I Accidentally Formatted My SD Card, Is Recovery Possible?
I accidentally formatted my SD card while moving photos and videos from my camera, and now everything appears to be gone. These files are important personal memories, and I need help figuring out if SD card data recovery is possible and what steps I should take right away to avoid making it worse.
I did this once with an SD card from a weekend shoot, and yeah, the stomach-drop feeling hits fast. I formatted the whole card when I meant to remove one junk clip. It looked cooked. It wasn’t.
What usually saves you is this. Most cameras, phones, drones, and PCs do a quick format. The files are often still sitting on the card. The index gets wiped, the space gets marked as free, and your photos or videos stay there until new data lands on top of them.
So the first move matters more than anything else. Stop using the card now. Don’t shoot more photos. Don’t record test clips. Pull it out of the device. If your SD card has the little lock tab on the side, switch it on.
I’d skip CHKDSK and random Command Prompt fixes. Those are for file system repair. A formatted card is a different mess. You want recovery software.
What worked best for me was Disk Drill. I had better results with camera and drone video there than with the free stuff I tried first. Free tools often pulled back clips in pieces, or files showed up but would not play. Disk Drill has an Advanced Camera Recovery mode, which helped with fragmented video files. The layout is easy too, so you’re not fighting the app while you’re already stressed.
If you want a free route, PhotoRec is still a decent pick. It works. It also feels old and rough. You’ll usually lose original filenames and folder structure, so sorting the output turns into a chore fast.
Do it like this:
  1. Put the SD card into a card reader and connect it straight to your Mac or Windows PC.
  2. Install the recovery app on your computer, not on the SD card.
  3. Scan the formatted card. If the missing files are videos, use Advanced Camera Recovery if your software has it.
  4. Preview what shows up. Make sure the files open before you start saving a pile of junk.
  5. Restore the recovered files to another drive, never back onto the same SD card.
If you haven’t written new data to the card, your odds are still decent. Keep the card untouched, run one careful scan, and sort through the results. That’s the best shot I know.
Yes, recovery is still possible if you stopped using the card fast enough.
I agree with @mikeappsreviewer on the big thing, stop writing anything to the SD card. I differ a bit on one point though. I would make a byte-for-byte image of the card first, before running multiple scans, if the files matter a lot. SD cards fail mid-recovery more often than people think. Work from the image, not the original, if you have the option.
A few things affect your odds:
  1. Quick format usually leaves data behind.
  2. Full format drops recovery odds hard.
  3. New photos or video overwrite old sectors. Once overwritten, those parts are gone.
  4. Cameras often split video into fragments, which is why some tools recover photos fine but choke on MP4 or MOV.
My approach:
  1. Put the card in a quality USB card reader.
  2. Check its SMART or health status if your tool supports it.
  3. Create a disk image.
  4. Scan the image with recovery software.
  5. Sort results by file signature and size, not filename. Formatted cards often lose names and folders.
  6. Recover to your computer or another drive.
For software, Disk Drill is a solid pick, esp if the card had camera video and not only JPGs. If one scan mode misses stuff, try a deeper signature scan on the image file. I would also keep expectations realistic. Photos often come back clean. Large videos are the first to come back corrupted.
If you want a simple guide, this formatted SD card recovery guide helps: how to recover files from a formatted SD card
One more thing, if the card asks to be formatted again, or disconnects on and off, stop messing with it. At tht point, software-only recovery gets riskier and a lab is the safer move.
Yes, recovery is often possible after an SD card format, but I’m gonna disagree slightly with @mikeappsreviewer and @sonhadordobosque on one thing: not every case needs a whole imaging workflow first. If the card is stable, readable, and not throwing disconnect errors, you can sometimes go straight into a recovery scan and save a ton of time.
What matters most is what kind of format happened. Quick format = decent chance. Full format or heavy reuse = way worse.
Also, don’t trust the camera saying the card is “empty.” That usually just means the file table got reset. The actual photo/video data may still be there.
One thing people forget: check whether your files were maybe copied off already into a temp import folder on the computer. Windows Photos, Mac Photos, Lightroom, even camera transfer tools sometimes leave partial imports behind. Search your computer before doing anything complicated.
If you do scan it, Disk Drill is a legit choice here, especially for formatted SD card recovery and camera/video recovery. I’d use that before trying a bunch of sketchy freeware that turns your files into a broken mess. Just recover everything to a different drive.
If the card starts acting weird, super slow reads, random disconnects, asks to format again, stop. That’s when DIY can make it worse.
Also, for anyone landing here from search, this covers the same issue pretty well: how to recover files after accidentally formatting an SD card
Short version: stop using the card, check for already-imported files on your computer, then run a proper recovery tool like Disk Drill. If nothing was overwritten yet, you’ve still got a real shot.
I’m with @sonhadordobosque, @ombrasilente, and @mikeappsreviewer on the core point: recovery is absolutely possible after a format. Where I’d push it a bit further is this: before you assume you need recovery software, check whether the card was formatted by the camera or by the computer. Camera formats are often “lighter” on the file system, and in some cases a tool can rebuild more than just raw files. PC full formats are a nastier story.
Another angle people skip: if these were important personal memories, think about file types before choosing a tool. JPEG is easy. HEIC, RAW, and long MP4 clips are harder. That matters because some apps look great in screenshots but fall apart with fragmented video or proprietary RAW formats.
Disk Drill is a reasonable option here, especially if you want something less clunky than PhotoRec.
Pros for Disk Drill:
  • Easy to use
  • Good preview support
  • Decent with photo libraries and many camera cards
  • Better interface than a lot of barebones recovery tools
  • Not the cheapest if you need full recovery
  • Deep scans can return lots of junk to sort through
  • Video recovery is not magic if footage was partially overwritten
One mild disagreement with the “scan immediately” crowd: if the card has any odd behavior at all, slow reads, freezing Explorer/Finder, vanishing mid-copy, don’t keep hammering it with repeated scans. That’s how a recoverable card turns into a dead one.
Also, don’t judge success by filenames. After formatting, recovered files often come back as generic names but still open fine. If your goal is memories, content matters more than folder structure right now.
