What’s the best way to mass delete photos on iPhone?
My iPhone storage is almost full because I have thousands of old photos and screenshots. I’m trying to find the fastest safe way to delete photos in bulk without removing anything important from iCloud or my other devices. Any tips for mass deleting iPhone photos?
If your Photos library is sitting at something like 20,000 items, don’t try to clean it by tapping one photo at a time. That’s the slowest possible way to do it, and it’s way too easy to either give up or delete something you meant to keep.
I’d start with the obvious junk first, then deal with duplicates and near-duplicates after that.
Start with the built-in Photos tools
In the Photos app, avoid working from the full “All Photos” view if you can. Pinch inward on the screen so you’re looking at your library by Months or Years instead. It gives you bigger chunks to work with, which makes cleanup feel a lot less painful.
From the Months view, tap “Select,” then drag across groups of photos instead of tapping every single one. This is useful if you know there’s a specific stretch of time you want to clean up, like an old trip where you took way too many videos or a month full of random saved images.
Delete the easy stuff first
Screenshots are usually the quickest win. Go to the Collections tab, scroll down to Media Types, and open Screenshots. Apple also separates things like Bursts and Screen Recordings there, so it’s a good place to clear out clutter that usually isn’t worth keeping.
Inside the Screenshots album, tap “Select,” then use “Select All” if you want to remove the whole batch. That button isn’t available everywhere in Photos, but it does show up in some of these grouped albums, which makes this part much faster.
Use Clever Cleaner for duplicates and almost-duplicates
The annoying part is when you have five or ten photos that are basically the same shot. You can sort those manually, but it gets old fast. For that, I’d use Clever Cleaner. I’m usually pretty skeptical of phone cleaner apps because a lot of them are packed with ads or subscriptions, but this one is free and actually useful.
The feature to look for is Similars. It groups photos that look nearly identical, like several versions of the same group photo, then picks a “Best Shot” and marks the rest for removal. You still get to review everything before deleting, so it’s not just blindly wiping out your library. When you’re ready, you use “Slide to Delete.”
Use a computer if you’re deleting thousands
If you’re trying to remove a huge number of photos, doing it on the phone can be miserable. A desktop browser is usually easier.
If you use iCloud Photos, go to iCloud.com on a computer. You can hold Shift on the keyboard to select large ranges of photos quickly, then delete them with the trash icon. It’s more controlled than dragging around on a small phone screen, and the changes should sync back to your iPhone.
Clear Recently Deleted too
One thing people miss all the time: deleting photos doesn’t immediately free the space. On iPhone, deleted items go into Recently Deleted first. You’ll find it near the bottom of the Collections tab under Utilities.
Photos can sit there for 30 days before they’re actually removed. So if you need storage space right now, open Recently Deleted, tap “Select,” then choose “Delete All.” That’s when the available storage should actually change.
Also check the Files app. Some images and downloads never show up in your main Photos library. Open Files and look through “On My iPhone” and “iCloud Drive.” Old Safari downloads, email attachments, or saved image folders can be hiding there and still taking up space.
A decent cleanup order would be: screenshots first, then screen recordings and bursts, then let Clever Cleaner handle the duplicate-looking stuff. That should get most of the mess under control pretty quickly without you having to pick through every photo one by one.
If iCloud Photos is turned on, deleting from the iPhone is deleting from iCloud and your other synced devices too, so don’t treat it like clearing local storage. For a safer bulk cleanup, first move keepers into a separate album or export them to a computer/external drive, then delete in batches and check Recently Deleted before emptying it.
Don’t hit Delete All in Recently Deleted until you know whether iCloud Photos is syncing. That is the point where “oops, I’ll restore it later” can turn into “it’s gone everywhere.”
I agree with @caminantenocturno on the iCloud warning, but I’d separate this into two different jobs because people mix them up:
If your goal is to free space on the iPhone only, deleting may be the wrong move. Go to Settings > your name > iCloud > Photos and check whether iCloud Photos is on. If it is, try Optimize iPhone Storage first. That keeps smaller versions on the phone and stores the full-size originals in iCloud. It is much safer than deleting a bunch of photos just because the phone is full.
If your goal is to permanently reduce the size of your photo library, then yes, delete. But treat it like cleaning out a real archive, not like clearing app cache.
A safer order would be:
  1. Turn on Optimize iPhone Storage if you mainly need phone space.
  2. Back up or export anything important before mass deletion.
  3. Clean obvious categories first: screenshots, screen recordings, blurry bursts, saved memes, random receipts.
  4. Use duplicate/similar-photo tools only as a review tool, not an autopilot.
  5. Wait a bit before emptying Recently Deleted unless you are 100% sure.
The missing trap is that albums are not folders. If you move photos into an album called “Keep,” that does not create a separate backup copy. It is just a way of organizing the same photo. If you delete that photo from the library, it is gone from the album too. A lot of people think “I put my good ones in an album, now I can delete the rest from Recents,” but Recents is still the main library view.
For a big cleanup, I’d actually do the first pass by date rather than by “what looks important.” Pick a year or month you know is mostly junk, then select chunks from there. Screenshots from three years ago are usually easier to judge than family photos mixed in with everything else. Search can help too. Try words like “receipt,” “whiteboard,” “menu,” “screenshot,” or names of apps if they appear in images. Photos search is not perfect, but it can surface junk faster than scrolling forever.
Clever Cleaner or similar tools can be useful for near-duplicates, especially where you took 12 versions of the same shot. I just wouldn’t let any app be the first thing you use. Do the obvious manual cleanup first, then use the app for the annoying comparison work. The risk with “best shot” suggestions is that the technically best photo is not always the one you care about. Sometimes the blurry one is the funny one.
If you have a computer, the boring method is still the safest: import the photos to the computer or an external drive, verify you can open them, then delete from the phone/iCloud. Do not count “I plugged it in once” as a backup. Make sure the files are actually there.
Last small annoyance: storage may not update immediately. After deleting, emptying Recently Deleted is what frees the space, but iOS can still take a little while to recalculate. Restarting the phone after a large cleanup sometimes makes the storage screen catch up. If Photos is still huge after that, check Settings > General > iPhone Storage > Photos and see what category is actually using the space before deleting more.
Open Settings > General > iPhone Storage first and see what Photos is actually taking up before you start deleting thousands of items. The count can fool you. A few long videos, screen recordings, slo-mo clips, or Live Photos can eat more space than years of normal pictures.
I’m with the others on the iCloud warning, but for speed I’d go after the largest media types before messing with duplicate photo cleanup. In Photos, check Videos, Screen Recordings, Slo-mo, Cinematic if you have it, and Bursts. Delete the obvious junk there first. If you shot a bunch of concerts, kids’ sports, lectures, or random screen recordings, that is usually where the real storage is hiding. Deleting 3,000 screenshots feels productive, but deleting ten huge videos may free more space.
For duplicates, Clever Cleaner or any similar app is fine as a second pass, but I wouldn’t make that the main strategy if you’re almost out of space right now. Similar-photo cleanup saves clutter more than massive storage unless you take tons of repeated shots. I’d do big videos first, then screenshots, then duplicates, then leave Recently Deleted alone for a day or two if you’re unsure. If you need space immediately, empty it only after checking that you didn’t accidentally toss something important.
