How to repair a corrupted hard drive on Mac?
I’m facing an issue with my Mac’s hard drive; it seems to be corrupted. It started acting up after a recent software update, and now I’m unable to access some files. I need the files for an upcoming project, so any help on repairing this would be greatly appreciated.
Sorry to hear about your drive issues—those can be super frustrating, especially when you’ve got deadlines coming up. I’ve had similar problems before after an update, and here’s a step-by-step method that should help you out.
First off, you should start with the basics: Disk Utility. It’s built into macOS and should handle most straightforward issues.
  1. Restart your Mac in Recovery Mode by holding Cmd + R during boot until you see the Apple logo or a spinning globe.
  2. Open Disk Utility from the macOS Utilities menu.
  3. Select your corrupted hard drive from the list on the left.
  4. Click “First Aid” at the top and then “Run.”
Disk Utility will check the disk for errors and attempt to repair them. If it finds any issues it can’t fix, you might get a message saying “The volume [disk name] could not be repaired.”
If Disk Utility doesn’t solve your problem, you might want to try single-user mode with the fsck command. This is a bit more technical, but it’s worth a shot:
  1. Restart your Mac in Single-User Mode by holding Cmd + S during boot.
  2. Type /sbin/fsck -fy and press Enter.
This command will run a file system consistency check and repair utility. If it reports that the file system was modified, run the command again until you see a “The volume [disk name] appears to be OK” message.
If those two methods don’t help, you might need third-party software for a deeper dive. One of the popular choices is Disk Drill
. It’s pretty robust for data recovery on Mac.
Pros of using Disk Drill:
  • User-Friendly Interface: Easy to navigate even if you’re not tech-savvy.
  • Comprehensive Recovery: Recovers various file types, not just media.
  • Preview Functionality: Allows you to see what can be recovered before you go through the process.
Cons of using Disk Drill:
  • Cost: The full version is not free, although there is a free trial which allows some limited recovery.
  • Time: Deep scans can be quite time-consuming.
To use Disk Drill:
  1. Download and install the software.
  2. Open Disk Drill and select your hard drive.
  3. Choose the type of scan you want to perform (Quick Scan or Deep Scan).
  4. After the scan completes, browse through the recoverable files and select what you need.
  5. Recover the files to a safe location, NOT on the corrupted hard drive.
Other competitors in the data recovery space include Stellar Data Recovery and Data Rescue, but each has its own strengths and weaknesses. Stellar is known for a straightforward interface and strong customer support, while Data Rescue offers powerful deep-scan options.
It’s also important to consider the possibility of a failing hard drive. If the software methods don’t work, it might be a hardware issue, and it may be time to consult a professional data recovery service—although that can get pricey.
Lastly, I’d recommend setting up regular backups once you’ve solved this immediate problem, to avoid similar headaches in the future. Time Machine is a great built-in tool for this on macOS.
Hopefully, you’ll be able to rescue your files and get back on track with your project. Good luck!
Hey, totally get the pain of dealing with a corrupted hard drive on a Mac – been there, done that. The advice from @techchizkid is solid, and Disk Utility is indeed a great starting point. But if your issue persists, I’d suggest considering another angle that might sound unusual but has worked for me in the past.
One method often overlooked is running a Safe Boot:
  1. Shut down your Mac completely.
  2. Turn it back on holding down the Shift key.
  3. Keep holding Shift until you see the login screen. This triggers a Safe Boot, which performs a disk check and repairs certain issues.
Another layer of troubleshooting, if you’re still stuck, would be more targeted command-line tools. Using Terminal in Recovery Mode:
  1. Again, boot into Recovery Mode (Cmd + R).
  2. Open Terminal from the Utilities menu.
  3. Run diskutil list to get a list of all disks.
  4. Find your problematic drive and use diskutil repairVolume /dev/diskX where X is the number of your drive.
Sometimes, a straight-up reformat might be the end solution, but you’ll obviously lose whatever’s on the drive. As a middle ground before this drastic measure, consider creating a bootable external drive:
  1. Download macOS installer from the App Store.
  2. Use Disk Utility to erase an external drive.
  3. Create a bootable installer using Terminal: sudo /Applications/Install\ macOS\ Mojave.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume.
Boot your Mac from this external drive while keeping your internal drive unmounted to prevent further corruption attempts.
Switching gears a bit, there’s notable software called DiskWarrior that’s a bit of a legend among Mac users dealing with disk issues. It’s pricey but powerful. What it does differently than Disk Drill is more geared towards the filesystem and directory repairs, whereas Disk Drill’s strength is in data recovery. Here’s how you use DiskWarrior:
  1. Boot from macOS Recovery (Cmd + R).
  2. Download and open DiskWarrior from their official source.
  3. Let it perform directory repairs. It reconstructs the directory instead of just patching up holes.
Pros of DiskWarrior:
  • Precision Repairs: It focuses on structural repairs, sometimes more effectively, than Disk Utility.
