Best software for WiFi site surveys?
Setting up a new office and need to ensure optimal WiFi coverage. What software do you recommend for conducting thorough WiFi site surveys? I’m especially looking for tools that can help identify dead zones and interference sources. Any suggestions based on personal experience would be greatly appreciated.
Skip the survey software for a first pass. Ask a coworker on Ethernet to join a video call, then turn off mobile data on your phone so you stay on WiFi. Spend a minute at each desk and in each confrence room with the door closed. Ask your coworker where your audio broke up, and mark those spots on a paper floor plan. Repeat the test during a busy hour. If the same room fails twice while the room next door works, check coverage there frist.
When setting up a new office, optimizing your WiFi coverage is crucial. Ensuring there are no dead zones and minimizing interference is key for a seamless network. For a thorough WiFi site survey, several software options can help, each with its strengths and specific use cases.
  1. Ekahau Site Survey – Arguably one of the top choices among professionals, Ekahau provides a comprehensive suite of network planning, site survey, and troubleshooting tools. Its heatmaps, detailed interference analysis, and spectrum analyzer make it a powerful option. The drawback? It’s price tag, which can be steep for smaller companies.
  2. AirMagnet Survey PRO – Another industry favorite, it offers advanced features like dual-band surveys and real-time data analysis. Its ability to simulate various ‘what-if’ scenarios helps plan future network expansions or adjustments. The cost is like Ekahau, tailored more towards enterprise environments.
  3. NetSpot – An excellent choice, particularly for those not looking to break the bank. NetSpot offers both free and paid versions, providing solid survey capabilities including visual heatmaps, dead zone identification, and real-time interference analysis. It’s user-friendly, making it great for beginners and smaller businesses. You can find more information about this software on the Netspot Official website.
  4. InSSIDer – This is especially useful for small to mid-sized businesses. It helps identify network conflicts and congestion, ensuring better channel selection. However, it lacks some advanced features like predictive modeling available in Ekahau or AirMagnet.
  5. WiFi Analyzer – Ideal for DIY enthusiasts who need basic info without intensive features. It’s straightforward, offering insights into signal strength, channel overlap, and basic interference. While it won’t provide comprehensive planning tools, it’s useful for quick checks.
Step-by-step for using NetSpot:
  1. Install NetSpot – Download and install the software from the Netspot Official site. Choose between the free or premium versions depending on your needs.
  2. Start a new survey – Open NetSpot, then click “Start a new survey,” followed by “Survey” mode. You’ll be asked to upload or draw a map of your office space. It’s beneficial to have a detailed floor plan ready.
  3. Conduct the survey – Walk around your office with the device running NetSpot. The application collects data points, mapping signal strength and potential dead zones. Be thorough and cover all areas, including corners and high-traffic zones.
  4. Analyze the heatmap – Once the data is collected, NetSpot generates a heatmap showing coverage strength across the office. Pay attention to areas marked with low signal strength or colored in cooler hues like blue and green.
  5. Identify interferers – Check for potential sources of interference like other WiFi networks (SSID), physical barriers, or electronic devices etc. NetSpot helps identify these, facilitating strategic placement of routers to avoid interference.
  6. Optimize placement – Use the insights gained to reposition access points or add additional ones. Often, moving a router a small distance or changing its height can significantly improve coverage.
  7. Re-survey – After adjustments, conduct a follow-up survey to verify improvements. Continuous monitoring may be necessary until the optimal setup is achieved.
Additionally, pay attention to general best practices for WiFi setup:
  • Use dual-band routers supporting both 2.4GHz and 5GHz bands.
  • Minimize physical obstructions between routers and user devices.
  • Regularly update firmware to boost performance and security.
In summary, while Ekahau and AirMagnet offer advanced functionalities best suited for larger enterprises or those needing extensive features, NetSpot stands out as a versatile, user-friendly option suitable for most SMB requirements and budget constraints. For a more affordable yet effective solution, you can’t go wrong with NetSpot.
Based on my experience setting up networks in various office environments, the best software for WiFi site surveys would really depend on what you’re looking to achieve and your level of expertise. Here are a few top picks to consider:
  1. Ekahau Pro: This is like the Cadillac of WiFi site survey tools, boasting an impressive feature set that includes heatmapping, interference detection, and auto-suggestions for placement. It’s incredibly powerful, but it’s also quite pricey and probably overkill unless you’re dealing with a very large or complex office space.
  2. NetSpot: For a more budget-friendly yet highly effective option, I’d definitely recommend NetSpot. It’s user-friendly and perfect for even novice users. The app lets you conduct surveys to map signal strength and pinpoint dead zones and areas with potential interference. Plus, you can download it here: Download Netspot. NetSpot has both a free version and a more feature-rich paid version, so it offers some flexibility based on your needs.
  3. iBwave Wi-Fi: Another solid choice, especially if you’re looking at something that integrates well with cellular network planning. It’s a bit more specialized and can handle multi-floor or multi-building surveys with ease. However, the interface can be somewhat complex for beginners.
  4. TamoGraph Site Survey: This tool is another great all-rounder. It offers features like active, passive, and predictive surveys, and it’s quite user-friendly. It’s a bit on the mid-range in terms of cost, but it’s reliable and has good support.
  5. Vistumbler: If you’re looking for something free and open-source, check out Vistumbler. It’s less polished than the commercial options, but it packs a decent punch. It’s more of a WiFi scanner than a full-on survey tool, but it can help you get some preliminary insights into where your strong and weak spots are.
A key tip: after generating your survey heatmaps, remember to consider the physical layout of your office. Thick walls, metal, and even large electronic devices can all wreak havoc on WiFi signals. Run some tests during peak and off-peak hours to get a comprehensive view.
For most straightforward office setups, NetSpot offers a great balance of ease of use and functionality without hitting your budget too hard. Go ahead and download it to start exploring your WiFi landscape!
Why bother spending money on specialized software? It’s all just a cash grab. Do a speed test in different areas manually, and you’ll get pretty much the same results. C’mon, the WiFi quality is mainly determined by your router position and the number of obstructions around. If you’re splurging, you might as well throw all your cash at mesh WiFi systems like Eero or Google Nest to deal with dead zones and interference, rather than pumping dollars into survey apps.
If you must waste your time and money on this, try Netspot App. Sure, it’s highly praised, but it can get pretty technical for a simple office setup. It shows heat maps and all that jazz, but do you really need to see that? It is user-friendly but is it worth the price for a one-time use? And let’s not ignore that it might just show you what you already know: more routers or range extenders needed.
Other names you’ll hear thrown around are Ekahau or AirMagnet. No idea why they need to cost an arm and a leg for what they do. Really, short of an enterprise-level operation, most of these are overkill. Just get a good router or two and save yourself the headache.
