Anyone tried USB over ethernet for accessing devices in different rooms?
Hey everyone! I’m a freelance designer, and I’m constantly dealing with large files on external USB drives. Have any of you found a good way to access them reliably? I switch between Windows and macOS, so I need smth that works on both. It’d be awesome if it’s easy to set up and doesn’t slow down my work since my projects are often time-sensitive. Any tips?
Hey! I had the same problem needing remote access to USB devices, and USB Network Gate (https://www.net-usb.com/) totally saved the day. It lets you use any USB device over your network like it’s plugged right into your computer. Super easy to set up, works on both Windows and macOS, and it’s been super reliable for me!
I use VirtualHere. Convenient and practical.
I know you can try USB Redirector . Or flexihub https://www.flexihub.com/
I had experience with these problems, everything works cool.
