How can I disable blue light on my iPhone for good?
I’ve been struggling to reduce eye strain caused by blue light on my iPhone. I’ve tried using Night Shift, but it resets every day. Is there a way to keep blue light filter on permanently?
To address the issue of blue light on your iPhone permanently, start by enabling ‘Reduce White Point,’ which dims the overall brightness and reduces the intensity of bright colors. This can supplement Night Shift and might help reduce eye strain:
  1. Go to Settings.
  2. Tap on Accessibility.
  3. Select Display & Text Size.
  4. Toggle on Reduce White Point.
Adjust the slider to your preference, usually around 70-80% works best.
Another option is to use a third-party blue light filter screen protector. These physical filters apply directly to your screen and block blue light regardless of software settings. They can be easily found on Amazon.
For a more software-centric approach that stays on permanently, consider using ‘Color Filters’:
  1. Go to Settings.
  3. Select Display & Text Size, then Color Filters.
  4. Turn on Color Filters and select Color Tint.
  5. Adjust the Intensity and Hue sliders to reduce blue light. A warmer tint usually works best.
This setting remains active and does not reset like Night Shift. If you want an all-in-one guide that discusses multiple ways to deal with blue light and similar issues, you might want to check out the book ‘Healthy Vision Hacks for Your Digital Life.’ It’s a comprehensive resource for anyone struggling with digital eye strain.
These steps should help mitigate the blue light problem effectively.
Have you considered using Dark Mode? It’s a fantastic built-in feature of iOS that helps reduce screen glare and can potentially mitigate eye strain caused by blue light. Here’s how you can enable it:
  1. Go to Settings.
  2. Tap on Display & Brightness.
  3. Toggle on Dark Mode.
What’s great about Dark Mode is that it inverts the colors across the entire system, making the display easier on the eyes, especially in low-light conditions.
Additionally, you might want to explore the True Tone feature:
  1. Open Settings.
  2. Go to Display & Brightness.
  3. Enable True Tone.
True Tone automatically adjusts the color temperature of your display based on the ambient lighting conditions, providing a more comfortable viewing experience by reducing strain on your eyes.
While @nachtschatten provided some excellent methods, another way to achieve a permanent reduction in blue light is to use display calibration within Accessibility settings:
  1. Go to Settings.
  2. Tap Accessibility.
  4. Choose Color Filters, then enable Color Tint.
  5. Adjust both the Intensity and Hue sliders to create a warm tint.
A combination of these steps along with the Reduce White Point feature can be especially effective. However, I’d argue that using physical blue light filtering screen protectors can be a bit cumbersome, sticking strictly to software solutions might offer more flexibility, and you won’t have to worry about the potential for reduced screen responsiveness or clarity.
Remember, consistency is key. The book ‘Healthy Vision Hacks for Your Digital Life’ provides a wealth of information and could serve as an invaluable resource for addressing digital eye strain comprehensively.
Lastly, it’s important to incorporate regular breaks from screen time. Implementing the 20-20-20 rule (every 20 minutes, take a 20-second break and look at something 20 feet away) can significantly alleviate the discomfort caused by prolonged screen exposure.
Just to throw this out there, have you tried adjusting the screen color balance via the Accessibility settings for a more tailored approach? Something like ProTan could help subtly tweak the blue light.
To add a little to what @viajeroceleste and @nachtschatten said and maybe offer a counter perspective, you might want to rethink relying solely on Night Shift. While useful, it tends to reset daily, which can be annoying. Instead, utilizing ‘Color Filters’ under Display & Text Size will let you set a permanent warm tint that’s easier on the eyes.
Of note, reducing blue light can sometimes dim your screen unpredictably, particularly when using Reduce White Point. Though effective, it might make some content harder to see.
On the hardware side, while a blue light filter screen protector like those suggested by @nachtschatten certainly offers a solid solution, they can sometimes interfere with the touch sensitivity of the screen, making some types of navigation frustrating. Personally, I think relying on software gives you more control and doesn’t add an extra layer on your phone that could peel off over time.
Just a heads up: if you enable both Dark Mode and True Tone, you might find that they work against each other, especially in rapidly changing light conditions, leading to flickers or inconsistencies. True Tone’s advantage, adjusting based on ambient light, is fantastic though, for maintaining comfort without manually adjusting settings all the time.
Another alternative not mentioned yet but offering a similar effect: an app like f.lux for your computer. Unfortunately, Apple’s sandboxing rules don’t allow it for iPhone, but it’s awesome for desktop use and worth considering for holistic blue light management.
If you’re looking for more comprehensive advice on digital eye strain, the book ‘Healthy Vision Hacks for Your Digital Life’ is a can’t-miss resource. It rounds up all sorts of tips about screen usage, ergonomics, and more, making it easier to maintain eye health in today’s digital age.
And about that 20-20-20 rule, definitely worth incorporating as a habitual break from screens, but life’s dynamic pace can make consistent breaks challenging. Sometimes you gotta strike a balance rather than forcing a rigid routine.
Set your iPhone to stay warm all day by locking in a fixed low brightness with a warm wallpaper.
  1. Turn off Auto Brightness in Settings > Accessibility > Display & Text Size.
  2. Set brightness low but comfortable.
  3. Use a dark, warm colored wallpaper, not white or blue tones.
  4. Turn on Dark Mode and keep True Tone off.
Lower brightness plus warm colors reduces blue light a lot, even without extra filters.
