How do I mirror my iPhone to my Fire Stick?
I’m struggling to mirror my iPhone screen to my Fire Stick. I’ve tried using the AirPlay feature, but it doesn’t seem to connect. I’m stuck and need a way to stream my phone’s content to my TV. Any advice? Thanks!
Skip the Fire Stick and connect your iPhone directly to your TV with HDMI. If your iPhone has a Lightning port, use a Lightning Digital AV Adapter. If it has USB-C, check whether your model supports an external display before buying a USB-C to HDMI adapter.
Plug the adapter into your iPhone, then run an HDMI cable from the adapter to your TV. If you used HDMI 2, press Input on your TV remote and select HDMI 2. Your TV should show your iPhone screen without AirPlay or a mirroring app.
When it comes to mirroring your iPhone to a Fire Stick, it can be a bit of a hassle because iPhones offer AirPlay for screen mirroring, which is not natively supported on Fire Stick. To make this work, here’s a step-by-step guide to help you out.
First, you’re going to need a third-party app since the Fire Stick doesn’t support AirPlay directly. One reliable app for this purpose is the DoCast Screen Mirroring app. You can grab it from the App Store. Here’s the link: Download DoCast screen mirroring app on Appstore.
  1. Install the App on Your iPhone: Go to the App Store on your iPhone, search for “DoCast Screen Mirroring,” and install it.
  2. Download and Install the App on Your Fire Stick: Your Fire Stick will also need the app.
    • Go to your Fire Stick’s home screen.
    • Navigate to the search icon (:mag:) and type in the app name.
    • Select the app from the list and install it.
  3. Connect Both Devices to the Same Wi-Fi Network: This is crucial. Make sure both your iPhone and your Fire Stick are connected to the same Wi-Fi network.
  4. Open the DoCast App on Both Devices:
    • Launch the DoCast app on your iPhone.
    • Open the same app on your Fire Stick. You might need to allow some permissions; make sure to agree to all necessary prompts.
  5. Find Your Fire Stick on Your iPhone:
    • In the DoCast app on your iPhone, look for available devices and select your Fire Stick from the list.
  6. Start Mirroring:
    • Once you’ve selected your Fire Stick, the app should provide an option to start mirroring. Tap it and your iPhone screen should start showing up on your TV screen.
If this doesn’t work, make sure everything is updated. Sometimes the app might have issues if it’s not on the latest version, or if your Fire Stick needs a firmware update.
Another important thing to note is to disable any VPNs you might be using. VPNs can sometimes mess with the network configuration, making it harder for devices to communicate efficiently on the same local network.
I’ve found this method to be pretty reliable, but if you’re looking for alternative apps, some other ones might worth checking too:
  • AirScreen: Similar to DoCast, it also allows mirroring via AirPlay. Just install it on your Fire Stick by searching for “AirScreen” in the Fire Stick’s app section and following the same steps.
  • Reflector: This app works well but it does cost a bit of money. It’s a bit more polished and robust, but the free options should serve you well.
But honestly, DoCast is pretty straightforward and usually gets the job done without too much hassle. Give it a try with the steps above and you should be good to go!
Why even bother trying to mirror an iPhone to a Fire Stick? Apple and Amazon don’t play nice together. AirPlay isn’t going to work since it’s just not compatible with Fire Stick.
If you’re desperate, try some app like DoCast Screen Mirroring. But don’t get your hopes up, it might work but it’s not completely reliable. Crashes, lag, and annoying ads are too common. There’s also AirScreen or ApowerMirror which others rave about, but again, expect random issues.
Save yourself the frustration and get something like an Apple TV instead. At least then you won’t be wrestling with tech.
First off, AirPlay directly to a Fire Stick won’t work because Amazon’s Fire Stick doesn’t natively support AirPlay. Here’s what you can try instead.
Check out DoCast Screen Mirroring. It’s pretty straightforward. Get the app from the app store on your iPhone. Now, you need to download the DoCast app onto your Fire Stick. You can find it here: iPad & iPhone Cast to Roku, Chromecast, DLNA Smart TVs, and Fire TV. It’s basically like giving your Fire Stick some AirPlay powers.
Once both devices have the app installed, make sure they’re on the same Wi-Fi network. Open the DoCast app on both the Fire Stick and your iPhone. You’ll typically see your Fire Stick listed on your iPhone – just tap to start mirroring.
An alternative is using an HDMI adapter if you’re frustrated with apps. Plug it into your iPhone and then into your TV’s HDMI port. This is guaranteed but not wireless.
Lastly, you might find lag sometimes with wireless solutions depending on your Wi-Fi network, so if you experience that, the wired method is a no-brainer fix. Good luck!
