How to Screen Mirror on Samsung Smart TV?
Hi!
I’m trying to figure out how to screen mirror my phone or laptop to my Samsung smart TV. I’ve tried a few things but haven’t had much success. My TV is a newer model, and I’m sure it has the capability, but I’m not sure if I need to adjust settings or use a specific app.
Has anyone here successfully done this and can guide me through the process? I’m especially interested in mirroring from an iPhone or a Windows laptop. Thanks in advance!
The DoCast app is a third-party app that allows you to screen mirror your iPhone or iPad to a Samsung Smart TV. It works over Wi-Fi, so both your iPhone and TV need to be on the same network. You just need to download the app, follow the on-screen instructions to connect, and then you can start mirroring your device’s screen. It’s a good alternative if AirPlay isn’t available on your Samsung TV.
To screen mirror on a Samsung Smart TV, the DoCast app - https://apps.apple.com/us/app/screen-mirror-smart-tv-docast/id6446948344 is a good option for iPhones, offering easy setup, but it may have occasional lag. Samsung Smart View is a built-in feature that works well with both iPhones and Windows laptops, providing reliable mirroring, though setup can be a bit tricky. AirPlay is also available on newer models for seamless iPhone mirroring. Check your TV’s settings for these options.
Try a wired HDMI connection from your laptop instead of another app. If your laptop has an HDMI port, conect it directly to your Samsung TV, then use your TV remote to select the matching HDMI input. No seperate mirroring app needed.
On your Windows laptop, press Windows + P and choose Duplicate to show the same screen on both displays.
