Best way to check WiFi signal strength?
I’ve been having issues with my internet connection lately and I suspect it’s due to weak WiFi signal. My Netflix keeps buffering and my video calls are really choppy. I want to know how I can check the WiFi signal strength to see if it’s the problem. Can anyone recommend a method or tool for accurately measuring it?
To check the WiFi signal strength effectively, there are several tools and techniques you can use that’ll help diagnose and address issues like buffering on Netflix and choppy video calls. Here’s a rundown:
  1. Router’s Admin Panel:
    Most modern routers come with a built-in admin panel you can access via a web browser. Type your router’s IP address (often something like 192.168.1.1) into your browser’s address bar and log in with your credentials. In the panel, there should be a section for WiFi status or signal strength. This is more technical and might require some digging, but it’ll give you specifics on signal quality.
  2. Built-in Tools on Your Device:
    • Windows:
      You can check WiFi signal strength right from your desktop. Click on the WiFi icon in the taskbar. The more bars you see, the stronger the signal.
    • MacOS:
      Hold down the Option key and click the WiFi icon in the menu bar. This will show you detailed information on your WiFi connection, including signal strength (measured in dBm). The closer the number is to 0, the better. For example, -30 is a strong signal, while -90 is very weak.
    • Smartphones/Tablets:
      Both Android and iOS have built-in indicators. On Android, go to Settings > WiFi and look at the signal strength. iOS is similar – just open Settings > WiFi.
  3. WiFi Analyzer Apps:
    There are numerous apps designed to assess and diagnose WiFi signal strength:
    • WiFi Analyzer (Android):
      This app provides a graphical view of your network’s signal strength over time, helping you understand changes in connection quality.
    • NetSpot:
      If you’re looking for a more comprehensive tool, consider NetSpot. It’s available for Mac and Windows and allows you to do a complete site survey, offering detailed insights into your WiFi signal strength throughout your home or office. You can download it from their official site – https://www.netspotapp.com.
  4. Using Command Line:
    • Windows:
      Open Command Prompt and type netsh wlan show interfaces. Look for the ‘Signal’ field which will show the signal strength as a percentage.
    • MacOS and Linux:
      You can open the Terminal and type iwconfig. This will show you various details including signal level.
  5. Hardware Tools:
    For a more precise assessment, you could use a WiFi signal meter. These are handheld devices that can give you a detailed reading of signal strength. They’re more commonly used by professionals but can be useful for a DIY approach.
  6. Optimizing Signal Strength:
    Once you’ve determined your signal strength, here are a few tips to boost it:
    • Router Placement:
      Place your router in a central location, elevate it off the floor, and ensure it’s not obstructed by walls or furniture.
    • Channel Switching:
      If you’re in a densely populated area, changing your WiFi channel can reduce interference. This can usually be done in the router’s admin panel.
    • Range Extenders and Mesh Networks:
      If certain areas of your home are persistently weak, consider a range extender or a mesh network to improve coverage.
Remember, the type of building materials and the layout of your home can significantly affect WiFi signal strength. Metal, concrete, and even some types of glass can weaken the signal. By using tools like NetSpot, you can create a visual heatmap of your signal strength and strategically place your router or extenders for optimal performance.
Totally agree with @byteguru on most fronts regarding WiFi signal strength. While the router admin panel and built-in OS tools are solid go-tos, they might be a bit tedious if you’re not tech-savvy. Detailed apps like WiFi Analyzer serve their purpose, but I found them a bit cluttered sometimes.
One angle not fully explored is using mesh networks. If you’re dealing with thick walls or multiple floors, a single router—even with an ideal placement—can struggle. I’d recommend investing in a decent mesh system like Eero or Google Nest WiFi. They’re relatively plug-and-play and provide seamless coverage across larger homes. They can also show real-time signal strength through their respective apps.
Another potential game-changer is using Powerline Adapters. These nifty devices use your home’s electrical wiring to create a pseudo-wired network. Plug one adapter near your router and another where the signal is weak to get an Ethernet-like connection. Brands like TP-Link AV2000 can deliver impressive results.
For those who like detail, you’re not wrong in turning to NetSpot for comprehensive WiFi analysis. It’s quite user-friendly and graphically presents your signal strength across different parts of your home or office. The heatmap feature is particularly fantastic for pinpointing dead zones. Although it’s powerful, some users might find it overkill if all they need is a quick check. Some competitors, like Acrylic WiFi Home, offer simplified signal visualizations but without the extensive site survey capabilities.
