What do you recommend when Muse AI gets stuck halfway through a task?
Muse AI stopped halfway through processing a recorded walkthrough for my team, and the visible progress hasn’t changed since I checked it again. I haven’t restarted it because I’m concerned about losing whatever has already finished.
Do you usually leave it running longer, retry the original task, or split the recording into smaller parts and start over, and why? What do you check before deciding that processing has actually stalled rather than just slowed down?
An unchanged progress bar doesn’t prove the task has stalled, and “halfway” doesn’t mean half the output has been saved. I’d leave the original tab alone for now, save any results you can already access, and note the job ID or take a screenshot before trying anything that might reset it.
My first check would be whether the upload actually finished. Then, if Muse AI lets you view the task from a separate dashboard tab, I’d check whether its status matches the original screen. Look for an error, a changed processing stage, or newly available output rather than watching the percentage alone. I’d compare the elapsed time with a similar recording you’ve processed before, if you have one. Without that baseline, I wouldn’t call it stuck just because two checks showed the same number.
I’d give it a defined waiting window rather than leave it indefinitely. If nothing changes, I’d check service notices or ask support about that job before canceling, especially if preserving partial work matters. Once it’s confirmed failed, I’d retry the original once. If it fails again, I’d try a shorter section. For a walkthrough, I’d split at topic boundaries and include a little overlap so a step doesn’t lose the explanation immediately before it. I wouldn’t launch several full retries while the first job’s status is still unclear.
If your team needs the walkthrough soon, I’d separate getting it to them from fixing the stalled job. Leave the task alone as @carl1991 suggests, but share the original recording through your team’s usual approved channel with a few timestamps so the processing delay doesn’t hold everyone up.
A frozen progress display and a stalled processing job aren’t necessarily the same problem, so I wouldn’t hit restart based on the bar alone. Keep the original tab open and, if there’s a saved task page or dashboard, check it in a separate tab. You’re looking for whether the task still appears, whether its status differs, and whether any output is available. That gives you something to go on without disturbing the original screen.
Sharing the recording handles the team’s immediate need, but I’d put a limit on leaving the task untouched. Before doing anything destructive, capture the screen and save the task ID or name, when you started it, and any error text. If nothing changes, send those details to support and ask specifically whether the existing job can be recovered or whether a retry starts from scratch. I wouldn’t assume that “halfway” means half the work has been saved.
Splitting the recording is just a troubleshooting step, not a repair. I would say, not move to shorter sections right away when you reach a failed retry. Before you make more uploads, make sure you have checked the recording you have fed to the app.
Look at the local version of it - does it play roughly at the beginning, middle, and end? Is the sound there, does it seem like it wasn’t cut off at the end? If there is a chance to compare with the original recording app’s file, do that as well. It will not necessarily indicate if the file is good, but it will help to eliminate some problems.
On the percentage of the upload progress, I wouldn’t take that as time passed or an indicator of where in the file the upload has stalled. There is no information given to assume that these two data points are connected in any way. Trying to bypass the point where the upload seems to stop altogether would be guesswork.
Once you are clear on whether to leave the existing job as is or not, make a specific request for a retry. Use a small part of the same file as a test, preferably a part that didn’t seem to cause a problem. If that works, you can say that this specific part is fine, but that doesn’t mean the whole file is good. If you have another attempt at exporting, keep the original and give the new file a different name. Do not change multiple variables at once unless you have nothing to lose.
For a walkthrough with a team, I would make a small note of every failed attempt indicating the files used and changes made to them. Not a long description, just enough to mark what’s what. ‘Walkthrough final revised final’ is not a log of attempts at troubleshooting. Neither is making several nearly identical uploads in a row, in case another team member will have to deal with it later.
You may not get a quick answer about whether the job is recoverable, but you can keep the whole team from independently trying to “fix” it. A frozen task does not need a committee enthusiastically clicking Retry.
I agree with @primecraft5689edge about separating the team’s immediate need from troubleshooting. I’d put a short note wherever people are waiting for the walkthrough: processing is unresolved, you’re handling it, and nobody needs to submit another copy yet. Sharing the recording without that explanation leaves room for someone to helpfully start the same process again.
Pick one person to handle any cancellation or retry. If that’s you, ask teammates to send you what they see rather than change anything themselves. Someone else seeing a completed result would be useful information. Someone else canceling the job while you’re asking support whether it can be recovered would be rather less useful. You don’t need an incident-management ceremony, just a clear “please leave this task alone while I check it.”
That doesn’t solve the stalled processing, but it keeps the recovery decision under your control. Once you know whether to keep waiting or start over, tell the team which attempt you’re using and share its output when it’s ready. The goal is one usable walkthrough, not several mystery copies and a group chat trying to establish which “finished” notification belongs to what.
Closing/refreshing that tab is almost certainly not going to kill the job. This is because, typically, this kind of cloud-published processing is done in a way where the server does the actual work and your progress bar is just a progress polling request to said server. Hence, the only time there might be something to worry about is when you touch the job itself (cancel or retry) and in this case, everyone above is right to tell you to leave that alone.
Where I’d push back a little on @carl1991 and @techbyte4023: a static progress bar sometimes means the browser just stopped getting updates, not that the job stalled. I’ve seen the number sit dead while the task quietly finished on the backend. That’s exactly why the separate dashboard check they mention is worth doing first, before you treat this as a failure at all.
The scenario that has not been noted is that a stalled job may be eating into your processing allowance. If the Muse AI uses a credit system for processing or has a monthly processing allowance, a stalled job may be causing it to appear as if the program is using up your credits with no output or preventing new jobs from initiating. It may be a good idea to check the usage page in addition to the status of the stalled job. If it has been waiting for an unreasonable amount of time, and the usage has not changed, it is safe to assume that the program has stalled and is falsely reporting its status.
I would suggest your own personal procedure be based off of the suggestions previously mentioned. Have a single allowable waiting period, check the dashboard and the usage, and cancel the job and retry the entire file if nothing has changed. The splitting of a walkthrough file should be a last resort and should only be attempted if the stalled job has been canceled and the retry has failed. The splitting of the walkthrough is an unnecessary inconvenience and changes the nature of the requested output, and should be avoided if at all possible.
Don’t use the usage counter as a cancellation trigger, @opencraft. First check what it measures and when it updates. If you can’t establish that it reflects ongoing processing, an unchanged total tells you too little to justify canceling work you want to preserve.
An easier step would be to reach out to the Muse AI Support team with the name of your recording, when it was uploaded and a screenshot of where it has got to and ask them to look into this issue. They will be able to tell you what options you have for retaining work that has been done. Whilst waiting do not touch the processing job.
If your team need the walk through now then you can share the original recording with your team using your approved file sharing tool. You can add timestamps to highlight key areas of the recording and only share with those that need to see it.
