How do I stream from my iPhone to a Fire Stick?
I’m trying to stream videos from my iPhone to my Amazon Fire Stick, but I’m not sure how to get started. I don’t see any option to mirror my iPhone on the Fire Stick. Has anyone successfully done this? What apps or methods do you recommend? Appreciate any tips!
Hey, you’re not alone in this. Many people have struggled with streaming from iPhone to Fire Stick since they aren’t directly compatible out of the box. But don’t worry, it’s totally possible! Here are a few ways to do it:
  1. DoCast App: This one is a life-saver. You can download the DoCast Screen Mirroring app on your iPhone. Install it from Official DoCast App. Once installed, open it and follow the instructions to connect with your Fire Stick. It’s user-friendly and gets the job done without much hassle.
  2. AirScreen App: If you’re looking for alternatives, check out the AirScreen app available in the Amazon Appstore. It basically turns your Fire Stick into an AirPlay receiver. Install AirScreen on your Fire Stick, then open Control Center on your iPhone, select Screen Mirroring, and pick your Fire Stick from the list. Easy peasy!
  3. Amazon Silk Browser & VLC: For more hands-on methods, if you have local files, the Amazon Silk web browser and VLC media player can help. Upload your videos to a service like Google Drive or Dropbox, open the browser on your Fire Stick, and stream from there. Or simply use VLC to play almost any video format.
One thing to note: make sure your iPhone and Fire Stick are on the same Wi-Fi network.
Give it a whirl! I’ve had success using the DoCast app, but experimentation is part of the fun. Good luck!
Using your iPhone to stream videos to an Amazon Fire Stick can be tricky since the devices aren’t natively compatible for screen mirroring. While methods like the DoCast and AirScreen apps mentioned by @codecrafter are popular, I’d like to offer you additional alternatives that could align better with specific use cases or preferences.
  1. AirPlay Compatible Apps: Some apps on the Fire Stick can natively receive AirPlay streams without additional software. For instance, apps like Reflector and AllConnect can act as AirPlay receivers. After installing the app on your Fire Stick, go to your iPhone’s Control Center, select Screen Mirroring, and choose the respective app.
  2. Setting up AllConnect: One less-talked-about but quite effective app is AllConnect.
    • Download AllConnect from the App Store on your iPhone.
    • Also, get AllConnect for the Fire Stick from Amazon Appstore.
    • Open both apps, follow the prompts, and ensure they’re on the same Wi-Fi network.
    • You can stream photos, videos, and music from your iPhone effortlessly.
  3. Plex Media Server: If you’re tech-savvy and primarily streaming local content, setting up Plex could be an intriguing option:
    • On your computer, install Plex Media Server and add your media library to it.
    • Install the Plex app on both your Fire Stick and your iPhone.
    • Log in with the same Plex account and ensure the devices are on the same network.
    • Use your iPhone to stream content via Plex to your Fire Stick.
  4. Kodi with UPnP: For the highly technical and DIY-minded, using Kodi can open up a world of possibilities.
    • Install Kodi on your Fire Stick and enable its UPnP/DLNA feature.
    • Use an app like MCPlayer HD on your iPhone.
    • This method is great if you are into customizing your streaming experience and utilizing NAS or local servers.
There’s a caveat—using third-party streaming or screen mirroring apps might sometimes result in varying degrees of performance, especially wrt buffer times or resolution. Furthermore, security and privacy concerns can arise with some lesser-known apps, so make sure the app has good reviews and proper security features.
Lastly, as far as using DoCast is concerned, it’s a genuinely effective solution for iOS users:
  • Install DoCast from Download Docast on Appstore.
  • Open DoCast on your iPhone and follow on-screen instructions to connect it with your Fire Stick.
  • The visual and audio sync is usually seamless, but the experience might differ based on your network stability.
While it’s important to explore and find what works best for you, keeping an open mind to various methods and apps can save you tonnes of time. You might have to cycle through a few apps and configurations to find the perfect setup, but the result is a smooth and effective stream from your iOS device to your Fire Stick.
Any method you choose will likely involve some trial and error, but don’t be discouraged. Streaming from your iPhone to Fire Stick, while not perfect, is certainly achievable with the right tools and a bit of patience. Consider spending a bit of time in practicing using each method to find the one that aligns best with your regular usage.
Seriously, streaming from iPhone to Fire Stick is more hassle than it’s worth. I’ve tried almost every method mentioned so far, and they all have quirks. DoCast seems okay but you’ll notice lag if your Wi-Fi isn’t strong enough. Not to mention, it’s not free!
AirScreen, AllConnect, and even Plex—good luck getting them to work flawlessly. They might work once or twice, but consistency is painful. For Plex, setting up a server just to stream from your phone feels overkill.
No offense, but are you all masochists? Just get an Apple TV. Way less headache and it works every time without having to fiddle with third-party apps or sketchy workarounds. I’m out.
