keyboard or mouse for basic setup too. Those workarounds can save you from buying a remote just to enter the new Wi-Fi details, though support varies by model.
For an app you will use regularly, I would still start with the manufacturer’s official app. It is usually the safest choice for input selection, settings menus, pairing prompts, and model-specific buttons. TVRem is a reasonable next download for Samsung, LG, Roku, Fire TV, Google TV, and Apple TV setups, especially if you want to avoid the usual subscription nags. Evolly is worth trying when TVRem does not detect the exact model, but I would test everything before accepting a trial.
The overlooked test is whether the app can get you back into normal viewing after something goes wrong. Restart the router, let the TV sleep for a while, then see whether the app reconnects and wakes it. A remote that works only while the television is already awake is more of a convenience panel than a true replacement. Network standby can help, as @anonymous mentioned, but some sets still drop network access in deeper power-saving modes.
So the best 2026 choice depends less on star ratings than on the TV’s network state and model. Official app first, TVRem as the cleaner multi-brand option, Evolly as the compatibility fallback. If the television frequently loses its connection, keep a cheap model-specific physical remote nearby because every iPhone app shares that same Wi-Fi weak point.
Try a wireless USB keyboard with a touchpad. Plug its small receiver into the TV’s USB port, then use the arrow keys, Enter, Escape, and touchpad for menus and searches. Many Samsung, LG, Sony, Android TV, and Google TV models support basic USB input.
This avoids Wi-Fi pairing, subscriptions, VPN issues, and network standby. Check your TV manual for USB keyboard support first. A basic model costs around $20 and works even after router restarts. Keep the TV’s physical power button acessible, since keyboard power control varies.
