How can I stream my iPhone to an LG TV without using Apple TV?
I’m struggling to mirror my iPhone to my LG TV and I don’t own an Apple TV. I’ve tried a few apps and methods, but none have worked so far. Does anyone know of any reliable ways to do this? Your help would be greatly appreciated! Thanks!
For mirroring your iPhone to an LG TV without having Apple TV, I’ve got a couple of suggestions that tend to work well. First things first, you wanna make sure both your iPhone and your LG TV are connected to the same Wi-Fi network to make any of these methods work.
One reliable option is using the DoCast Screen Mirroring app. This app usually doesn’t get laggy and supports most LG TV models. You can grab it from the App Store and follow the steps it guides you through. It’s pretty straightforward. You can check out more details on their Official DoCast App page: iPad & iPhone Cast to Roku, Chromecast, DLNA Smart TVs, and Fire TV
Another method is to use an HDMI adapter. You need to buy a Lightning Digital AV Adapter from Apple or a certified one from another brand, and an HDMI cable. Plug the adapter into your iPhone, then connect the HDMI cable to the TV and adapter. Your iPhone screen should instantly mirror to your TV.
If you prefer wireless, and DoCast doesn’t work for you, there’s also an app called LetsView which you can try. It’s free and pretty user-friendly. Just install it on your iPhone and follow the instructions it provides.
And if none of these work, you might need to check if your TV’s firmware is up to date. Sometimes outdated software can prevent these connections from working smoothly.
Hope one of these solutions works for you. Tech can be a real pain sometimes, huh? Good luck!
Hey, sorry to hear you’re having such a hard time with this. I’ve been there – trying to get your iPhone to mirror anything can be super tricky without Apple TV. codecrafter’s suggestions are decent, but let me throw in a couple more alternatives that might just solve your issue.
You could try AirPlay 2 if your LG TV is one of the newer models that support it. Not all LG TVs do, but if yours is one of the lucky ones, you should be able to swipe down on your iPhone to open the Control Center, tap Screen Mirroring, and select your LG TV from there. It’s sleek and doesn’t require any extra apps, as long as your TV supports it.
Also, there’s an underrated method: third-party casting devices like Chromecast or Roku. These are pretty affordable compared to an Apple TV. You just plug one into your TV’s HDMI port, set it up, and then you should be able to cast content directly from various iPhone apps to your TV. Most of the major streaming apps like YouTube, Netflix, and even some photo apps support casting.
Codecrafter recommended the DoCast Screen Mirroring app (Download Docast on Appstore: https://apps.apple.com/app/docast-cast-and-mirror-to-tv/id6446948344) and it’s a solid option, especially when it works with your TV model. But if it didn’t work for you, another app you could test out is iMediaShare which streams your phone’s media files like photos, videos, and music. It’s pretty easy to use and doesn’t require any complex setup.
For a bit more niche option, there’s something called a DLNA app. DLNA stands for Digital Living Network Alliance, and there are several apps out there like TV Assist. It helps your device communicate over your home network and can stream media files to your TV. This method can sometimes be a bit clunky and may not support live mirroring unlike other methods, but it’s worth a shot.
I’d slightly disagree with using an HDMI adapter as codecrafter suggested. It’s a good fail-safe for sure, but part of the benefit of these new TV setups is going wireless, right? So, maybe try out these wireless methods first.
Lastly, here’s a less-known trick: mirror with a computer as an intermediary. If you have a computer you can connect it to the TV via HDMI and use an application like AirServer or Reflector on your computer to mirror your iPhone to the PC, which in turn will display it on your TV. It might sound out-of-the-way, but it usually works quite well and sidesteps any compatibility issues between the iPhone and the TV.
Just make sure your TV has the latest firmware update. Outdated software can mess with what devices and apps it’ll work smoothly with. You can usually find the update option in your settings menu on the TV.
Hope this gives you a few extra avenues to explore! Trust me, messing around with tech to get it just right can be super frustrating, but once it clicks, it’s worth all the effort. Good luck!
Why are people suggesting so many apps like DoCast, LetsView, and iMediaShare? :zzz: Just get a Chromecast or a Roku and be done with it. You don’t need all these random apps clogging up your phone. These devices are cheap and super easy to set up; you won’t have to deal with any unreliable apps or connection issues.
And by the way, “DoCast Screen Mirroring,” sure, it might get the job done, but it can be laggy and sometimes just doesn’t support certain LG TV models. Save yourself the headache. For those saying HDMI adapter is old school, well, it is – but at least it works every time. No Wi-Fi issues, no app crashes.
Why make things complicated with buggy apps and wireless problems when you’ve got solid, straightforward options? If your TV supports AirPlay 2, use it; if not, use a casting device that’s actually built for this. Avoid the hassle.
