How to Screen Cast iPhone to Roku?
Hi everyone,
I’m trying to screen cast my iPhone to my Roku device, but I’m not sure how to set it up. I want to mirror my entire screen, not just stream specific videos or apps. I’ve heard that some Roku devices support AirPlay, but I’m not sure if mine does or if there are other methods I can use. Can anyone guide me on how to cast my iPhone screen to Roku or suggest any reliable apps that work well for this purpose?
Thanks in advance for your help!
To screen cast your iPhone to a Roku device, you can use the built-in AirPlay feature if your Roku supports it—simply ensure both devices are on the same Wi-Fi network and select your Roku from the AirPlay menu. If AirPlay isn’t available, you can try third-party apps like DoCast or Mirror for Roku. DoCast is user-friendly and supports a wide range of TVs, including Roku.
To screen cast your iPhone to Roku, try DoCast or AirBeamTV. DoCast is user-friendly with good quality but has time limits in the free version. AirBeamTV supports many devices but may have slight delays.
