How to screen mirror from iPad to TV?
Hey!
I’m looking to screen mirror from my iPad to my TV, but I’m not sure how to go about it. I know there are several methods to mirror the screen or stream content, but I’m a bit uncertain about which one is the best. Could someone guide me on how to set this up? Any recommendations for apps or step-by-step instructions would be really helpful. Thanks!
If your TV supports AirPlay technology, it’s quite simple to mirror your iPad using the Control Center. Here’s Apple’s guide
For non-AirPlay TVs, one option you can consider is the DoCast app, which is compatible with the iPad. DoCast provides a smooth mirroring experience, and I found it to be free of bugs during use. However, the free version of the app does have time limitations for screen mirroring.
Another app you might try is Screen Mirroring App: Smart TV, which also works well with the iPad but shares the same limitation on mirroring time in its free version.
I used the app Screen Mirroring - TV Cast Air, but sometimes there were connection issues. Now, I use DoCast, and everything is fine. The only downside is that the free version of the app has a 15-minute mirroring time limit, but overall, I’m satisfied. You can also connect your iPad to the TV via cable: Use AirPlay to stream video or mirror the screen of your iPhone or iPad - Apple Support.
