How can I recover data from my WD Passport?
I accidentally deleted important files from my WD Passport external hard drive. I need to recover these files as they contain valuable data for my project. Any recommendations on reliable data recovery tools or services? What should I do next?
Facing the same issue not so long ago, I get how frustrating it can be to lose important files on your WD Passport. Here’s what worked for me and could potentially help you out.
First thing is, don’t write any new data to the WD Passport. Every time you save a new file, it increases the possibility of overwriting the deleted data, making recovery more difficult.
As for the tools, I’d suggest starting with Disk Drill
. This software is reliable and has a user-friendly interface, which is great if you’re not super tech-savvy. Here’s a quick breakdown:
Pros of Disk Drill:
  1. User-Friendly Interface: It’s pretty straightforward, even for non-techies.
  2. Preview Before Recovery: You can see which files are recoverable beforehand.
  3. Free Version: Allows you to recover up to 500MB without any cost, which can be handy.
  4. Supports Multiple File Systems: Whether you’re working with NTFS, FAT32, HFS+, or ext2/ext3/ext4, Disk Drill has got you covered.
  5. Quick/Deep Scan Options: Depending on how serious your data loss is, you can go for a quick scan or a more intensive deep scan.
Cons of Disk Drill:
  1. Pricey Pro Version: If you need to recover more than 500MB, you’ll have to upgrade to the Pro version, which can be a bit pricey.
  2. Limited Free Features: While the free version is great, some features are locked behind the paywall.
There are other tools out there like Recuva and EaseUS Data Recovery Wizard. Both are pretty good too—Recuva has a free version that’s unlimited in data recovery capacity, while EaseUS is known for its relatively higher success rate but costs more. MiniTool Power Data Recovery is another solid choice if you’re looking for a straightforward, no-fuss option.
Here’s a bit of a step-by-step on how you could use Disk Drill for your recovery:
  1. Download and Install Disk Drill: Make sure you get the right version for your OS.
  2. Connect Your WD Passport: Plug it in and ensure it’s recognized by your computer.
  3. Choose the Drive: Open Disk Drill, and you should see your WD Passport listed among the storage devices.
  4. Start the Scan: You can start with the Quick Scan. If that doesn’t yield the results you want, go for the Deep Scan.
  5. Preview and Recover: Once the scan is complete, you can preview the files to see which ones are recoverable. Select the files you need and hit ‘Recover’.
A tip in case you run into issues with Disk Drill: make sure you have enough space on your main drive to recover the data. It temporarily saves the recovered files before moving them back.
Also, avoiding continuous use of the WD Passport until you’re done with the recovery is crucial. If Disk Drill doesn’t do the trick, you might want to try contacting a professional data recovery service, but keep in mind that these services can be quite expensive.
Hope that helps and good luck with recovering your project files!
Hey, I totally get where you’re comin’ from. Losing critical files on an external drive is a nightmare, but there’s hope! Here, I’ll share some alternatives and extra tips that might not have been covered already by @techchizkid.
Firstly, if Disk Drill sounds good to you but you wanna keep your options open, another solid choice is Recuva, developed by Piriform. It’s free and supports an unlimited amount of data recovery, which is a huge plus if you don’t wanna spend money upfront. It’s straightforward and has both Quick and Deep Scan modes. Although Recuva’s interface isn’t as polished as Disk Drill, it’s reliable enough for most recovery needs.
Now, one step you might not have considered is recovering data using the built-in features of the operating system. If you’re on Windows, File History or a Windows Backup could come in handy if you had these enabled. Here’s a quick rundown:
  1. Open the Control Panel and navigate to System and Security > File History.
  2. If File History is on, you’ll see an option to Restore personal files.
  3. Browse through older versions of your files and restore them.
Mac users have a similar tool called Time Machine. If you’ve been backing up your Mac, you might be in luck without needing any third-party software.
Online Cloud Backups
Always worth a shot to check any cloud backup service you’re using, like Google Drive, Dropbox, or iCloud. Sometimes, you might have those services configured to back up your external drives.
Using a Different Computer
Sometimes the problem could be with the current system. Try plugging your WD Passport into a different computer. This can sometimes clear up issues with recognition or give you a different perspective on how to tackle the recovery.
Professional Services
If none of the above methods get you to where you need, it’s worth considering data recovery services, though they’re costly. @techchizkid touched on this, but let me add that companies like DriveSavers or Secure Data Recovery offer a “No Recovery, No Charge” policy, so you only pay if they achieve results. These services are usually pricy but highly effective.
