Accidentally deleted a partition and now it’s showing as unallocated space. I really need to get back the data that was on it. Any suggestions on how to fix this?
Oh no, losing a partition can be stressful, but there are recovery options out there. First, don’t write any new data to the storage device where the partition got deleted. Writing new data can overwrite the ‘deleted’ partition, making recovery more difficult, if not impossible.
One tool that might help you out is Disk Drill
. It’s reliable for recovering lost partitions and data. Here’s how you can use it:- Download and install Disk Drill.
- Run the program and select the storage device with the unallocated space.
- Scan for lost partitions. Disk Drill has a feature specifically for this.
- After the scan, you’ll see a list of recoverable partitions and files. Select the ones you need, and follow the instructions for recovery.
Pros of Disk Drill:
- User-friendly interface: It’s pretty intuitive, so you don’t need to be a tech whiz to use it.
- Powerful scanning algorithms: It’s quite comprehensive in what it can recover.
- Free version: The free version lets you recover up to 500MB of data, which might be good enough if you’re dealing with smaller files.
Cons of Disk Drill:
- Cost: Full features and unlimited data recovery come with the paid version, which may not be cheap depending on your budget.
- Scan time: Depending on the size of the disk, the scan can take quite a while.
Other notable tools are MiniTool Partition Wizard and EaseUS Data Recovery Wizard. They also have free versions with varying limits and are worth checking out if Disk Drill isn’t to your liking.
By the way, if you’re comfortable with command lines, you might want to try TestDisk. It’s a free, open-source tool that’s well-regarded but not as user-friendly as the others. You have to be careful with this one though since it doesn’t come with the same ease-of-use features and needs cautious handling to avoid further issues.
So there you go – download a tool like Disk Drill, follow the prompts, and keep calm. Disk recovery hasn’t been made this easy before. Good luck!
Can’t agree more with what @techchizkid said about not writing new data to the drive, that’s crucial. Personally, though, I’ve had mixed results with Disk Drill. It’s a decent tool, but there are other strong contenders you might wanna look into as well.
If you’ve got some basic tech skills, let’s talk about using MiniTool Partition Wizard. In my experience, it’s pretty robust and, importantly, free for something like this. Here’s how you could tackle it:
Steps for MiniTool Partition Wizard:
- Download and Install: Grab it from their official site and install it on a different drive than the one you’re trying to recover. More info on that here: Best Free Partition Manager for Windows | MiniTool Partition Wizard Free
- Launch and Analyze: Once up, fire up the tool and find your drive with the unallocated space.
- Partition Recovery: They’ve got a “Partition Recovery Wizard” option that’s pretty self-explanatory. Follow the steps, and it’ll show you what can be scooped back up.
- Review and Recover: After running the scan, it’ll list recoverable partitions. Take a good look at these and select what you need.
Advantage of MiniTool:
- Comprehensive and Detailed: It provides an in-depth look at the drive, so you won’t miss much.
- Free Tier: It handles a lot without prompting you to fork over cash straight away.
- Ease of Use: While not as slick as Disk Drill, it’s intuitive enough.
However, not everything is rosy. The interface can be a tad clunky compared to Disk Drill, and recovery might not always be as successful depending on the corruption level.
Another Solid Option – EaseUS Data Recovery Wizard:
- Download and Install: Get it from their official site (keep in mind the free version has a 2GB limit for data recovery).
- Choose the Disk: Select the disk with unallocated space.
- Run a Scan: It has a detailed scanning process, might take some time.
- Recover: Once it shows the recoverable data, proceed with restoring it.
EaseUS is pretty effective and also user-friendly like Disk Drill. The downside? Pro version is pricey, but if you need it only once, it might be worth it!
Secret Nerd Trick – TestDisk:
If you’re into command-line tools, try TestDisk. It’s reliable but needs a bit of caution.
- Install and Run TestDisk: There are tutorials to guide you, and it’s open-source.
- Select Disk and Analysis: It asks specifics, and then you analyze the disk, looking through the logs.
- Recover Partitions: You can then view, select, and proceed with partition recovery.
While TestDisk is free and powerful, it’s imperative to double-check each step ‘cause one wrong move and you’ll end up complicating things further.
While some folks might not find TestDisk friendly, I guess double-checking and patience can work wonders here.
For more info on Disk Drill and its intricate details if you ever consider it, check out their site: Disk Drill Data Recovery Software.
