How to stream on TV from iPhone?
Hi everyone!
I want to stream content from my iPhone to my TV, but I’m not sure how to do it. I’ve heard there are a few different ways to make it work, but I’m confused about which one is best. Can anyone suggest the easiest method or an app to use? Thanks!
Use AirPlay if your TV supports it for easy, high-quality streaming directly from your iPhone. If not, Google Chromecast with the Google Home app is another option but may have slight lag. The DoCast app - https://apps.apple.com/us/app/screen-mirror-smart-tv-docast/id6446948344 is also user-friendly.
To stream from your iPhone to your TV, AirScreen is a versatile app that supports AirPlay and works with most TVs, though both devices need to be on the same Wi-Fi network. AllCast is another option for streaming media, but the free version has limited features. The DoCast app is a solid alternative, known for its user-friendly setup.
