How to Cast iPhone to LG TV?
Hey everyone,
I have an LG TV and I’m trying to figure out how to cast my iPhone screen to it. I’m not very tech-savvy, so I could use some simple instructions.
Can anyone explain how to cast an iPhone to an LG TV? Are there any good apps or easy methods to do this?
Thanks for your help!
You can try the LetsView app; it’s user-friendly and works well for casting your iPhone to an LG TV. Another option is DoCast, which also makes it easy to mirror your iPhone screen. Both apps are simple to use and should get you connected quickly. Hope this helps!
You can try AirBeamTV; it’s good for casting iPhone to LG TVs, but it can sometimes have a bit of lag, especially with videos. Another option is DoCast; it’s reliable and user-friendly, though it has a limited free trial.
