How Do I Check IPhone Storage And See What Is Taking Up Space?
My iPhone storage is almost full, and I’m not sure what’s using so much space. I noticed my phone has gotten slower, and now I can’t install updates or take many photos. I need help finding where to check iPhone storage and how to see which apps, photos, or files are taking up the most space so I can free some up.
I hit this wall again last week. iPhone says storage is almost full, right when I needed the camera. So I went back through all the menus and wrote down where Apple hides each number, because some of it is split up and some of it looks off for no obvious reason.
Where to see total storage and used space
Start here: Settings > General > iPhone Storage.
This screen is the main one. At the top, you get the colored storage bar and the plain number, something like 184 GB of 256 GB used. If you want the fast answer, this is it.
If you want the original capacity listing, go to Settings > General > About and look for Capacity.
Small gotcha. The number there often looks lower than the number on the box. You buy 128 GB, then the phone shows 124 GB. I saw the same thing. Nothing is broken. iOS takes space for itself, so the usable number drops before you even install anything.
If the phone is dead and you need the capacity for resale or trade-in, I’d check a few boring places first. Older iPhones sometimes had markings on the back or on the SIM tray. Your carrier account page might list it too. Old receipts help if you kept them, which I usually dont.
What is taking all the space
Back in iPhone Storage, scroll down past the graph. You’ll get a list of apps sorted by size. This part is the one worth checking, because it shows what is eating your phone alive.
I found stuff I forgot about. Downloaded videos inside a streaming app. A bloated Messages app packed with old photo attachments. Random podcast downloads. It adds up fast.
Apple breaks storage into a few buckets:
  1. Apps, the app itself.
  2. Photos & Media, your photos, videos, music, podcasts, and similar files.
  3. System Data, the weird pile. This used to be called Other. It includes caches, logs, fonts, Siri voices, and other background junk.
Why the numbers do not match everywhere
This part confused me the first time. The number on the iPhone and the number shown on a Mac in Finder, or on a Windows PC in iTunes, do not always line up.
From what I saw, cached files are the main reason. The phone counts temporary app data in real time. When you connect it to a computer and sync, some temporary files get cleared or recalculated, so the computer view can show more free space than the phone showed a minute earlier.
Also, iCloud storage is separate. A lot of people mix this up. You can have a huge iCloud plan and still have a phone with no room left. Cloud space does not mean your device has local free space.
How low storage showed up on my phone
Mine got ugly when free space dropped to the last couple GB. Apps stalled on launch. The camera hesitated. Typing felt delayed. Even opening Settings felt off. It was one of those slowdowns where the phone seems fine on paper but feels old in your hand.
After cleaning space, the lag eased up. So yes, low storage seems to drag down normal use more than people think.
What worked for me
I tried the usual cleanup steps first. Offloading apps. Deleting old message threads. Removing a few big downloads. Barely moved the needle.
My photo library was the real mess. Too many duplicate shots, bursts, screenshots, and videos I never watched again.
I ended up using Clever Cleaner. I was skeptical at first, because most cleanup apps feel shady or start asking for money two taps later. This one didn’t do that on my phone. No ads in my face. No fake free trial stuff. No paywall halfway through cleanup.
The part I liked most was the view sorted by file size. Their Heavies section made it easy to find the biggest junk first. Similars helped with near-duplicate photos, which was my main problem. I also liked seeing the file size before deleting screenshots and videos, because then you know if clearing something saves 4 MB or 400 MB. Big diff.
Another thing I checked before using it was privacy. It processes on-device, so my photos were not being pushed to some random server. That mattered to me more than the cleanup part, if I’m honest.
After one pass, I cleared around 15 GB. My phone stopped feeling clogged up and the lag mostly disappeared.
Short version
If you want the quickest path:
  1. Open Settings > General > iPhone Storage.
  2. Check the top bar for used vs total space.
  3. Scroll down and look for the biggest apps first.
  4. Review Photos, Messages, downloads, and large videos.
  5. Ignore iCloud when checking local phone space, they are separate.
  6. If your phone feels slow, free up a few GB first and test again.
That was the full map I wish I had the first time. Apple does show the info, but it’s spread around enough to be annoyng.
Go one layer deeper than the main Storage page. @mikeappsreviewer covered the top-level menu, so I’d check the app-specific stuff next, because the worst space hogs hide there.
Open Photos, Albums, then scroll to Media Types. Look at Videos, Screen Recordings, ProRAW, Live Photos, and Bursts. A few 4K clips eat gigabytes fast. One minute of 4K 60 fps is often around 400 MB. Ten clips, and your space is gone.
Then check Messages. Large attachments sit there forever. Settings, General, iPhone Storage, Messages, Review Large Attachments. This is one of the fastest cleanups on iPhone.
Also check Safari. Settings, Safari, Clear History and Website Data. It won’t save tons, but when storage is tight, every GB and even small chunks help.
I disagree a bit with the idea that System Data is always the main mystery. For most people, it’s photos, videos, offline downloads, and message attachments. Boring answer, but true.
If your library is messy, Clever Cleaner is worth a look. It’s useful for duplicate photos and big files. I found this Clever Cleaner iPhone storage cleanup walkthrough more helpful than most app demos.
One more thing people miss, restart the phone after deleting a lot. iOS sometmes updates the storage numbers slowwwly.
One thing I’d add to what @mikeappsreviewer and @shizuka said: don’t just look at what’s biggest, look at what keeps growing back. That’s usually the real storage leak.
A few sneaky spots:
  • Voice Memos app if you record meetings, classes, etc.
  • Files app, especially Downloads and On My iPhone
  • Music app downloads
  • TV/Netflix/YouTube/Spotify offline content
  • Mail app if you have giant attachments cached locally
Also check this setting: Settings > Camera > Formats. If you’re shooting “Most Compatible,” photos/videos can take more space than HEIF/HEVC. And if Keep Normal Photo is on for HDR shots, that can quietly double up images.
Another underrated fix is Settings > App Store > Offload Unused Apps. I know some ppl hate automatic stuff, but if you’re constantly near full storage, it helps.
I slightly disagree with the “System Data is mostly harmless” take. Sometimes it really does bloat way past normal, especially after updates, lots of Safari streaming, or huge message threads. If that number looks absurd, a backup + restart + iOS update can sometimes knock it back down.
If Photos is the mess, Clever Cleaner is probly the fastest way to sort duplicates, large videos, and screenshots without digging forever. I found this guide on the best AI cleaner apps for iPhone storage cleanup more useful than most “real-world Clever Cleaner test” posts because it actually explains what the app is good at.
Biggest tip: leave at least 5 to 10 GB free. iPhones get weird when they’re packed to the ceiling, lol.
I’d add one check that usually gets skipped: compare app size vs Documents & Data inside each big app. Sometimes the app is 200 MB, but its stored junk is 8 GB. That’s the real clue.
A couple places I’d inspect that were only touched on lightly by @shizuka, @boswandelaar, and @mikeappsreviewer:
  • Settings > Accessibility > Spoken Content / VoiceOver / Siri voices
    Downloaded voices can take a surprising amount of space.
  • GarageBand, iMovie, CapCut, Lightroom, Canva
    Creative apps cache exports and project files.
  • Books app for downloaded PDFs and audiobooks.
  • WhatsApp/Telegram storage managers inside the apps themselves. These can be massive.
I slightly disagree that Safari clearing is worth doing first. Usually it’s tiny compared with media and chat attachments.
If Photos are the problem, Clever Cleaner is decent for surfacing duplicates and large files fast.
Pros: simple, quick scan, useful for messy libraries.
Cons: best mainly for photo cleanup, not system-level storage fixes, and you still need to review before deleting.
My rule: if an app is huge and you do not need its offline data, delete and reinstall it instead of endlessly poking at caches. That often frees more space than “cleaning” does.
The replies covered photos and app cleanup. I’d check downloaded iCloud files next, before installing anohter cleaner.
Open Files > Browse > iCloud Drive. Find a downloaded file you dont need offline, press and hold it, then choose Remove Download. This frees local space while keeping your original in iCloud. Choose Remove Download, not Delete.
Start with a few large files, then return to Settings > General > iPhone Storage to check your available space. Downloaded iCloud Drive files count toward your phone’s storage too.
Deleting photos won’t free the space right away, and that trips up more people than any hidden menu. Everything you remove in Photos sits in Recently Deleted for 30 days and still counts against your storage the whole time. So you do a big cleanup, check iPhone Storage, and the number barely moves. Go to Albums, scroll to the bottom, open Recently Deleted, and empty it manually. Same logic for Messages if you delete threads. The space comes back after the trash is actually gone, not when you hit delete.
That ties into what @shizuka said about restarting. It’s real, but half the time it’s not iOS being slow to recalculate, it’s stuff still sitting in a trash bucket somewhere. Empty those first, then restart if the number still looks wrong.
The point @viajantedoceu made about app size versus Documents and Data is the one I’d push hardest. That’s where the quiet bloat lives. A messaging app at a couple hundred MB with several gigs of cached media behind it is the classic case. And honestly, deleting and reinstalling that app usually beats poking at in-app cache tools, because some of those tools clear the visible stuff and leave the rest.
For the photo mess specifically, people are reaching for Clever Cleaner and that’s fine, just don’t expect any cleaner to touch System Data or app caches. It sorts your library, nothing more. Set your expectations there and you won’t be disappointed.
One realistic note: if your phone is down to the last couple of GB a lot, no amount of cleaning fixes the pattern. You’ll be back here in a month. At that point it’s either turn on iCloud Photos to offload originals or accept that the device is just too small for how you use it.