While unpaid, these tools‘ free versions can offer substantial recovery. But hey, if you need consistent reliability and more features, investing in a premium version might just save you from future heartburn.
Remember, the worst enemy’s time here. The faster you tackle this, the better odds you’ve got at retrieving your lost data. Don’t stress too much, with the right tool you should be able to get your data back.
Oh man, accidentally deleting a partition can feel like the end of the world, but chill out, there’s definitely hope! @byteguru and @techchizkid already covered some terrific tools, but let me throw in another angle for you.
First thing’s first, if you’ve got a Windows system, you actually have some built-in utilities worth trying before downloading any new software. Here’s a step-by-step that’s saved me more than once:
Disk Management Tool:
- Right-click on ‘This PC’ and go to ‘Manage’.
- In the Computer Management window, head to ‘Disk Management’.
- Sometimes, the unallocated space can simply be re-added by creating a new partition here. This won’t exactly recover your data but can visualize the lost space.
Command Prompt (Diskpart):
- Fire up your Command Prompt as an admin and type
diskpart. - List your disks with
list diskand navigate to the specific disk withselect disk X(X being your disk number). - Try
list volumeanddetail diskto get more info. Sometimes the ‘lost’ partition shows up here and can be re-flagged for access.
These methods aren’t as full-featured as some of the dedicated software, but hey, free built-ins can sometimes do the trick if you’re lucky.
Now, heading into the heavy-duty stuff, if you want something a bit more hardcore, you might try Recuva (developed by the good folks at CCleaner). It’s similar to those previously mentioned but often overlooked. Here’s a quick rundown:
Recuva Steps:
- Download and Install: Hit up their official site and grab the installer. (Note: Run the installation on a different drive).
- Run the Wizard: It’s got a super friendly wizard to walk you through the process.
- Choose the Drive: Select the drive with the unallocated space.
- Advanced Scan: For a more robust check, run the deep scan.
- Recover: Choose what you need from the list of recoverable files.
Pros of Recuva:
- Simple Interface: Very user-friendly, even for the non-techie types.
- Lightweight: Doesn’t bog down your system.
- Free: The free version often suffices for basic recovery needs.
Cons of Recuva:
- Depth of Recovery: Doesn’t always dive as deeply as some tools.
- Limited Support: Not as much detailed troubleshooting or support.
If the above tools don’t float your boat, and if you’re slightly more tech-savvy, go for R-Studio. It’s a bit more on the advanced side but creates various recovery scenarios and includes a disk editor.
R-Studio in Action:
- Download and Install: You’ll find it on their official website. Installation on a separate drive advised.
- Analyze the Disk: Launch the software and scan the affected disk.
- Review Scan Results: It gives you a super detailed report.
- Recover: Choose what you want to retrieve.
This program’s a beast but might frighten newbies due to its depth. On the upside, being thorough can make the difference.
One critical thing both @techchizkid and @byteguru rightly emphasized – avoid writing any new data to that drive at all costs. The data isn’t really ‘lost’ until it’s overwritten. So, your main enemy right now isn’t your lack of a recovery tool but accidentally saving new files.
Last but not least, let’s dive into Disk Drill when needed. Not detouring too far from our friends’ recommendation, Disk Drill is popular for a valid reason. It’s powerful yet easy enough for everyday users.
Got a quirky approach to try? If you’re on Linux, there’s an open-source tool called Photorec (bundled with TestDisk). While TestDisk excels in partition issues, Photorec aims at file recovery bigtime, entailing a somewhat raw, straightforward way to get back what’s been lost. It takes some patience, though.
Ultimately, in my mind, Disk Drill is like insurance – rarely do you need it, but boy, you’re glad when it’s there. More info on their tool? Check their site: Disk Drill.
No matter which route you choose, remember, patience, and double-checking steps are your best tools here. These recovery endeavors can take some time, and stressful as it might get, staying calm ensures you don’t make further errors.
So go on, give these a shot, and relax – your data’s out there waiting for you to retrieve it. Good luck!
Try restoring from an existing backup before scanning the disk.
Open Windows Backup, File History, OneDrive, Dropbox, or your NAS. Check deleted-file folders and older versions. For OneDrive, open the Recycle Bin and restore the missing folders. File History lets you select a date from before you accidently deleted the partition.
Restore everything to a seperate drive, never the unallocated disk. This approach avoids partition repair and preserves filenames, folders, and timestamps. If no backup exists, stop using the disk and contact a recovery service.
