How to recover data from accidentally formatted SD card?
I accidentally formatted my SD card and lost all my photos and videos. I’m looking for reliable methods or software to recover my lost data. Any help or recommendations would be greatly appreciated. Thanks!
Oh man, that’s a bummer. Accidentally formatting an SD card can happen to anyone, but don’t worry, there are ways to potentially get your data back. Here’s a breakdown of some methods and software to help you recover your photos and videos:
1. Stop Using the SD Card Immediately
First things first, stop using the SD card immediately. The more you use it, the higher the chances that your data gets overwritten, making it more challenging to recover.
2. Data Recovery Software
You’ve got quite a few options when it comes to data recovery software. Here’s a list of some that are generally well-regarded:
a. Disk Drill
Disk Drill is a solid choice for data recovery. It’s user-friendly and versatile, capable of scanning and recovering a variety of file types. The software supports recovery from SD cards, hard drives, USB drives, and more.
  • Ease of Use: Very User-Friendly
  • Supported OS: Windows and Mac
  • Recoverable Files: Photos, Videos, Documents, etc.
You can check it out here for more details.
b. Recuva
Recuva is another good option. It’s free, with a premium version available if you need more advanced features.
  • Ease of Use: User-Friendly
c. EaseUS Data Recovery Wizard
This is also a powerful recovery tool, though it might be a bit more complex than others. It supports a wide range of file types and devices.
  • Ease of Use: Moderate
Methods to Follow
1. Using Disk Drill
  1. Download & Install: First, download and install Disk Drill from their official website here.
  2. Run Disk Drill: Launch the application once installed.
  3. Select the SD Card: Choose your formatted SD card from the list of detected devices.
  4. Scan for Lost Data: Hit the “Search for lost data” button. The scan process might take some time, depending on the size and speed of your SD card.
  5. Preview & Recover: Once the scan is complete, Disk Drill will show you a list of recoverable files. You can preview them before selecting the ones you want to recover. Once selected, click on the recover button.
2. Using Recuva
  1. Download & Install: Get Recuva from their official site.
  2. Run the Program: Launch Recuva after installation.
  3. Choose File Type: Select the type of files you are looking to recover (e.g., photos, videos).
  4. Select SD Card: Choose your SD card as the location to scan.
  5. Scan for Files: Start the scan, and Recuva will search for recoverable files.
  6. Recover: Select the files you want to recover and click the recover button.
3. Using EaseUS Data Recovery Wizard
  1. Download & Install: Get EaseUS Data Recovery Wizard from their website.
  2. Select SD Card: Select the SD card from the list of available drives.
  3. Scan the SD Card: Initiate the scan. There are quick and deep scan options; a deep scan will be more thorough but take longer.
  4. Preview & Recover: Once the scan is completed, you can preview the files, select the ones you want, and click recover.
Pros and Cons
Disk Drill
  • Pros: User-friendly, supports multiple file types, can preview files before recovery.
  • Cons: The free version has limited recovery capabilities.
Recuva
  • Pros: Free version available, easy to use.
  • Cons: Only supports Windows.
  • Pros: Powerful deep scan, supports multiple file types.
  • Cons: More complex to use, free version has limited recovery.
Physical Recovery Services
If software methods don’t work, you can also consider professional data recovery services. These services can be expensive but are particularly useful if the data is extremely crucial. Search for trusted local services or look up data recovery companies online with good reviews.
Pro Tips
  1. Backup Regularly: Always keep backups of your important data to another storage device or cloud storage to avoid such situations in the future.
  2. Double-Check Before Formatting: Always make sure to double-check the drive name before clicking the format button.
Hopefully, one of these methods works for you and you can get your precious memories back. Best of luck!
Hey, sorry to hear about the formatting mishap with your SD card. Happens to the best of us. Byteguru gave some excellent options, but I wanted to add a few more nuances and tools you might find useful. They covered the mainstream choices well, but there are always other angles to consider.
Alternative Tools
PhotoRec
While Disk Drill and Recuva are top picks, PhotoRec is worth mentioning. It’s a powerful tool focused primarily on recovering lost photos and other media files. It’s part of the TestDisk suite, which is known for its robustness.
Pros:
  • Very Powerful: Known for its deep scanning capabilities.
  • General Compatibility: Works on multiple platforms, including Windows, macOS, and Linux.
  • User Interface: Not as user-friendly as Disk Drill or Recuva; it operates through a command-line interface which can be intimidating for newbies.
Stellar Data Recovery
Another player in the recovery space is Stellar Data Recovery. Definitely take a look if the others don’t cut it.
Pros:
  • Wide Range: Can recover almost any file type.
  • User-Friendly: Easier to navigate, especially for those who aren’t tech-savvy.
  • Pricing: It can be a bit pricier compared to others.
  • Performance: Sometimes slower compared to Disk Drill or PhotoRec.
