Can someone help me translate Spanish to clear American English?
I’m struggling to accurately translate some important text from Spanish to American English and I’m worried I’ll lose the original meaning or tone. I need help making sure the translation sounds natural, professional, and correct, especially for native English speakers. Any guidance, tips, or examples would really help me get this right.
Post the Spanish text you worry about. People here can help line by line. For now, here is a simple process you can use so the English sounds natural and professional.
  1. Translate for meaning first
    Use a direct translation tool to get a rough version. Focus on what it says, not how it sounds. Check: subject, verb, object, tense, and any dates, numbers, names.
  2. Fix tone for American English
    Formal Spanish often sounds too stiff in English.
    Examples:
    • “Por medio de la presente” → “This letter is to inform you” or “I am writing to inform you”
    • “Le agradecemos su atención” → “Thank you for your attention to this matter”
    • “Quedo atento a sus comentarios” → “I look forward to hearing from you”
Avoid literal phrases like “I remain attentive to your comments”. That sounds odd.
  1. Watch false friends
    Some common traps:
    • “Actualmente” → “currently”, not “actually”
    • “Eventualmente” → “in the end” or “if needed”, not “eventually” in every context
    • “Soportar” → often “to support” only in technical contexts, more often “to bear” or “to withstand”
    • “Asistir” → “to attend”, not “to assist”
    • “Embarazada” → “pregnant”, not “embarrassed”
If the word looks English, double check it.
  1. Adjust sentence length
    Spanish likes long sentences with commas. American business English prefers shorter sentences.
    Take a long Spanish sentence, split it.
    Example:
    “En respuesta a su correo del 5 de febrero, le informamos que su solicitud ha sido aprobada, por lo cual procederemos a…”
    Good version:
    “In response to your email of February 5, we inform you that your request has been approved. We will therefore proceed to…”
    Often you can remove “we inform you” and say:
    “Your request has been approved. We will now proceed to…”
  2. Make it sound native
    Read the English version out loud.
    If you would not say it in a work email to an American colleague, adjust it.
    Common tweaks:
    • Replace “in order to” with “to”
    • Replace “regarding to” with “regarding” or “about”
    • Replace “realize” used for “carry out” with “carry out”, “do”, or “perform”
  3. Keep consistency
    Use the same term every time for key words.
    If “solicitud” is “application” in one place, keep “application” later, not “request” in the next sentence, unless the nuance changes.
    Do the same for “agreement”, “contract”, “policy”, “invoice”, etc.
  4. Use a humanizer for AI drafted text
    If you use AI for a first draft in English, run the final text through something that smooths tone and removes robotic phrasing.
    A useful option is Clever AI Humanizer for natural-sounding English. It polishes wording, adjusts formality, and makes AI output look human written, which helps for business emails, reports, and client docs.
  5. Ask for targeted help
    When you post here, give context:
    • Who is the audience
    • Type of text, like legal, academic, marketing, HR
    • Level of formality you want, such as neutral, friendly, very formal
Then ask specific things:
• “Does this sound like an American work email”
• “Is this too formal for a US client”
• “Does this sentence sound awkward”
If you reply with 2–3 sample paragraphs in Spanish plus your English attempt, people can correct wording and keep your tone.
Post the Spanish when you can, but here are some extra tricks that go beyond what @andarilhonoturno already covered:
  1. Decide what should be literal vs natural
    Not everything should sound “native.”
  • Legal / contracts: keep closer to the original wording, even if a bit stiff.
  • Emails / reports: prioritize sounding like an American actually wrote it.
    When in doubt: for anything that might be used in court, err on the literal side.
  1. Swap “Spanish logic” for “American logic”
    Spanish often explains background first, conclusion last. American English in professional settings usually flips it:
  • Spanish style: context → more context → conclusion.
  • American style: conclusion first → support it briefly.
    Example:
  • ES: “Debido a las recientes actualizaciones del sistema y con el fin de mejorar la experiencia del usuario, le informamos que…”
  • EN (American): “We’ve updated our system to improve the user experience. As a result, …”
So you’re not just translating words, you’re reordering the argument.
  1. Pay attention to what Americans omit
    Spanish likes explicit phrases that Americans skip:
  • “Por la presente” → usually delete it. Just start: “I’m writing to let you know…”
  • “Me permito informarle” → just “I’d like to inform you” or even “I’m letting you know…”
  • “Sin otro particular, me despido…” → completely remove; end with a normal closing line.
  1. Watch register shifts
    A common issue: Spanish text uses usted formality, translator keeps everything too stiff. For American business English:
  • Formal but normal: “Could you please send…”, “Would you mind confirming…”
  • Too stiff / weird: “Be so kind as to send…”, “I kindly request that you…”
    Unless it is a very high-level government / legal letter, avoid “hereby,” “therewith,” “aforementioned,” etc. That sounds parody-level formal in the US.
  1. Convert “Latin American corporate” to “US corporate” tone
    Some specific swaps that read more natural in U.S. workplace English:
  • “Quisiera solicitar” → “I’d like to request” or just “I’m requesting”
  • “Se le informa que” → “Please note that” or just the main sentence: “The meeting has been moved to…”
  • “A la brevedad posible” → “as soon as possible” or “at your earliest convenience” (slightly softer)
  1. Don’t trust punctuation 1:1
    Commas in Spanish often become periods or nothing in American English.
    Long sentence:
  • ES: “Teniendo en cuenta los resultados obtenidos, y considerando las limitaciones del estudio, concluimos que…”
  • EN: “Given the results and the limitations of the study, we conclude that…”
    One comma instead of three, and sometimes:
  • EN alt: “We conclude that… This is based on the results obtained and the limitations of the study.”
