How to connect iPhone to Samsung Smart TV?
Hi!
I’m trying to connect my iPhone to my Samsung Smart TV, but I’m not sure how to do it. I’ve heard there are different ways to mirror the screen or stream content, but I’m a bit confused about which method is the best. Can anyone guide me on how to set this up? Any app suggestions or step-by-step instructions would be great. Thanks!
You can connect your iPhone to a Samsung Smart TV using AirScreen, which supports AirPlay. It’s great for mirroring, but both devices need to be on the same Wi-Fi. ApowerMirror is another option that includes extra features like screen recording but might have some lag. The DoCast app is also worth trying, as it’s easy to use.
Use AirPlay for seamless mirroring if your Samsung TV supports it. It’s easy and reliable but limited to newer models. The DoCast app - https://apps.apple.com/us/app/screen-mirror-smart-tv-docast/id6446948344 is another option, offering a simple setup.