Deep Scan vs Quick Scan
While most tools offer both quick and deep scan options, always start with the quick scan. If that doesn’t yield the desired results, move on to the deep scan which, although time-consuming, is thorough. Deep scans can sometimes locate data that quick scans miss.
Professional Services
Professional recovery services can be a life-saver if DIY methods don’t work out. They’re expensive, but worth considering if the data is invaluable. Companies like DriveSavers or Kroll Ontrack have a solid reputation.
Pro Tips
  1. Backup Strategy: Implementing a regular backup strategy can save you from future headaches. Consider using cloud services like Google Photos for your media files.
  2. Emergency Boot CD: Having an emergency boot CD or USB stick with recovery software on it can also be useful in such scenarios.
  3. File Shredder: If you’re worried about privacy and ever do need to irreversibly delete data, consider using file shredder software. But that’s for another day.
Disk Drill, Again
Just had to second Disk Drill here. Its ease-of-use really sets it apart—especially if you’re not too tech-savvy. Plus, the ability to preview files before recovery adds an extra layer of confidence. However, the free version is somewhat limited, so you might need to shell out for the full version. Its versatility across Windows and Mac is also a big plus.
Pros:
  • User-Friendly: Extremely easy to navigate.
  • Preview Feature: Lets you preview files before recovery.
  • Versatile: Works on multiple platforms and file types.
  • Free Version Limitation: Limited recovery capabilities in the free version.
  • Price: The full version can be a bit costly, but you get what you pay for in terms of reliability.
Skip Disk Drill?
If Disk Drill doesn’t cut it for you or if budget is a concern, Recuva is a solid, albeit Windows-only, alternative. But, once again, its free version is quite impressive for basic recovery.
Final Thoughts
Experiment with a couple of these tools to see what works best for you. Each has its quirks and specialties, and ultimately, the recovery results can sometimes be a bit unpredictable. Also, it’s crucial to stay patient. Deep scans can take a long time, especially on larger cards, but they can sometimes dig up files you thought were long gone.
Hoping you get those photos and videos back! Feel free to circle back with updates or further queries.
Oh no, that’s rough! Accidentally formatting an SD card is a modern-day nightmare. But relax, I’ve got a few more solutions that might just save the day.
R-Studio
R-Studio is another formidable tool that doesn’t always get the spotlight it deserves. It’s not as user-friendly as Disk Drill, but it’s powerful and robust, especially for tech-savvy users.
Pros:
  • Advanced Features: Great for handling complex data loss situations.
  • File Systems: Supports a wide range of file systems, making it versatile.
  • Learning Curve: Not the easiest to navigate, especially for beginners.
  • Price: It’s on the pricier side, but it offers a demo version if you want to test the waters first.
DIY Hex Editor
If you have a knack for the tech stuff, a hex editor might be your secret weapon. Using a hex editor, you can manually seek out and extract lost files. It’s definitely not for everyone, but hey, it’s an option.
Pros:
  • Highly Customizable: Gives you total control over the recovery process.
  • Deep Dive: Can recover stuff other software tools might miss.
  • Complex: Requires a detailed understanding of file systems and data structures.
  • Time-Consuming: Can be quite labor-intensive, not for the faint of heart.
Pro Tips for Data Recovery
  1. Avoid Overwriting: Even after stopping SD card use, ensure you don’t accidentally save or download anything that could overwrite your data.
  2. Multiple Scans: Run multiple scans with different software. Sometimes one tool might miss files that another can recover.
  3. Data Imaging: Creating a bit-by-bit copy of the SD card and working with the image can prevent further data loss.
Linux Live USB Approach
For the geeky, setting up a Linux live USB can help. You run data recovery tools like PhotoRec or TestDisk without installing them on your operating system. Here’s how:
  1. Create Live USB: Use software like Rufus to create a bootable USB drive with a Linux distro.
  2. Boot from USB: Restart your computer and boot from the USB drive.
  3. Install Recovery Tools: Once in Linux, install and use recovery tools like PhotoRec.
Pros:
  • No Overwriting: Keeps your main OS untouched, reducing further data loss risks.
  • Powerful: Linux recovery tools can be highly robust.
  • Complicated Setup: Not exactly beginner-friendly, requires some tinkering.
  • Time-Consuming: Can take a while to get everything running smoothly.
Not Just Photos and Videos
Sometimes, it’s not just photos and videos but other files that need rescuing. R-Studio, Disk Drill, and even PhotoRec can handle a variety of file types. Keep this in mind while selecting a tool.
Revisiting Disk Drill
To reiterate, Disk Drill remains a standout option for its simplicity and power. You can get it straight from their site here. It’s pretty straightforward to use, and the preview feature is super handy.
Take with a Grain of Salt
While these tools and tips are generally reliable, the results can vary. If your SD card has been heavily used post-formatting, recovery might be trickier. The key is to act swiftly and avoid further usage.
Good luck, and I hope you manage to recover those cherished memories!
