How to Use AirPlay on a Sony TV?
Hey everyone,
I have a Sony TV, and I want to use AirPlay to stream from my iPhone or iPad. I’m not very tech-savvy, so I need some simple instructions.
Can anyone explain how to use AirPlay on a Sony TV? Do I need to download any apps or change any settings? Any help would be appreciated!
Thanks in advance!
You can try the AirBeamTV app; it’s a popular choice for using AirPlay on Sony TVs, but it can sometimes have connection drops or lag. Another option is DoCast; it’s simple to use and works well for streaming from your iPhone or iPad, though the free version has limited features.
To use AirPlay on your Sony TV, you can try the AirBeamTV app. Here’s how: Download AirBeamTV on your TV. Open the app and follow the instructions to connect. On your iPhone/iPad, swipe down for Control Center and tap Screen Mirroring. Select your Sony TV. Cons: It might have occasional connection drops and some features require payment. Another option is the DoCast app: Install DoCast on your TV. Follow similar steps to connect and mirror. Cons: Sometimes, there’s a bit of lag, and it may need a strong Wi-Fi signal.
