I just got an HP laptop and I can’t figure out how to take a simple screenshot. I’ve tried a few key combinations I found online but nothing seems to save an image anywhere. Can someone explain the easiest ways to screenshot on an HP (keyboard shortcuts or built‑in tools) and where those screenshots are stored afterward
On HP laptops it depends more on Windows version than the brand. Here are the easiest options.
Full screen straight to file
Press Windows key + PrtScn.
Your screen will flash.
Windows saves the screenshot to:
Pictures > Screenshots folder.
If nothing happens, check that the PrtScn key is not sharing with another function. On some HP keyboards you must press Fn + Windows key + PrtScn. -
Copy full screen to clipboard
Press PrtScn by itself.
This copies the screen.
Then open Paint, Word, Discord, whatever, and press Ctrl + V to paste.
Save from there. -
Active window only
Click the window you want.
Press Alt + PrtScn.
Open Paint and press Ctrl + V.
Save the image. -
Snipping Tool shortcut
Press Windows key + Shift + S.
Your screen goes dim and a small toolbar shows at the top.
Choose Rectangular, Freeform, Window, or Fullscreen.
Drag and select what you want.
The image goes to the clipboard.
You get a small notification in the corner. Click it to open in Snipping Tool and save. -
Check the Fn key setting
On some HPs the top row keys need Fn. If PrtScn is on the same key as Insert or something, try:
Fn + PrtScn
Fn + Alt + PrtScn
If none of these save to Pictures > Screenshots, start with Windows + Shift + S. That one works on almost every Windows 10 and 11 HP laptop, unless an admin killed it.
Since @caminantenocturno already covered the usual Windows key combos, I’ll skip rehashing those and hit a few other things that trip people up on HP laptops specifically.
- Check what “Print Screen” actually does on your machine
HP + Windows loves to silently hijack that key for OneDrive or other apps.
- Open Settings → Accessibility → Keyboard (on Win 11) or Settings → Ease of Access → Keyboard (Win 10).
- Look for an option like “Use the PrtScn button to open screen snipping.”
- If it’s ON, then hitting PrtScn will open the snipping overlay instead of saving anything automatically. You still have to drag, then paste or save.
- If you want old school behavior, turn that off.
- Check OneDrive’s screenshot settings
Sometimes screenshots are being saved, just not where you expect.
- Right‑click the OneDrive icon in the system tray.
- Go to Settings → Backup → Screenshots.
- If “Automatically save screenshots I capture to OneDrive” is checked, your PrtScn screenshots go to OneDrive\Pictures\Screenshots instead of local Pictures\Screenshots.
So you might be taking screenshots correctly and just hunting in the wrong folder.
- Try the built‑in Snipping Tool directly (not just the shortcut)
If Win + Shift + S feels clunky:
- Hit Start and type “Snipping Tool.”
- Open it, click “New,” pick your area, then save.
You can pin it to the taskbar for a one‑click screenshot workflow. A bit slower than the shortcuts, but very reliable if key combos keep failing.
- Check the HP keyboard driver / hotkey app
On some HP models, the top row and special keys behave weirdly until HP’s hotkey/keyboard driver is installed or updated.
- Open Device Manager → Keyboards and make sure nothing has a warning sign.
- Go to HP Support for your model and grab the latest “Hotkey Support” or similar.
If Fn combos are not working at all, this can be the reason.
- Rule out a “broken” Print Screen key
Low‑tech but worth doing. Try:
- Win + Shift + S. If that works, but PrtScn alone never does anything no matter what settings you flip, your dedicated PrtScn key might actually be faulty.
- As a workaround, you can map another key combo to screenshots using PowerToys (Keyboard Manager) or a 3rd‑party tool like ShareX.
- If you want something dead simple that always saves to file
Windows’ behavior is honestly a bit inconsistent between versions and settings. If you’re tired of guessing:
- Install ShareX, turn on “Capture → Print Screen” to “Save image to file.”
- From then on, any time you hit PrtScn it just silently saves a PNG to the folder you chose, every time, no questions asked.
So, in your situation, I’d do this quick checklist:
- Hit Win + Shift + S and confirm something happens.
- Check OneDrive’s screenshot folder to see if your earlier tries actually worked.
- Look at the Keyboard settings for that “Use the PrtScn button to open screen snipping” toggle.
- If all else fails, install a tiny tool like ShareX and bypass the whole HP / Windows PrtScn circus.
It’s not really about HP as a brand, more about how Windows is configured on your particular laptop, which is where I slightly disagree with @caminantenocturno’s “works on almost every system” comment. In practice, OEM settings, OneDrive, and Fn behavior can make it feel like nothing is working, even when it technically is.
Couple of extra angles that might explain why “nothing is saving,” without rehashing what @sternenwanderer and @caminantenocturno already covered:
Check if your screenshots are going into a virtual desktop app
Some OEM setups come with a preinstalled tool that quietly hijacks Print Screen and stores images in its own gallery. Open the Start menu and search for things like “Screenshot,” “Capture,” or “Gallery.” If you see an HP-branded capture utility, open it and check its settings or library. Your shots might all be in there instead of Pictures > Screenshots. -
Look for weird key sharing on the HP keyboard
On certain HP layouts, Print Screen is hiding on a key that looks harmless, like “End” or “Home,” or is printed in tiny text on a function key. In those cases, pressing Win + PrtScn alone will never work. You really do have to press Fn + that shared key. Do a slow visual scan of the top row and cluster above the arrow keys for “PrtSc,” “prt sc,” or a camera icon. -
Try a different user account
Sometimes a corrupted profile or tight admin policy blocks saving to Pictures.
- Create a temporary local account.
- Log into it and try Win + PrtScn or Win + Shift + S.
If it works there, the problem is not the key combo but your main account’s permissions or policies.
Check folder permissions on Pictures
Right click the Pictures folder > Properties > Security and confirm your user actually has Write permission. If HP’s initial setup or a domain policy borked that, Windows might be failing silently when it tries to auto save screenshots. -
Third party tool as a “truth test”
Ignoring the empty product title you mentioned, the general idea of using a dedicated screenshot program still helps. Tools in that category have some pros and cons:
Pros:
- You decide exactly where files go, every time.
- Can auto save with timestamps and custom names.
- Often add extras like annotations, auto upload, GIF capture.
- One more app running in the background.
- Needs a bit of setup to bind it to the Print Screen key.
- Overkill if you only need the occasional quick grab.
Compared to what @sternenwanderer focused on (Windows versions and standard key combos) and what @caminantenocturno added (settings, OneDrive, hotkeys), this approach is more about figuring out why your current attempts feel like they vanish. Personally, I would:
- Identify the physical PrtScn key on your specific HP layout.
- Test a third party capture app with a simple “Save to file on PrtScn” rule.
- If that works, then track down whether OneDrive, an HP utility, or permissions are intercepting the default Windows behavior.
Open the Start menu and type “Snipping Tool.” Launch it, select New, then drag over the area you want. Click the save icon and choose Desktop. Name the file, then press Save.
This avoids hidden PrtSc keys, folder permissions, and background apps. Saving to Desktop also makes the sceenshot easy to find.
Before installing anything, just check the Screenshots folder inside Pictures one more time. Sort by date. Half the ‘nothing is saving’ cases I’ve seen come down to people looking in Documents or the Desktop while the files quietly stacked up somewhere else. @shadowspark169one’s Snipping Tool route is the one I’d actually start with too, mostly because the current Snipping Tool can be set to auto-save every capture on its own, so you skip the paste-into-Paint dance entirely. Worth turning that on in its settings before you go chasing OneDrive toggles or third party apps.
