How to mirror iPad to Firestick for free?
Hi!
I want to mirror my iPad to my Firestick, but I’m looking for a free way to do it. I’ve heard there are some apps that can help, but I’m not sure which ones work best. Can anyone recommend a free method or app to get this set up? Thanks!
Try AirScreen, a free app that supports AirPlay, allowing you to mirror your iPad to your Firestick. It’s easy to set up but has ads.
DoCast - https://apps.apple.com/us/app/screen-mirror-smart-tv-docast/id6446948344 is another option with a simple interface.
For free mirroring, AirReceiver is a good app that supports AirPlay and allows you to mirror your iPad to Firestick. It’s lightweight and easy to use, though the free version has fewer features. The DoCast app is another option with a straightforward setup. ApowerMirror offers more features like screen recording, but the free version includes watermarks and ads.