  • Reputation: Trusted by many professionals for years.
  • Costly: Can be prohibitively expensive for a single use.
  • No Data Recovery: More about fixing than salvaging files.
As amazing as Disk Drill is for data recovery (https://www.cleverfiles.com/), if you need to delve deeper into filesystem intricacies, DiskWarrior might be your better bet. So have a go at both types of tools if one doesn’t cut it.
And don’t forget to heed @techchizkid’s advice about setting up regular backups. Time Machine is no joke for macOS users, or go hardcore with something like Carbon Copy Cloner for more control over backup schedules and destinations.
Sometimes, even a simple NVRAM reset can bring some sanity back into your Mac:
  1. Shut down your Mac.
  2. Turn it back on holding Option + Cmd + P + R together until the Mac restarts again.
Not to be a bringer of bad news, but intermittent drive failure sometimes stems from physical issues. If nothing works, consulting a pro might save you the heartache of losing data, even though it’s usually an expensive path.
Try out these additional steps and hopefully, you’ll get that deadline off your back. Best of luck!
Oh, I’ve been down this road with a corrupted Mac hard drive—it’s never fun, and deadlines just make it worse. Let’s dive in with some alternative steps and agree/disagree points:
First off, the Safe Boot method mentioned by @codecrafter can sometimes be a lifesaver but isn’t a silver bullet that fixes everything. Safe Boot actually does a directory check similar to Disk Utility but sometimes isn’t robust enough for severe corruption. But worth trying since it’s relatively quick:
  2. Power it on holding Shift until you hit the login screen.
After that’s done, if still no luck, here’s another often overlooked trick: consider resetting the SMC (System Management Controller). This little reset can fix more than you might think, especially if your computer behaves erratically:
  2. Hold Shift + Ctrl + Option + Power button for about 10 seconds.
  3. Release all keys simultaneously, then power on as usual.
This reset can sometimes clear out hidden issues, but it’s kind of a long shot in clear disk corruption cases.
As @techchizkid and @codecrafter highlighted, Disk Utility and fsck are solid go-tos. However, if those don’t work or you’re not keen on waiting for endless scans, here’s a different angle. I’d suggest using a tool like TechTool Pro before diving into DiskWarrior’s directory-focused fix:
TechTool Pro offers robust hardware diagnostics along with disk repairs. You can basically get an early heads-up if your hard drive is on the verge of a hardware failure. It’s sort of diagnostic and repair rolled into one:
  1. Download and install TechTool Pro.
  2. Perform a complete hardware test to rule out physical issues.
  3. Use the Disk Repair feature to fix logical issues.
It’s not cheap, but its diagnostic capability is solid and might save you from wasting time on software fixes if your issue is hardware-based.
I heavily agree with @techchizkid on needing regular backups. If you haven’t already, definitely set up Time Machine or even go one step further with a cloning solution like Carbon Copy Cloner. These tools let you create an exact replica of your hard drive that you can boot from, ensuring you’re never caught off guard again.
Here’s another practical suggestion: Disk Drill (https://cleverfiles.com/lp/data-recovery-software.html) not only helps recover lost files, but it also provides some disk health monitoring features. This can be a two-for-one tool: recover the necessary data now and prevent future meltdowns:
  1. Install Disk Drill.
  2. Run a deep scan to recover essential files.
  3. Use its S.M.A.R.T. monitoring feature to keep tabs on your disk’s health.
Advantages:
  • User-friendly interface.
  • Comprehensive data recovery.
  • Built-in monitoring functions.
Disadvantages:
  • Doesn’t fix directory issues as effectively as DiskWarrior.
  • Full version costs a bit.
One topic not yet mentioned is the possibility of using an external SSD with macOS installed, effectively working from there and avoiding the corrupted internal disk. This is more of a temporary fix to gain immediate access to your files and work environment until you have more time to address the core problem. You can use macOS’s built-in migration assistant to pull your critical files over:
  1. Format an external SSD using Disk Utility.
  2. Install macOS onto the SSD.
  3. Boot from the external SSD by holding Option during startup and selecting it.
Finally, if you’re really in a bind and the above methods draw blanks, remember the importance of professional services. Financially painful, but places like DriveSavers can often retrieve data from seemingly doomed hard drives.
So, in summary: try Safe Boot, reset the SMC, run TechTool Pro for diagnostics, and if all else fails, lean on Disk Drill for file recovery and S.M.A.R.T. health monitoring. It might mean shelling out some cash, but saving your project files might just justify it.
Time Machine or Carbon Copy Cloner from now on, my friend! Good luck.
