How to recover a deleted Word document?
Accidentally deleted a crucial Word document and can’t find it in the recycle bin. Tried searching everywhere on my computer but no luck. Need it back urgently for an important project. Any advice on how to recover it?
First thing you need to do is stop using your computer immediately. Continual usage can overwrite the deleted file, making it much harder, if not impossible, to recover. I get that you’re in a tight spot, so here’s a rapid rundown of steps you can follow.
Step 1: Check Your Backup Options
If you’ve been using a cloud service like OneDrive, Google Drive, or Dropbox, your document might still be there. These services often have a version history, which means even if you deleted the document, an older version might still be available.
Step 2: Look for Temporary Files
Microsoft Word sometimes saves temporary copies of your documents. These are generally found in a folder like C:\Users\[Your Username]\AppData\Local\Microsoft\Office\UnsavedFiles.
Navigate there and look for files with a .asd or .wbk extension. If you find any, change the extensions to .docx and try to open them with Word. It’s a long shot, but worth a try.
Step 3: Use a File Recovery Software
If you haven’t found any backups or temp files, you’ll need to use file recovery software. I highly recommend trying Disk Drill
(you can get it from https://www.cleverfiles.com/). It’s a robust program designed to recover lost files from hard drives, USB drives, and other storage devices.
After downloading and installing Disk Drill, run a scan on the drive where your document was originally saved. Disk Drill will display a list of recoverable files. Look through the results and find your Word document. The free version has some limited data recovery options, and for extensive recovery, you might need the pro version. It’s really user-friendly, even for non-techies.
Step 4: Check Your Email Attachments
If you’ve ever emailed the document to someone or worked on it via an email attachment, dive into your sent folders or check those attachments. That could save your neck without all the hassle.
Step 5: Seek Professional Help
If none of the above steps work and this document is absolutely irreplaceable, contacting a professional data recovery service might be your last resort. These services can be expensive but they usually have very high success rates.
Good luck! These situations can be really stressful, but with a bit of perseverance, there’s a good chance you’ll get your document back.
Hey, sorry you’re going through this. Losing essential documents can really trip you up.
Here’s a tip that sometimes gets overlooked. Check the “File History” option in Windows if it’s enabled. First, go to the folder where your file was located. Right-click and see if there’s an option to “Restore previous versions”. This will show you the old versions of the folder and potentially your lost document.
Another method that might help you is using the built-in Windows backup utility. If you have Windows Backup running, this is where it shines. Go to Settings > Update & Security > Backup, and check if you have any backups that might contain your file.
For Mac users, Time Machine does this job exceptionally well. Plug in your Time Machine backup disk, then use the “Enter Time Machine” feature from the Time Machine menu to browse old backups of your documents.
Sometimes, Word crashes and leaves behind AutoRecover files. Search for .asd, .wbk, or .tmp files under C:\Users\[Your Username]\AppData\Roaming\Microsoft\Word if you’re on Windows or under \Library\Application Support\Microsoft\User Data\ on a Mac. Word also sometimes saves drafts under C:\Users\[YourUsername]\Documents\.
If those don’t pan out, a quick caveat regarding file recovery software echoing what codecrafter mentioned – be cautious about continuously using Disk Drill or any recovery software in an emergency. It’s indeed a reliable option, but constant installations and operations might make sections of your disk inaccessible, thereby lowering your chances of recovery. Disk Drill Data Recovery Software (https://cleverfiles.com/lp/data-recovery-software.html) usually works well, but keep that in mind.
Don’t forget to also try looking in the OneDrive Recycle Bin or Google Drive Trash if you have cloud sync enabled. They often keep trashed files for 30 days or more.
Another angle – sometimes documents get saved in weird places if you were using something like a USB drive or external disk. If you remember the exact contents or keywords from your doc, a deep dive with advanced search tools such as “Everything” for Windows can be extra efficient compared to the standard search functionality of the OS.
