EaseUS data recovery issue
I recently used EaseUS Data Recovery to recover important files from a corrupted hard drive. However, some of the recovered files are not opening and seem to be corrupted. Has anyone faced this issue? How can I repair these files? Really need those documents for an upcoming project.
I’ve run into the same problem with EaseUS a few times. It seems like the software can sometimes recover files in a corrupted state if the drive is too far gone. Here are some steps you can take to try and fix it:
  1. Check File Extensions: Sometimes the recovered files may have lost their extensions or have them incorrectly labeled. Make sure they match the correct file type.
  2. Use a File Repair Tool: For corrupted files like documents, photos, or videos, using specialized file repair tools can help. Tools like Stellar Repair for Video or Photo can sometimes work wonders.
  3. Try a Different Data Recovery Software: Not all data recovery programs use the same algorithms to recover files. I had better luck with Disk Drill when EaseUS failed me.
    It seemed more thorough in scanning and recovering usable files. You can Download Disk Drill and give it a try.
  4. Repeat the Recovery Process: Before you give up, sometimes just running the recovery process again can work. Make sure your hard drive connection is stable and try the deep scan feature to see if it picks up any more data.
  5. Consult a Professional: If it’s critical data, and you’re still having trouble, it might be worth contacting a data recovery professional. They can sometimes access and restore data that regular consumer software can’t.
I’ve had experiences where no matter what I tried software-wise, some files just couldn’t be recovered. Those are usually the times when the drive itself is physically damaged. In the future, frequent backups are key to avoid the headache altogether. Anyone else have other tips or tricks?
I’ve seen issues like this crop up with EaseUS too. Not to bash the software — it’s great, but not perfect. If your files emerged corrupted from recovery, here’s some other strategies you might wanna try.
  1. Alternative Data Recovery Software: Honestly, not all software operate the same. EaseUS is decent, but you might wanna give Disk Drill a shot. It uses different algorithms and sometimes picks up files that others miss. You can grab Disk Drill here and see if it does any better. In some tricky situations, it’s been my go-to.
  2. Manual Check for Data Integrity: Sometimes, going manual can help. Open the recovered files in a hex editor to see if you can spot any recoverable data that looks intact. This way, you might identify partially corrupted files which can be salvaged.
  3. Use Command Line Tools: If you’re comfortable with command-line, consider using tools like ddrescue on Linux. It can be really powerful for pulling data off a failing drive and might recover data that other tools miss.
  4. File Recovery from Multiple Angles: If you have another backup or different versions of the files, layering these with the corrupted ones might help. For instance, if you have partially corrupted video files, overlaying them with different recovered versions can sometimes stitch together a usable file.
  5. Check Drive Health: Use S.M.A.R.T. monitoring tools to see the condition of your hard drive. If the drive’s in a bad state, consider cloning it to another drive before doing more data recovery attempts. Sometimes, running recovery on an already failing drive can make it worse.
  6. Use Specialized Repair Tools: Tools like Recuva and Photorec might offer different recovery results. They approach the recovery process differently and stand a shot at getting the data EaseUS couldn’t manage.
  7. Partition Recovery: If your drive had distinct partitions and you haven’t done so yet, you might also attempt partition-level recovery. Tools like TestDisk can reconstruct lost partitions and might make some currently inaccessible files recoverable.
Finally, for permanently corrupted files that just won’t open, even professionals sometimes hit a wall. Data can become too tangled for any software repair. When in doubt, don’t overwrite your existing data — keep the drive as is and maybe try other professional services if the data is that critical.
Yeah, hope this helps. Anyone else here with more magic tricks to fix corrupt files post-recovery?
Been there, done that. Frankly, EaseUS is hit or miss. It’s supposed to be reliable, but I’ve had more misses than hits with it. Not surprised your recovered files are corrupted.
Here’s what to try:
  1. Run a deep scan: Yes, they all say it. But I doubt EaseUS’s partial scan gets everything. Try a deep scan—might get more results but be prepared to wait.
  2. Tweaking File Headers: If you’re somewhat tech-savvy, open the files in a hex editor. You MIGHT be able to fix corrupted headers. Caution: you can also easily make things worse. Just saying.
  3. Try Disk Drill: It’s not a silver bullet, but Disk Drill tends to be more thorough. Sure, it’s pricey—but isn’t everything when recovering crucial data?
  4. Use different tools: EaseUS isn’t the only one. Recuva, TestDisk, even Recover My Files—they have their pros and cons. Sometimes a combo works when one alone doesn’t.
  5. Drive cloning: If your drive’s failing, clone it before another pass. ddrescue can be your friend here. Avoid worsening the corruption.
  6. Professional help: Ultimately, if those files are worth saving and software isn’t cutting it, bite the bullet and call a pro. It’s expensive but sometimes the only viable option.
Nonetheless, backup frequently to avoid these headaches. The reality is sometimes data is too damaged. No software or soft-hearted sentiment can change that.
Your issue matches common EaseUS misses. You tried deep scan, header edits, other tools, cloning, a pro.
Try a simpler path. Restore via Previous Versions, Volume Shadow Copy. On Windows, rigth click the parent folder, Properties, Previous Versions, open a date before corruption, copy files to a different drive. If you used OneDrive or Google Drive, check Version history, restore the last good copy. Typical default is 30 days. This reduces disk reads and preserves integrity. Test on a few files first.
