I’m used to FaceTime on my iPhone, but now I need to video chat with family and friends who only have Android phones. I’m confused about which apps actually work best between iPhone and Android, and how to set them up for less tech-savvy relatives. Can anyone walk me through the easiest, most reliable way to video call between iPhone and Android, and what settings we should check so it all works smoothly?
Short version. FaceTime to Android is awkward. Using a cross‑platform app is much easier. Here is what works best right now and how to set it up.
FaceTime link to Android
- iPhone needs iOS 15 or newer.
- Open FaceTime on iPhone.
- Tap “Create Link”.
- Share the link by text, email, WhatsApp, whatever.
- Android user taps the link in Chrome.
- They enter a name, hit Join.
- You accept them from your iPhone.
Downsides - No FaceTime app on Android, only browser.
- Quality and stability vary.
- Not great for frequent calls.
Best cross‑platform choices
These work well between iPhone and Android.A) WhatsApp
- Free, encrypted, huge user base.
- Needs phone number.
Setup on iPhone and Android - Install WhatsApp from App Store or Play Store.
- Open, accept terms.
- Verify phone number with SMS code.
- Add contacts or let it read your contacts.
Start video call - Open chat with the person.
- Tap video icon in top right.
Pros - Works on weak networks better than some apps.
- Easy for non‑techy family.
Cons - Tied to phone number.
- Need decent data or Wi‑Fi.
B) Zoom
- Good for groups and scheduled calls.
Setup - Install Zoom from each app store.
- Create an account with email.
Start call - Tap “New Meeting”.
- Share link or Meeting ID to family.
- They join from the app.
Pros - Great for big family calls.
- Works on phones, tablets, computers.
Cons - More steps.
- Older relatives get confused by IDs and passwords.
C) Google Meet
- Solid quality, easy if people use Gmail.
Setup - Install Google Meet app on iPhone.
- On Android many phones have it preinstalled.
- Sign in with Google account.
Start call - Tap “New meeting”.
- Share link by text or email.
- Everyone taps link and joins from the app.
Pros - Simple join link.
- Works well on mixed devices.
Cons - Everyone needs a Google account for best use.
D) Messenger or Instagram
- Good if your family already uses Facebook or IG.
- Video icon inside any conversation.
- Quality is fine for casual calls.
What I would do for your situation
- If your family already uses WhatsApp, use that for daily video chats. Setup takes 5 minutes and calling is one tap.
- For big holiday calls with many people, use Zoom or Google Meet. Create a link, send it in a group chat, tell everyone “Tap this link at 7pm”.
- Use FaceTime links only if someone refuses new apps and you are on iPhone with iOS 15 or newer.
Quick troubleshooting tips
- If video looks bad, switch both sides to Wi‑Fi.
- If audio lags, turn off video for a bit.
- If older relatives get lost, send a screenshot with a big circle around the video button.
- Keep everyone on the same app. Less confusion.
If you say what your family already uses, like WhatsApp, Facebook, SMS only, you get a clearer winner fast.
FaceTime + Android is basically Apple saying “fine, but only if it’s inconvenient.” @boswandelaar covered the link stuff well, so I’ll skip repeating that and talk about what actually works day to day.
If you want this to be painless for non‑techy relatives, I’d pick one app and force everyone into it. Harsh, but it saves you from being family IT support forever.
Here’s how I’d look at it:
If they mostly text with SMS
Use Google Meet or Messenger instead of FaceTime links.- Google Meet: iPhone installs the app, Android usually has it already. You make a meeting, text them the link, they tap and join.
- Messenger: If they already have Facebook accounts, this is usually the least confusing. Open chat, hit video, done. No weird “open in browser” FaceTime behavior.
If they’re on Android with RCS / Google Messages
Slight disagreement with @boswandelaar here: before installing 5 new apps, check what’s already there.- A lot of Android users have Duo / Meet integrations baked in. You start a video call straight from the conversation.
- For you on iPhone, Meet is still the bridge. One app on your phone is easier than juggling Zoom, FaceTime links, and ten random things.
If you care about quality more than convenience
- Zoom and Meet usually beat FaceTime-in-a-browser for stability, especially on older or cheap Android phones.
- FaceTime link to Android can be fine, but I’ve seen it glitchy enough that I wouldn’t trust it for important calls.
If your relatives get confused easily
Pick one of these and stick to it:- Messenger
- Meet
Then literally tell everyone: “We use X for video calls now.”
Make a little “how to answer” screenshot for them: circle the green button or video button, send it in your family group. Sounds silly, works wonders.
When to actually use FaceTime links
- Someone refuses to install apps.
- You’re on iOS 15+ and they have Chrome on Android.
- You don’t mind sending a fresh link every time.
Personally, I’d treat FaceTime-to-Android as a backup option, not the main solution.
If you say what your family already uses most (SMS, Facebook, WhatsApp, nothing at all), you can narrow this down to one app and save yourself a ton of explaining later.