Here’s a less-known trick: sometimes antivirus software keeps a shadow copy of modified files. If you have a solid antivirus running, check if it has a file restoration feature.
Paranoia kicking in? Sometimes, people inadvertently email drafts of critical documents. Scour through your email for attachments or versions you might have sent. This could be quicker and simpler.
Last but probably the heftiest step - data forensics services. These professionals can dive deep into your hardware to pull up seemingly irretrievable data. It’s pretty much the nuclear option but can be incredibly effective. Costs another kidney though.
Focus on these steps, and minimize any new writes on your disk until you’ve exhausted data recovery methods – the key is to act swiftly but cautiously.
First off, tap those brakes and stop any further activity on your machine. The more you use it, the harder it’ll be to recover your Word doc. Byteguru and codecrafter have shared some solid advice, but here’s a bit more to chew on.
Check for Shadow Copies and Previous Versions
Windows often keeps shadow copies—automatic backups—of your files. Right-click the folder where the file was and look for “Restore previous versions.” If you’re lucky, your doc might be there. Mac users, time to flex Time Machine. Plug in your backup drive and dive into those old backups. If Windows shadow copy doesn’t pan out, try this:
System Restore
It might be a stretch, but if you had System Restore active, you could revert your computer to a point before the file was deleted. Open System Restore by typing it in the Windows search bar, follow the prompts and select a restore point.
Peeking into Hidden Corners
It’s easy to miss hidden folders and files. They might be storing auto-saved versions of your document. On Windows, open File Explorer and navigate to:
Or even,
Look for files with .asd, .wbk, or .tmp extensions. Change these extensions to .docx and see if Word can open them.
For Cloud Wizards
Double-check your OneDrive, Google Drive, or Dropbox accounts if you have them linked to your Word. These storage services often lag in permanent deletions and might still hold an old version in the Trash or Recycle Bin. Log in and dig through the deletions.
Specialized File Recovery Software
Even if cloud sync wasn’t enabled, there’s hope. Disk Drill is a notable recommendation but keep in mind: it’s powerful yet not infallible. It has a user-friendly UI, supports a range of file types, and usually delivers. However, running it can take considerable time and if you’re not quick, new data might overwrite your deleted files. Also, it’s a bit of a nag with upsells to their pro version.
Pros of Disk Drill:
  1. User-friendly, catering even to non-techies.
  2. Supports numerous file types.
  3. Often successful in retrieving files from hard drives, USB drives, and more.
Cons of Disk Drill:
  1. Free version is limited; extensive recovery needs a paid upgrade.
  2. Potential to overwrite data during installation.
Alternatives include programs like Recuva and EaseUS Data Recovery Wizard. Each software has its quirks, but the principle remains the same. Install on a different drive to avoid overwriting.
Beyond Software – Email and Attachments
While it’s easy to forget, you might have emailed the document or stored it in your email drafts. Open your email client and perform a robust search. Keywords and attachment searches can be incredibly revealing.
Diving Deeper – Antivirus Software
Another overlooked trick is checking your antivirus software for shadow copies. Some robust antivirus programs make backups of modified files and might just have your document.
Last Resort – Professional Data Recovery Service
All of this not panning out? Data forensics can feel like overkill, but if it’s that critical, professionals can work miracles. They’re pricey but often boast high success rates. Be prepared for substantial cost, but it might be worth it if it’s make-or-break.
Conclusion
So there you go, more avenues to explore. Just remember, speed and caution are key. Minimize any new writes on your system and explore these methods one-by-one. Here’s hoping you get your document back pronto.
Open Microsoft Word, then go to File, Info, Manage Document, Recover Unsaved Documents. Word stores temporary recovery copies even when the original file is gone.
Sort the files by date. Open anything created near your last editing session. If you find the document, select Save As and store it on another drive or cloud folder.
Also open File, Open, Recent. Your document might appear under a different name or location. Right-click its entry and choose Open file location. This takes two minuites and requires no extra sofware.
