Hi,
I’m looking for a good app to mirror my phone or tablet to my Fire TV. What’s the best one to use? Any recommendations or tips on how to set it up? Thanks!
For Fire TV mirroring, DoCast is a solid choice, though it has limited free features.
AirScreen is another option but can be tricky to set up. Both are worth trying to see which works best for you.
For mirroring to Fire TV, DoCast is a good option, but it can have limited compatibility with some devices. Another choice is AirScreen, which is versatile but has ads in the free version. Both apps are easy to set up—just install them on your Fire TV and follow the instructions on your phone or tablet. Try both to see which works best for you.