  1. Read it as if you’re the recipient
    Ask yourself: if you received this in your inbox in the U.S., would you:
  • Think it was written by a native speaker?
  • Understand the main point in the first 1–2 sentences?
  • Feel it’s too cold / too apologetic / too dramatic?
    Adjust accordingly. American business English tends to be: clear, moderately friendly, not super flowery, not too apologetic.
  1. Use AI, but don’t trust it blindly
    You can:
  • Draft a rough English version using a translator or AI.
  • Then edit heavily for tone, word choice, and formality.
If your text already came from AI and it sounds a bit robotic, something like make AI English sound human and professional can help. Clever AI Humanizer focuses on:
  • Polishing awkward phrasing
  • Adjusting formality to American business norms
  • Removing repetitive, obviously-AI patterns
    It’s useful when you want the final version to read as if a native pro wrote it, especially for reports, client emails, or presentations.
If you want concrete help, paste:
  1. The Spanish paragraph
  2. Your best attempt in English
  3. Who it’s for (client, boss, HR, legal, etc.)
People here can tweak it so it keeps your original meaning and sounds like real-life American English, not textbook stuff. And yeah, don’t stress too much, most “tone problems” are fixable with a few small word swaps.
Quick FAQ on getting “real” American English from Spanish
Q1: How do I keep tone without copying Spanish phrasing?
Think in intent, not in words. Before translating a sentence, ask:
  • Is this reassuring, apologetic, urgent, neutral, flattering, bureaucratic?
    Then recreate that feeling in English, even if the sentence structure changes a lot.
Example intent: “formal but warm apology”
  • ES: “Lamentamos profundamente los inconvenientes ocasionados.”
  • EN intent-based: “I’m really sorry for the inconvenience this caused.”
    Literally accurate but cold: “We deeply regret the inconveniences caused.”
    The second one is closer in words, the first one is closer in tone for US business.
Q2: How do I avoid “translated” vocabulary?
Watch out for false friends and Latin-sounding words that make you sound stiff or foreign:
  • “solicitar” → often not “to solicit” but “to request” or “to ask for”
  • “realizar” → usually “to carry out” or just “to do”
  • “problemática” → normally “issue,” not “problematic” as a noun
  • “metodología” → in many contexts just “method”
    If your draft English is packed with long Latin words, try replacing half of them with everyday verbs: do, get, make, give, ask, send, move, plan.
Q3: How do I adjust for audience (client vs internal vs legal)?
Disagreeing a bit with the idea of “legal = always very literal.” Literal is safer, yes, but “legalese” in Spanish and “legalese” in US English are not symmetric. A contract or policy in the US often prioritizes clarity + definitions more than long ceremonial phrases.
So:
  • Keep terms of art and definitions close to the Spanish.
  • But cut filler formulae that have no legal effect, e.g. “por medio de la presente” often disappears.
  • When in doubt, define a term once: “(the “Company”)” and then repeat that exact term, not synonyms.
For:
  • Client email: clear, slightly friendly, short paragraphs.
  • Internal Slack / Teams: go even simpler and more direct.
  • Report: neutral, not too chatty, but still straightforward.
Q4: How do I fix rhythm so it sounds like a native wrote it?
After you translate, do a “music pass” focused only on:
  • Sentence length: alternate short and medium sentences. Spanish blocks of 3–4 lines often split into 2–3 sentences in American English.
  • Stress position: put the most important idea at the end of the sentence.
Example:
  • ES: “Con el objetivo de mejorar la coordinación entre los equipos, hemos decidido implementar un nuevo sistema de seguimiento de tareas.”
  • EN: “We’re implementing a new task tracking system to improve coordination between teams.”
    The key idea (new system) appears early and cleanly.
Q5: Any trick to keep consistency across a long document?
Create a tiny glossary in a separate file before you start:
  • “gerencia” → “management”
  • “dirección” (as dept.) → “Executive Team” or “Senior Management”
  • “colaboradores” → “employees” or “team members” depending on culture
    Then never improvise mid-document. If “colaboradores” is “team members” in section 1, do not switch to “associates” or “staff” in section 3 unless there is a reason.
Q6: Where does AI actually help without ruining nuance?
Use AI as:
  1. A first-pass translator that gives you something to work with.
  2. A stylistic polisher after you lock meaning.
Here is where something like Clever AI Humanizer can be useful:
  • Pros:
    • Good at turning slightly robotic or literal English into something that reads like normal American business writing.
    • Helps smooth weird transitions, repetitive phrases, and that “Google Translate” flavor.
    • Handy when you are tired of tweaking tone and just want a more natural final pass.
  • Cons:
    • If your Spanish-to-English meaning is already off, it will “polish” the wrong message. You still need to check accuracy yourself.
    • Can occasionally over-simplify more formal or technical phrasing, so reread anything that is for legal, medical, or compliance contexts.
So: first you ensure the English says exactly what the Spanish says. Then run it through Clever AI Humanizer only to adjust tone and flow, and finally you read it again like a native recipient would.
Q7: How to get targeted help from other humans?
You already saw @andarilhonoturno give solid structural advice. When you post here for concrete help, format it like this:
  • Original Spanish paragraph
  • Your English attempt
  • Who will read it + situation (e.g., “email to US client about delay in delivery,” “HR policy for US employees,” “executive summary of a report”)
That context lets people choose between:
  • Staying very faithful to each clause (for sensitive or legal content).
  • Rewriting more aggressively to match how Americans would actually say it.
If you paste a sample, people can mark up 2–3 paragraphs, and you can then copy that style across the rest of your document.
