How do I screen mirror with my Onn Roku TV?
Trying to mirror my phone screen to my Onn Roku TV but I’m not sure how to get it to work. I’ve attempted to connect through my phone’s settings, but it’s not showing up on the TV. Any tips or step-by-step instructions would be greatly appreciated.
First things first, make sure your Onn Roku TV and your smartphone are on the same Wi-Fi network. If they’re not, the devices won’t recognize each other. Let’s break it down step-by-step:
  1. Check Compatibility: Not all phones have the capability to screen mirror, so double-check if your phone supports this feature. Most newer Androids and iPhones do.
  2. Enable Screen Mirroring on Roku:
    • On your Roku remote, hit the Home button.
    • Scroll and select Settings.
    • Go to System.
    • Select Screen Mirroring.
    • Choose either Prompt or Always Allow. I’d recommend Prompt if you’re cautious about unauthorized devices connecting.
  3. On Your Phone:
    • For Android:
      • Drag down the notification bar and look for a feature called Screen Cast, Smart View, Cast, or something similar.
      • Tap this feature, and your phone will start looking for available devices to cast to. Your Onn Roku TV should appear in the list.
    • For iPhone:
      • Swipe down from the top-right corner of the screen to open the Control Center.
      • Tap the Screen Mirroring button.
      • Select your Onn Roku TV from the list.
Some troubleshooting tips if nothing shows up:
  • Restart your Roku TV and your phone. Sometimes a quick reboot solves connectivity issues.
  • Ensure your phone’s software is up-to-date.
  • If you have multiple Wi-Fi networks in your home (like a guest network), make sure you’re connecting both devices to the same one.
Another option if you’re still struggling is using a third-party app like DoCast. It’s a pretty reliable app for smooth screen mirroring. You can download and install it from Official Docast App. This app often bypasses complicated setup issues and just works straight out of the box for many users.
Remember, screen mirroring works better if both devices have strong, consistent Wi-Fi signals. So avoid areas with poor reception. Give it a shot and holler back if it still doesn’t work!
First off, codecrafter has covered the basics really well, but I’d just like to sprinkle in a few extra tips, especially if you’re still experiencing hiccups with your Onn Roku TV and phone mirroring combo.
  1. Check Your Router Settings: Sometimes your Wi-Fi router settings can mess things up, particularly if you have settings enabled like guest isolation or AP isolation. Head into your router’s admin panel (you usually get there by typing your router’s IP address into a browser) and make sure these settings are disabled. These settings can create different sub-networks that restrict devices from talking to each other.
  2. Update Your Roku Software: Honestly, old software can create hiccups. Go into SettingsSystemSystem Update on your Roku. Sometimes updates fix bugs and improve compatibility.
  3. Phone-Specific Troubleshooting:
    • Android: If your Android phone won’t find the Roku, try switching off options in the casting settings. Go to SettingsConnected devicesCast and flip the little three-dot menu in the corner, and make sure every box is checked. If needed, toggle Bluetooth off and on. Mirroring needs both Wi-Fi and Bluetooth sometimes.
    • iPhone: On iOS, sometimes it’s the Wi-Fi Assist that causes unnecessary switching between Wi-Fi and cellular data. Go to SettingsCellular → and scroll down to toggle off Wi-Fi Assist.
  4. Third-Party App Considerations: Another thing to try, if you’re still seeing no dice, is delving into third-party apps. One notorious app for seamless screen mirroring is DoCast. It’s a breeze to set up and often circumvents many of the quirks we’re talking about. Not perfect, but for iOS users, download it from this link to just get right to the action.
  5. Reduce Wi-Fi Congestion: If you have a lot of Wi-Fi gadgets fighting for bandwidth (smart doorbells, IP cameras, robot vacuums), consider reducing their activity or temporarily disabling them to test. Use the 5GHz band if possible, which typically is less congested and delivers better performance.
  6. Device Reboot Sequence: Unconventional but sometimes effective, try this reboot sequence:
    • Power down the TV and unplug it completely for 2 mins.
    • Restart your phone.
    • After two minutes, plug the TV back in and boot up again like normal.
  7. Roku App for Wireless Convenience: If all else fails, while this might not be screen mirroring per se, you can always use the Roku app from the App Store or Play Store. Use it for streaming personal media from your phone onto the TV. This can be a temporary halfway measure if you’re desperate to display photos or videos without full mirroring.
  8. Check for Interference: Microwave ovens, cordless phones, and other devices can interfere with Wi-Fi signals. If you face persistent issues, try performing the screen mirroring process closer to your router or experiment by turning off potential interfering devices.
Ultimately, you have some solid failsafe options. If you’re really stuck, definitely give the DoCast app a whirl. It’s honestly saved my setup more than once and given me less headache overall. The native Roku mirroring capabilities are great when they work, but having a reliable fallback like DoCast can be a game-changer.
Let me know what worked (or still doesn’t) for you!
Honestly, it blows my mind that Roku’s still such a hit-or-miss deal with screen mirroring. Yeah, @codecrafter and @byteguru have laid down some solid groundwork, but can we talk about the elephant in the room? Compatibility issues seem to lurk around every corner, no matter how many boxes you tick or networks you sync.
One thing I noticed, not mentioned, is the input lag. Even when it does work, there’s often an annoying delay—especially for gaming or real-time apps. Roku’s native solution just doesn’t cut it for high-demand tasks. It’s okay for showing off a few vacation pics, but anything beyond that and you’re skating on thin ice.
And speaking of third-party solutions, sure, @codecrafter threw in DoCast, but while it works, it’s not all sunshine and rainbows. Occasionally, it craps out during extended usage, especially with certain Android models. Plus, it’s not exactly free, which is a bummer considering what this basic functionality should be. But I guess it does get the job done better than most.
Still, it’s worth mentioning a few alternatives like AllCast or even Google’s own Chromecast for simplicity. These options, while not perfect, usually offer more consistent experiences without diving into the Roku black hole of troubleshooting.
In short, Roku’s screen mirroring is a gamble. If you must go third-party, DoCast isn’t too bad, but don’t expect it to be flawless. Don’t shortchange your expectations; tinkering with router settings and dancing around Wi-Fi interference sometimes feels like a prerequisite for the simplest operations on a Roku.
Skip mirroring. Use the Roku app as a remote media sender.
  1. Install the official Roku app on your phone.
  2. Connect your phone and Onn Roku TV to the same Wi Fi.
  3. Open the Roku app, select your TV.
  4. Tap Photos+ or Media.
  5. Pick photos, videos, or music from your phone, then play to the TV.
This avoids lag, works on most phones, and stays more stable than live mirroring.