Possible Tech Interventions
For advanced users, using robust tools like TestDisk can be invaluable. It’s a bit less user-friendly but incredibly powerful, especially for file system fixes and deeply-rooted recovery issues. TestDisk can help rebuild partition tables and recover lost partitions, which might be overkill for simple file recovery but is worth noting if you’re dealing with something more complex.
Step-by-Step for TestDisk:
  1. Download TestDisk: Available from CGSecurity.
  2. Run TestDisk: It’s a command-line tool, but don’t be intimidated.
  3. Analyze: Select your drive and let TestDisk analyze it.
  4. Recover: Follow on-screen instructions to recover your partitions and files.
Additional Tips:
  1. Avoid Heat: Make sure you’re working in a cool environment. Overheating drives can make the problem worse.
  2. Backup Strategy: After recovery, consider a more robust backup plan to prevent future heartaches. Multiple backups, perhaps one on a local storage and another in the cloud.
  3. Health Check: Tools like CrystalDiskInfo (for Windows) or DriveDx (for Mac) can give you insights into the health of your HDD.
Conclusion
So, while Disk Drill (which you can check out here: Disk Drill) is a fantastic tool, you shouldn’t overlook Recuva, system backup utilities, cloud backups, or even professional services if needed. Remember, the key thing is not to use the drive until you’re done with the recovery process.
Everyone’s experience can vary, but taking a multi-pronged approach will increase your chances of getting your valuable files back. Good luck, and may the data recovery gods be with you!
When files get accidentally deleted from an external hard drive like your WD Passport, it’s indeed a serious hassle. First off, completely agree with @codecrafter: avoid writing new data to the drive to prevent overwriting.
I’ll add another tool into the mix—PhotoRec. While TestDisk focuses on partition recovery, PhotoRec is specifically designed for file recovery and can be incredibly effective, especially since it’s free and open-source. Unlike Disk Drill, it isn’t as intuitive but compensates with a powerful recovery engine.
Using PhotoRec
  1. Download: Grab it from the CGSecurity website.
  2. Run it: It runs in a terminal or command prompt, but guides you through the process.
  3. Select Drive: Choose your WD Passport.
  4. Choose the filesystem: Select ‘other’ if you’re unsure.
  5. Select the recovery option: Choose ‘Free’ for free space only to avoid recovering already existing files.
  6. Choose destination folder: It’s crucial to save recovered files on a different drive.
Backup Recovery Might Help
If you were using any ongoing backup services or features—like Windows File History or macOS Time Machine—you could be in luck there, like @techchizkid mentioned. But I’d say, don’t rely too much on system backups for extensive data loss situations because they might not cover everything you need.
Windows and Mac OS-integrated solutions
For Windows users, using Shadow Explorer could be an option. This tool lets you browse the shadow copies created by Windows. The professional versions of Windows (think Pro and Enterprise editions) have this feature available by default.
For Mac users, Data Rescue is another legit choice if Time Machine fails. It’s more expensive but boasts advanced features.
Different Environment?
Don’t underestimate plugging your external HDD into another machine—sometimes, compatibility or system-specific issues hinder the recovery process. A different OS, for instance, may interpret the drive structure better.
Professional Data Recovery Services
Professional services remain the last resort. :raised_hand: While they cost quite a penny, the odds of successfully retrieving data are higher. Check out DriveSavers or Secure Data Recovery, as @codecrafter pointed out. They indeed have “No Recovery, No Charge” policies which can be a financial relief.
Pro Tips:
  1. Regularly Backup: To save yourself future headaches.
  2. Check Drive Health: Tools like CrystalDiskInfo (for Windows) and DriveDx (for Mac) can report the status of your HDD and alert you to potential issues.
  3. Use Dedicated Recovery Software: Consider Disk Drill for its robust features like Quick/Deep scan and support for multiple file systems (NTFS, FAT32, HFS+, etc.). The tool can be found here: Disk Drill Data Recovery Software.
While efficient, Disk Drill can be heavy on the wallet if you need more than the free data limit. However, its rich feature set and user-friendly interface can be worth the investment.
In summary, nobody likes being in your shoes, but with the combination of free tools like PhotoRec, system backups, and premium ones like Disk Drill, your chances of recovery look bright. Be thorough in exploring all these avenues, and you’ll likely get your valuable project files back. Good luck!