Sometimes the issues aren’t purely signal-based. Factors like outdated firmware or interference from other electronics can play a role. Make sure your router firmware is up-to-date and try switching off non-essential devices.
Before diving into gadget shopping sprees, another free tip: WiFi Channel Switcher. Jammed channels can mess with your signal. Head over to your router settings and find a less crowded channel manually. Modern routers might have an auto-selection, but manual tweaking sometimes yields better results. A WiFi channel scanner like inSSIDer can help identify the congestion levels on different channels.
And if you’re still having issues, consider a complete network reset. Power cycle your router and all connected devices. Sometimes, a simple reboot can clear out any technical cobwebs slowing down your connection.
Lastly, though it’s often overlooked, check your ISP’s Performance. WiFi signal strength can’t compensate for a sluggish internet plan. Run a few speed tests at different times of the day to see if your service speeds match what you’re paying for. Sometimes, buffering and choppy calls are just due to bad service rather than weak WiFi. If the ISP is the bottleneck, no amount of WiFi tweaking will fix that.
Hope these extra tidbits help! Just remember, a solid connection often requires a combo of good hardware, strategic placement, and a bit of tech tinkering.
I see you’ve gotten some great advice from @techchizkid and @byteguru on checking WiFi signal strength, but I’ve got a few more tricks up my sleeve that might be useful. People often overlook some simpler, hands-on solutions, so let me offer a fresh angle.
Firstly, if you’re tech-averse or get overwhelmed by too many options, you might want to try something a bit more straightforward. While those thorough apps and built-in tools are fantastic, they can sometimes be a tad too much for just a quick check.
Simple Built-In Methods You Might’ve Missed
  • Smart TV or Streaming Device: Given you’re having Netflix issues, have you tried checking the network settings on your smart TV or streaming device? These often provide a signal strength indicator in their settings menus. A quick peek here can give you a general idea without diving into other devices or apps.
  • Gaming Consoles: If you have a gaming console, they also have WiFi settings that show signal strength. For instance, PS5 or Xbox Series X has easy-to-navigate settings where you can see how strong your connection is.
Mesh Network? Maybe, Maybe Not
I slightly disagree with @techchizkid about mesh networks being a one-size-fits-all solution. They are great, yes, but they can be pricey and might be overkill for smaller spaces. I’d recommend starting with simpler solutions like placing your current router in a more central location before splurging on mesh systems. If that fails, then maybe consider upgrading.
Cables Are Your Friend
Sometimes, a wired connection can solve things faster. If possible, use a long Ethernet cable to test if the buffering and choppy calls persist. If the issues go away, then you know for sure it’s a WiFi issue, not an ISP problem.
Consider the Environment
Have you thought about environmental factors like interference from other electronic gadgets? Microwaves, cordless phones, or even baby monitors can mess with your WiFi. If you’ve got these around, try moving them further from your router.
The Power of Simple Tweaks
  • Router Bands: Modern routers offer dual-band connections (2.4GHz and 5GHz). Sometimes the 5GHz band is less crowded, leading to better performance. Try switching bands on your devices.
  • Quality of Service (QoS): Some routers have QoS settings which allow you to prioritize certain types of traffic (like streaming or video calls). This can help ensure smoother performance for these activities. Look into your router’s settings - it might make a world of difference.
Mobile Hotspot Hack
Temporarily turn your phone into a hotspot and connect your TV to see if the buffering problem persists. This can help differentiate if the problem is with the WiFi router or your ISP.
Check with Your ISP
Sometimes, it’s not even the WiFi but your ISP’s fault. You mentioned Netflix buffering and choppy video calls – these could be more about internet speed rather than just WiFi signal strength. Run a speed test on both WiFi and a wired connection. If your speeds are consistently lower than what you’re paying for, give your ISP a call.
Advanced Analysis
If you’re into knowing more detailed info and you’re ready to spend some time analyzing, @byteguru’s mention of NetSpot is gold. It can provide a comprehensive overview of your WiFi environment and help you pinpoint exact weak spots in your home. Their site has a pretty straightforward download process if you’re curious – NetSpot Site Survey Software.
Wrapping Up
Don’t just rush into buying new equipment until you’ve fully diagnosed the problem. Sometimes, you might only need better placement or a few tweaks here and there. WiFi signal issues are annoying but often fixable with a bit of sleuth work.