FaceTime-to-Android is basically three choices:
- Use FaceTime links as “emergency only”
- Standard cross‑platform chat apps
- Proper video‑meeting tools
I disagree a bit with treating FaceTime links as purely backup. For short, one‑off calls with semi‑techy people, they’re fine if:
- You are on iOS 15 or later
- They open the link in a modern browser
- You’re okay with no fancy features and slightly flaky behavior
Anything more than that, @boswandelaar is right: you’ll regret the friction.
Instead of rehashing Meet / WhatsApp / Messenger, here is how I’d decide based on how “structured” your calls are:
Casual drop‑in family chats
- Use WhatsApp or Messenger if everyone already messages there.
- Advantage over FaceTime link: tap once from the chat, no browser, no “join” screen confusion.
- On iPhone you just treat it as your “How to Facetime Android” replacement: whenever you would hit FaceTime, hit WhatsApp/Messenger video instead.
Scheduled or “event” calls (birthdays, holidays, remote parties)
- This is where proper meeting tools shine.
- Google Meet is good, but I’d strongly consider Zoom as a main “family event” app:
- Very tolerant of bad Wi‑Fi and ancient Android devices.
- The “meeting link” pattern is simple: the same URL can be reused for all big calls.
- Still, I would not force grandparents through app stores if they are already comfortable with something like Messenger. In that case, let the quality be “good enough” and win on simplicity.
Mixed tech‑levels in the same family
- Do not chase a perfect universal app. Pick 2 layers:
- Layer 1 “default”: one everyday app for most people (WhatsApp / Messenger / Meet).
- Layer 2 “fallback”: FaceTime link or Zoom for the one person who cannot install or cannot remember passwords.
- This prevents you from changing tools every time one person has an issue.
Since you specifically come from FaceTime, here’s how I’d mentally translate habits:
- “Start a FaceTime” → “Open X app and hit video in the existing chat”
- “Create a FaceTime link” → “Create Google Meet / Zoom link and reuse it for recurring calls”
Regarding the product name “How to Facetime Android” as a concept or guide you might search for, treat it like this:
Pros:
- Forces you to think cross‑platform instead of Apple‑only.
- Surfaces simple app combos like “iPhone + Android = WhatsApp / Meet / Messenger” in one place.
- Helps you stop troubleshooting FaceTime links and just adopt a cleaner workflow.
- The phrase itself is a bit misleading because there is no true FaceTime app for Android.
- Many “How to Facetime Android” guides online overcomplicate things with 5+ app suggestions instead of pushing you toward one main option.
- Can make you cling to FaceTime links when you’d be better off fully switching to a proper cross‑platform tool.
Compared with what @boswandelaar wrote, I’d say:
- They are right that Apple made this inconvenient on purpose.
- I disagree slightly on treating Meet as the only serious bridge. Meet is good, but Zoom or WhatsApp can be less confusing for very non‑technical folks, especially if they already live inside WhatsApp.
Bottom line:
- If your people already use WhatsApp daily, make that your “FaceTime for everyone.”
- If they mostly use SMS and nothing else, start with Google Meet or Messenger.
- Keep FaceTime link as a rare exception, not the thing you keep trying to fix every weekend.
I’d simplify your plan to one app, rather than a default plus backups. Signal is another option for iPhone and Android video calls.
Install it on both phones and complete setup. Open your family member’s chat, then tap the camera icon to call. Both people need Signal and an internet connection.
Do the intial setup together, then practise one call before you need it. Put the app on your home screen for easy access.
I’d try this if your family is willing to install one new app.
Watch the notification settings on the Android side before you blame any app. Half the ‘it didn’t ring’ complaints I’ve seen come down to Android aggressively killing the app in the background or burying its notifications. Samsung and Xiaomi phones are the worst for this. If your aunt installs WhatsApp or Signal and then never gets a ringtone when you call, it’s almost never the app itself, it’s battery optimization quietly shutting it down. Go into the app’s settings, turn battery optimization off for it, and make sure notifications are allowed. Do that once and you save yourself a dozen ‘did you call? I didn’t see anything’ texts.
On the app choice, I think @nanostream6881one has the right instinct pushing one app instead of a default-plus-backup stack. Signal is solid and the privacy is genuinely better than most. The catch is that your family has to actually have it, and getting non-techy relatives to install something they’ve never heard of is harder than it sounds. People trust the logo they already recognize. That’s the quiet reason WhatsApp wins so often, not because it’s technically better, but because grandma already has the green icon.
The thing nobody above mentioned is cost on mobile data. Video calling eats data fast, and if any of your relatives are on a capped plan or prepaid, a long family call can burn through an alarming chunk of it. That matters more than which app looks nicer. Tell everyone to call on Wi-Fi when they can, not as a quality tip but as a bill-saving one.
Where I’d gently disagree with the ‘force everyone onto one app’ line running through this thread is the assumption it stays clean. In practice families split. Some cousins live in Messenger, the older crowd ends up on WhatsApp, and you quietly become the person who has both. That’s fine. You don’t need one universal app, you need to not be the one troubleshooting it every weekend. Pick whatever the loudest, least flexible relative already uses and let the rest adapt to that.
FaceTime links I’d keep for exactly one case: the person who flatly refuses to install anything. For everyone else they’re more hassle than they’re worth.
