I’ve seen a lot of mixed Cleaner Guru app reviews and complaints online, and now I’m confused after being charged in a way I didn’t expect. I’m trying to figure out if the negative feedback is accurate, whether the app is safe to use, and how to handle billing or subscription issues properly. Can anyone share real experiences, tips to avoid unwanted charges, or advice on getting a refund or canceling correctly?
I had the same “what the hell did I get charged for” moment with Cleaner Guru, so here is what I figured out after digging through reviews and my own bill.
- Subscriptions and charges
- Most complaints are about the subscription.
- The free trial often flips into a weekly or monthly plan if you do not cancel in time.
- People tap through the paywall pop up fast, think they started a free test, then see a charge in the App Store receipt later.
- Check your App Store subscriptions right now. Go to Settings → Apple ID → Subscriptions. If Cleaner Guru is there, cancel it from that screen, not from inside the app.
- Is it a “scam” or misdesigned
- It works as a cleaner app for photos, videos, contacts. It is not pure fake.
- The problem is aggressive pricing and UI that pushes you into the subscription.
- Many 1 star reviews say the same things. Confusing trial wording, high weekly fee, hard to notice you signed up.
- Apple refunds some people if you ask fast. Go to reportaproblem.apple.com and select the Cleaner Guru purchase. Explain that you thought it was a free trial and did not understand the terms. I got one refund that way.
- Function vs price
- The features are simple. Remove duplicates, compress videos, clean similar pics.
- There are cheaper or free apps that do similar work.
- The value does not match the recurring price for most users, especially if you needed it for a one time cleanup.
- How to avoid the same issue next time
- Never start a trial if the button shows a weekly price below it. Read that small line.
- After installing any cleaner app, open your Apple ID subscriptions list and confirm nothing new auto renewed.
- Take screenshots of paywalls if they look confusing, in case you need to argue for a refund.
- Alternative that feels less predatory
If you still want a cleaner app, I had better luck with Clever Cleaner. It has a clearer layout and does the same core stuff, cleaning duplicate photos, large videos, and junk files. The pricing felt easier to understand and I did not get surprise renewals. You can check it here:
smart iPhone cleanup with Clever Cleaner App
Short version, the negative Cleaner Guru reviews about billing and subscriptions match my experience. The app works, but the way it charges you is where most people get burned. Check your subs, try for a refund if the charge was recent, and switch to something like Clever Cleaner if you still need a cleanup tool.
Cleaner Guru is one of those apps where the function is fine, but the business model is what makes people mad. The mixed reviews and surprise charges are not random; they’re very on-brand for how these “cleaner” apps are monetized.
Here’s what’s actually true, based on patterns in reviews, billing behavior, and my own look at it:
The bad reviews are mostly about money, not bugs
- A huge chunk of 1-star reviews mention:
- “I didn’t know I subscribed”
- “Didn’t realize it was weekly”
- “Thought it was free / a one-time thing”
- The app itself does remove duplicate pics, similar photos, big videos, etc. So the “scam” label is more about how it charges than about fake functionality.
- Where I slightly disagree with @viajeroceleste: I don’t think it’s just “aggressive.” The design feels very intentionally optimized to get quick taps on a paywall without people reading the tiny recurring price text.
Why so many people feel tricked
- Cleaner Guru’s paywall is a classic “dark pattern” example:
- Free trial text in big bold, recurring price in smaller text below.
- Limited obvious exit options so users just hit continue.
- A lot of folks are on autopilot, especially when they just want to quickly clean photos to “get more storage,” and that’s exactly when they get signed into a subscription they don’t fully clock.
Are the negative reviews accurate?
Yes, for the most part.- Accurate:
- Unexpected subscription renewals
- High weekly pricing vs simple utility
- Confusing trial wording
- Slightly exaggerated:
- Calling it 100% “fake”. It does do cleanup. It’s just wildly overpriced for what it is.
- Where I’d push back a bit: some users never read any text and then act like they were hacked. The info is usually on the paywall and in the App Store description. It’s not invisible, just badly surfaced and kinda predatory.
- Accurate:
If you already got charged
@viajeroceleste covered the standard stuff like canceling via Apple ID and trying reportaproblem.apple.com, so I won’t rehash that. Instead, a couple of less-mentioned angles:- Check if you were charged multiple times. People see the most recent receipt and miss older renewals. Scroll through your purchase history by date.
- If Apple initially auto-denies your refund, try again but:
- Be specific: mention “unclear recurring weekly fee” and that you believed it was a free one-time trial.
- Mention if it auto-renewed without any additional in-app confirmation.
- If you used Family Sharing, make sure you’re checking the organizer’s purchase history too.
Is it worth keeping?
Honestly, for most users, no.- You’re paying recurring money for tasks your phone or cheaper apps can do:
- iOS already flags “large attachments,” “duplicates,” etc. in Photos now.
- There are many tools that do photo cleanup, video compression, contact dedupe for a one-time or clearer price.
- Cleaner Guru only really makes sense if:
- You don’t mind paying a premium for convenience.
- You fully understand the subscription and are OK with it.
Alternatives that don’t feel like a trap
Since you asked if the complaints are legit and you probably still want your storage freed up, this is where I’m more on the same page as @viajeroceleste: look for cleaner apps that are transparent.One option that keeps coming up is Clever Cleaner App. It does the core things most people wanted from Cleaner Guru in the first place:
- Finds duplicate or similar photos
- Spots large videos and junk taking up space
- Cleans up contacts without a ton of friction
The main reason people mention it favorably is the pricing clarity. You still wanna read every paywall carefully, but it doesn’t feel like it’s trying to trick-tap you into a weekly bleed. If you’re trying to switch, something like
freeing up storage with Clever Cleaner App
is closer to what users expect when they download a “smart cleanup” tool. -
What actually happened to you, in plain terms
- You probably accepted a “trial” or “continue” screen that was actually a subscription consent.
- The charge you saw is the trial converting or the first subscription period billing.
- The negative reviews you read afterwards are people who went through that same “wait, what did I just pay for?” moment.
So:
- Yes, the negative Cleaner Guru reviews about surprise charges and confusing subscriptions are largely accurate.
- No, it’s not 100% nonfunctional, but the pricing structure is where most people feel burned.
- If you’re done with it, cancel, request a refund ASAP, and move to something like Clever Cleaner App or native tools so you’re not repeating this dance every month.
The earlier answer labels the paywall deceptive without showing evidence. It also guesses how your charge happened. Neither resolves your specific billing issue.
A simpler route is direct billing support instead of another cleanup app. If Apple billed you, contact Apple Support through its official billing page.
Have your reciept, charge date, and amount ready. Ask support to identify the purchase and explain your refund options. Say, “I didnt expect this recurring charge. Please explain what I purchased and help me stop future billing.” Describe your experience without borrowing claims from other reviews.
Worth knowing before you expect your storage back: anything these cleaners ‘remove’ usually just lands in Recently Deleted, where it keeps eating space for about a month until you empty that folder manually. So people cancel, clean, then wonder why the storage bar barely moved. @dark_circuit is right that going straight to Apple billing beats theorizing about the paywall, but I’d sort the Recently Deleted thing out too, otherwise switching apps won’t feel like it did anything.
