How Do I Recover Deleted Photos From An SD Card?
I accidentally deleted important photos from my SD card while moving files from my camera, and now I can’t find them anywhere. These pictures are really important, and I need help figuring out the best way to recover deleted photos from an SD card before anything gets overwritten.
I’ve been there. You delete a batch of photos, or the card gets formatted, and your stomach drops. First move, stop using the SD card right now. Take it out of the camera or phone and leave it alone.
Deleted photos usually are not erased on the spot. The card marks the space as free, and new files take over it later. If you kept shooting after the mistake, recovery gets worse fast. If the card has been sitting untouched since it happened, your odds are still pretty good.
Before you install anything, do a few boring checks.
  • If the deletion happened while the card was mounted on a Mac, look in the macOS Trash.
  • If it happened on Android, check Google Photos trash and Samsung Gallery recycle bin. Those often keep items for 30 to 60 days.
  • Look for auto backup copies in whatever cloud sync you use.
If none of those turn up anything, the usual path is recovery software.
One mistake I made once, I tried pulling files through the phone connection first. Bad idea. A phone or camera over USB often hides the raw file system, so recovery apps don’t get full access to the card. Phone recovery apps are rough too. A lot of them only pull cached thumbnails unless the device is rooted, and then you end up with tiny blurry previews instead of the original files.
Use a USB SD card reader. Plug the card straight into a Windows PC or Mac. That gives the recovery tool direct access to the card.
There are a bunch of recovery tools out there. Disk Drill is the one I had the least friction with. PhotoRec works, and people swear by it, but sorting through piles of renamed files with no folder structure got old fast when I tried it. Disk Drill was easier to deal with, and it handled camera formats like RAW, CR2, and NEF without me fighting the app.
What I’d do:
  1. Install Disk Drill on your computer. On a Mac, give it Full Disk Access in Privacy settings or it may not scan properly.
  2. Insert the SD card with a card reader. Open the app and find the SD card in the drive list.
  3. Select the card and start a lost data scan. Universal Scan is usually the safest pick. It checks for recent deletions first, then does a deeper pass for known file signatures.
  4. Wait. You can peek at results while it scans, but I usually let the whole thing finish.
  5. Open the Pictures section when the scan is done. Filter by file type if you want. Use the preview icon on each file.
This part matters most. If the image preview opens cleanly, the file is usually intact. If it won’t open or it looks broken, recovery for that one is hit or miss.
  1. Select the photos you want and hit Recover.
When it asks where to save the recovered files, do not put them back onto the same SD card. Save them to your computer’s internal drive or a different external drive. Writing recovered data back to the same card is how people wreck the last good copy. I did this once years ago. Never again.
After recovery, open a handful of files and make sure they’re fine. Once you know the photos are safe, put the card back in the camera and format it there for a clean start.
That’s the route I’d take.
Stop using the SD card. That part from @mikeappsreviewer is dead on. Every new photo or file move lowers recovery odds.
One thing I’d add, make an image backup of the card before you try recovery. Use a tool like USB Image Tool on Windows or dd on Mac/Linux. Work from the image file, not the card itself. If a scan goes sideways, you still have the original state. Most people skip this and regret it.
I also would not trust the camera after deletion. Put the card in a reader, not back in the camera. Some cameras write thumbnails and index files the second they mount. Tiny writes still matter.
If the card looks empty after a transfer, check for file system damage too. On Windows, look for hidden files and a FOUND.000 folder. On Mac, use Disk Utility to see if the card mounts with errors. Sometimes photos were not deleted, the directory got messed up.
For recovery, Disk Drill is a solid pick because previews save time. I agree there. If Disk Drill finds nothing useful, try PhotoRec as a second pass, since it ignores the file table and searches by file signatures. Messy output, but it pulls files from damaged cards better than many polished apps.
Also, this helps if you want a quick overview of photo recovery tools, best recovery software for deleted photos and SD cards.
Save recovered files to your computer, never back to the SD card. Then test a few images. Full size, not thumbnails. If previews look gray or half cut off, parts were overwritten. That sucks, but at least you’ll know fast.
Big thing I’d add to what @mikeappsreviewer and @andarilhonoturno said: figure out how the photos were deleted, because that changes your odds a lot.
If this was a normal delete from a computer, recovery is usually better. If the card was formatted in-camera, still possible. If the card was used a bunch afterward, that’s where things get ugly fast. Also, if it’s a microSD from a phone and it was encrypted by that phone, standard recovery can be a total pain. People skip that detail and waste hours.
I slightly disagree with the “always make an image first” advice for every person. It’s ideal, yes, but if somebody is non-technical, they can screw that up too. If you’re comfortable doing it, make a byte-for-byte image. If not, at least set the SD card’s little lock switch before connecting it and recover carefully from there. Not perfect, but better than poking at it blindly.
Another thing, check the file sizes of anything recovered. Sometimes you get a “photo” back that is really just a broken header or tiny thumbnail. If your camera normally makes 8MB JPEGs and you recovered 120KB files, yeah… that ain’t it.
If Disk Drill sees the original filenames and folder structure, that’s a very good sign. If it only finds raw signatures, recovery may still work, but organization will be a mess. That’s one reason Disk Drill is usuallly easier for SD card photo recovery than more barebones tools.
Also worth reading: best ways to recover deleted photos from an SD card
One more practical tip: recover the most important photos first, not all 4,000 files in one go. Prioritize the irreplaceable stuff. Saves time and lets you verify whether the recoverd files are actually usable.
One angle not mentioned enough: check whether the SD card is failing, not just “deleted.” If Windows asks to format it, or the copy process threw read errors, recovery software may only get part of the set. In that case, do the recovery first, then retire the card. SD cards often die gradually.
I partly disagree with the “lock switch is enough” idea. It helps, but some readers ignore it, so I still treat it as a nice extra, not protection. Reader + no writing + recover to another drive is the real rule.
About tools, Disk Drill is a reasonable first shot.
Pros
  • Easy previews, which matter more than people think
  • Better for normal people than command-line stuff
  • Can sometimes preserve names/folders if filesystem metadata is still there
  • Free recovery limits depend on platform/version
  • Deep scans can return lots of junk alongside real photos
  • If the card has serious corruption, it may miss files that rougher tools can carve out
That’s where @andarilhonoturno, @nachtdromer, and @mikeappsreviewer are all basically pointing in the right direction: use a card reader, avoid writing anything, verify recovered files at full size.
My extra tip: sort results by date taken and camera file extension first. Ignore PNGs, thumbnails, cache files, and tiny JPEGs until you’ve secured the actual DCIM shots. If your camera shot RAW+JPEG, recover the RAWs too even if the JPEG looks broken. Sometimes the RAW survives when the JPEG does not.
