I just switched to an Android phone and can’t figure out how to take a screenshot. I’ve tried pressing different button combinations but nothing seems to work, and the settings menu is a bit confusing. Can someone explain the different ways to capture the screen, including any shortcuts or hidden options, so I don’t miss anything important on my display?
On most Android phones the default way is:
- Press Power + Volume Down at the same time.
- Hold for about 1 second.
- Screen should flash and you get a small preview at the bottom.
If nothing happens, try this:
• Make sure you press both buttons together.
If you press Power a bit earlier it turns the screen off.
Try using two hands and press them firmly at the same time.
• Check if your phone has a different combo:
- Some Samsung phones also support Palm swipe:
Settings > Advanced features > Motions and gestures > Palm swipe to capture.
Then swipe the side of your hand across the screen. - Some older phones use Power + Home.
• Try the Quick Settings shortcut:
- Swipe down from the top to open the notification shade.
- Swipe down again to see full Quick Settings.
- Look for “Screenshot” or “Screen capture”.
- If you do not see it, tap the pencil icon or “Edit” and add the Screenshot tile.
• Google Assistant method:
- Open the screen you want.
- Say “Hey Google, take a screenshot”.
- It saves it to Photos or your default gallery.
Where to find your screenshots:
• Open Photos or Gallery.
• Go to Albums.
• Look for “Screenshots”.
If none of these work, share your phone brand and model. Some brands hide the option in special menus or use custom gestures, so the exact steps depend on your device.
If the usual button combos are making you want to launch the phone into orbit, you’re not alone. @jeff covered the “standard” routes pretty well, but a few extra angles might help, especially since different brands like to be “special.”
Check your specific brand’s quirks
Instead of randomly mashing buttons, figure out what your phone actually is:- Go to Settings → About phone → look for Brand / Model.
Then Google:
[your brand] [model] screenshot
Sadly, this is often faster than digging around menus, because OEMs hide stuff in weird places.
Three-finger / gesture screenshots
A bunch of phones have gesture-based screenshots that are off by default:- On many Xiaomi / OnePlus / Realme / Oppo devices:
Settings → Additional settings / Convenience tools / Buttons & gestures
Look for “Three-finger screenshot” or similar.
Then: swipe down on the screen with three fingers to capture.
This is usually way easier than juggling hardware buttons.
Assistive / floating button
If you hate button combos entirely:- Some phones have an “Assistive ball” or “Accessibility menu” that includes a Screenshot button.
Rough path: - Settings → Accessibility
- Look for “Accessibility menu” or “Assistive touch / ball.”
Turn it on, and you’ll get an on-screen icon you can tap → Screenshot.
Not pretty, but very useful if your buttons are stiff or you keep mis-timing the combo.
Long-press power customization
On some Android versions, long-pressing the power button can bring up more than just “Power off / Restart”:- Hold Power
- If there’s a “Screenshot” option in that menu, use that instead of the combo.
If not, sometimes in Settings → System → Gestures → Power menu, you can tweak what shows there.
Slightly disagreeing with @jeff here: I’d actually prefer this to the Quick Settings tile, since QS often takes more swipes / taps.
Scroll / extended screenshots
Once you do get a normal screenshot working, don’t miss the scroll capture:- Right after the screenshot, look at the little toolbar or preview that pops up.
- Many phones have “Scroll,” “Capture more,” or “Long screenshot.”
That lets you grab an entire chat or web page instead of taking 5 seperate shots like a caveman.
Why your combo might “do nothing”
Some reasons the Power + Volume Down trick feels broken:- Case interference: Thick or stiff cases make it hard to press both buttons at the exact same time. Try without the case once.
- Button timing: You really want simultaneous, very short press. If Power triggers first, the screen turns off. If Volume triggers first, you might just change the volume.
- Broken / mushy buttons: If one button doesn’t click well, gestures or on-screen options are your best bet.
If you share the exact brand + model, people can usually give you a 2-line, “tap here, then here” answer instead of you randomly spelunking thru Settings again.
Try the Recent Apps screen. Open the page you want, swipe up from the bottom, then pause. Tap “Screenshot” below the app preview. Your phone saves the image to Photos or Gallery.
This avoids button timing, gestures, and confusing settings. If you dont see “Screenshot,” your phone’s launcher doesnt support this option.
Realistically, the button combo will work on your phone. It almost always does. The issue is that ‘at the same time’ means within a fraction of a second, and human hands are bad at that. What usually goes wrong is you press slightly harder on power, the screen dies, and you assume the whole thing is broken. It isn’t. Try resting your finger on volume down first, then tap power a hair later while still holding volume. That order fails less often than pressing them dead even.
The three-finger swipe @nachtdromer brought up is genuinely the nicest method once it exists, but heads up that plenty of phones don’t have it at all. It’s mostly a Chinese-brand skin thing. If you’re on a Pixel or a stock-ish setup, don’t waste twenty minutes hunting for a toggle that was never there. Same goes for the recent-apps trick, that one comes and goes depending on the launcher, so it’s hit or miss.
If your hands keep losing the timing fight, just talk to it. Saying take a screenshot to the Assistant is boring but it never mis-times, never turns the screen off, and doesn’t care about a thick case. I’d keep that as your fallback and slowly get the button feel down for when you can’t talk out loud.
