How to cast my iPhone to my TCL TV?
I’m struggling to cast my iPhone to my TCL TV. I have tried using different apps and settings, but nothing seems to work. Any advice on how to make this work would be greatly appreciated. Need help ASAP!
To cast your iPhone to your TCL TV, it depends on the type of TCL TV you have — Roku TV, Google TV, or Android TV. Here are your best options:
If your TCL TV supports AirPlay (some Roku and Android models do):
  1. Connect both your iPhone and TV to the same Wi-Fi network.
  2. On the TV, enable AirPlay:
  • For Roku TVs: go to Settings → Apple AirPlay and HomeKit → Turn AirPlay ON.
  • For Android/Google TVs: some may support AirScreen (you’ll need to install this).
  1. On your iPhone, open Control Center → tap Screen Mirroring.
  2. Select your TCL TV from the list.
If AirPlay is not supported, try these alternatives:
If you’re still hitting a wall, let me suggest an app that might get you sorted fast: the DoCast app. It’s designed specifically for screen mirroring from iPhone to TV, including TCL TVs, and tends to iron out most of the common issues.
  1. Download DoCast from the App Store.
  2. Make sure both devices are on the same Wi-Fi.
  3. Open DoCast, let it detect your TV (it works with Roku, Fire, and Android TVs).
  4. Choose Screen Mirroring, or cast specific content (photos, videos, etc.).
Use a Lightning to HDMI adapter:
  1. Plug the Lightning Digital AV Adapter into your iPhone.
  2. Connect the adapter to the TV via HDMI.
  3. Switch your TV input to the correct HDMI port.
  4. Your iPhone screen should instantly appear on the TV.
Hope this helps to cast and mirror your iPhone to a TCL TV! Enjoy!
Hey, sounds like a bit of a headache you’re dealing with :grimacing:. Here’s another angle you might wanna try out.
First off, make sure your iPhone and TCL TV are on the same Wi-Fi network. Seems basic, but it’s a common trip-up.
Your TCL TV should ideally support AirPlay if it’s a newer model. To check:
  1. Go to “Settings” on your TCL TV.
  2. Navigate to “Network & Internet.”
  3. Look for AirPlay settings and turn it on if it’s not already.
Next, on your iPhone:
  1. Open the Control Center (swipe down from the upper-right on iPhone X or later, swipe up on earlier models).
  2. Tap on ‘Screen Mirroring.’
  3. Look for your TCL TV on the list and select it.
If AirPlay isn’t supported or it’s still not showing up, sometimes a good old reset helps. Restart your iPhone and TLC TV.
And hey, if these steps leave you banging your head, another good app option is the DoCast app like @viajantedoceu mentioned. It’s designed for screen mirroring and can cut through a lot of the nonsense:
  1. Download the DoCast app from the App Store.
  2. Follow the in-app instructions.
  3. Enable screen mirroring on your TV if needed through “Network” or “AirPlay” settings.
One last thing – make sure your TV’s firmware is up-to-date. Check for updates under the settings. If there’s any lag between your devices, firmware might be the culprit.
For a detailed run-down on the steps, you can check out this guide on how to cast from your iPhone to a TCL TV. It covers various ways to get your screen up and running.
Hope one of these does the trick!
Alright, let’s get rolling! Actually, let’s take a different approach here. While the DoCast app does seem like a solid option, sometimes it’s better to keep things native.
Minimalist Style:
On your TCL TV, check for AirPlay settings and make sure they’re enabled. To do this:
  1. Navigate to “Settings” → “Network & Internet.”
  2. Look for AirPlay settings and toggle it on. Done.
Pros of DoCast:
  • Easy setup.
  • Broad TV compatibility.
Cons of DoCast:
  • May require in-app purchases.
  • Doesn’t work offline.
Alternatives:
Apple TV Device:
  • Apple TV connects seamlessly, acting as a bridge.
  • Just plug and play.
Troubleshooter’s Tone:
Still hitting a bump? Restart both devices. Maybe even check that firmware on your TCL.
Humorous Take:
‘Throwing stuff at the screen in frustration won’t help, but updating firmware just might!’ :arrows_counterclockwise:
Mix it up as needed. Good luck! :four_leaf_clover:
