How do I get an APA book citation from an ISBN?
I pasted the ISBN into the citation field in our team’s workshop handout, but it just showed up as a string of digits on the references page. The number came from the back cover of the book we use for the discussion prompts. How do I use it to get the APA book citation that belongs on that page? I’m not sure what the lookup field would be called.
The ISBN goes in a book lookup field, not on the references page. It identifies the edition you’re citing, but it isn’t an APA reference by itself.
I’d paste the number from the back cover into the search box in the clever humanizer apa citation generator. Look for a field that accepts an ISBN. It can be the same box you’d use to search by title, so you don’t need a separate field labeled “ISBN lookup.”
Ensure that the author, title, year of publication, edition, and publisher match those presented on the copyright page. If so, replace the [numbers] in your handout with a complete APA reference. However, you should only include the in-text reference (author/year) in your text. Not in your References.
Your handout’s citation field sounds like plain text: it prints whatever you paste. I’d use the Clever Humanizer APA Citation Generator because it gives you both versions from the ISBN in one go. Paste the full entry under References and the short citation beside the discussion prompt.
You might get incorrect information using ISBN. If the question refers to a chapter within an edited text, then the data retrieved from ISBN will refer to the entire text. This means that ideas may be incorrectly attributed to the editor.
Look at the first page of the chapter. If there is an author for the chapter, but someone different is listed as the editor in the book, include a “chapter in an edited book” in your reference. Start by including the author of the chapter (from the chapter), date, chapter title, editor, book title, pages of chapter, and finally publisher. Include the author of the chapter in relation to the question.
If the author is the same in the chapter and book, or if the question refers to one chapter in the book, ignore the chapter. Simply include the standard book reference.
The book title may not be in italics in this field. The numbers in this field suggest that content has been directly copied in. It is, however, useful to consider how the information will be formatted.
Entire book
Search for the book in the library catalogue using the ISBN. Click on the relevant book, and click on the ‘Cite’ button. Select ‘APA’ if possible. Copy the citation (not the book description). The book title should appear in italics. Any edition information, for example (2 nd ed.) should directly follow the book title. It should be in standard font.
When pasting this information in the references section, check the handout preview. If the book title is in italics then you are fine. However, if the book title is in standard font and you do not have formatting options in the template, change the book title to italics in the editable handout and export the handout.
Different editions will have different ISBNs. Therefore, the same book published in hardback format, paperback format and a reprint will each have a unique ISBN. If you have borrowed a second-hand copy of the book for the workshop, and the ISBN you type in is for a different printing, then the date/edition shown by the generator may be inaccurate. Check that it matches the copyright page.
@swiftstream is right that an ISBN points at the whole volume, and that trips people up more than they expect. Edited collections are the usual trap, but textbooks with a general editor do it too. If the thing you’re actually quoting has its own named author on the chapter’s first page, the ISBN lookup will hand you the editor and you’ll end up crediting the wrong person. Check whose words you’re using, not just what the barcode says.
This tool is very useful as it can take this format of information quickly. Therefore, you do not need to remove any extra formatting in order to get the citation. If this number has been copied directly from the front cover, then this tool will provide a quick draft citation. However, it may be better to manually add the Publisher and date.
Include the page number if the quote is directly taken from the text. If paraphrasing information from the text, including the author and year is sufficient.
Confusion may occur in that in-text referencing may not be complete. Whilst the ISBN helps identify which text you are using, it will not indicate exactly which sentence from the text was used.
Look up the ISBN in the library database. Under Cite select the APA option. Copy the entire citation for the book into the printout field.
Once the desired sentence has been found in the book, include the page number in the abbreviated citation. Each prompt quoting different page numbers from the same source should include their respective page numbers. However, you only need to include one citation for this source under References.
