Need help choosing between Google Drive and OneDrive
I’m trying to decide between Google Drive and Microsoft OneDrive for everyday cloud storage, file sharing, and backups. I’ve run into sync issues, confusing storage limits, and trouble accessing files across devices, so I need real advice on which one works better, is more reliable, and offers better value long term.
I spent enough time bouncing between both of these to stop treating them like the same product with different logos. They overlap, sure. Still, they fit different habits.
If you want more opinions from regular users, I found this thread useful:
Google Drive vs. Microsoft OneDrive: Which cloud actually works better?
Price and storage
This part is easy to measure.
Google Drive gives you 15 GB free. OneDrive gives you 5 GB free. If you dump in phone photos, PDFs, tax docs, and random screenshots, that extra 10 GB goes fast and it matters.
Paid business plans are where Microsoft pulls ahead. OneDrive starts around $6 per user each month for 1 TB. Google’s lower business tier sits around $7 per user each month and only includes 30 GB. For a team, that difference is hard to ignore. For one person who wants free storage, Google feels less cramped.
One weird OneDrive detail annoyed me more than it should have. Outlook attachments count against the same 5 GB pool on the free plan. If you fill it, email starts getting messy, and Microsoft does not put this front and center when you sign up.
Which ecosystem you already live in
This is where most people end up deciding, even if they pretend they’re comparing features.
OneDrive fits neatly into Microsoft’s setup. Files move through Outlook, Teams, and SharePoint without much friction. Drive feels more at home in Google’s browser-first setup, with Gmail, Calendar, Docs, and Sheets sitting right there.
On Windows, I noticed OneDrive fades into the background in a good way. Word files open from OneDrive like they belong there, because they do. Same with Excel and PowerPoint, whether you’re in desktop Office or the web version. Google Drive handles Office files too, but I always got the sense it was standing off to the side, waiting to be invited in.
Sharing outside your bubble
This was one of the bigger surprises for me.
Sending a file to someone outside your org felt smoother on OneDrive. If they do not have a Microsoft account, they usually get a one-time code by email and get in. Done.
OneDrive also gives you more knobs to turn on shared links. Passwords. Expiration dates. Blocking downloads. Google Drive is simpler here, which sounds nice until you need those controls and they are missing.
If you share contracts, drafts, internal docs, or anything time-sensitive, this part is not small.
Big file limits
For giant files, Google Drive has the higher ceiling.
OneDrive supports files up to 250 GB each.
Google Drive supports files up to 5 TB each.
If your life is Word docs and slide decks, who cares. If you move raw video, VM images, huge project exports, or archive dumps, then yeah, you care.
Security, without the hand-waving
Both are decent here. Neither is magic.
Google Drive and OneDrive both use AES-256 for stored data and TLS for data moving between your device and their servers. Same basic idea as HTTPS in your browser. Your files sit encrypted on their side, and the trip across the internet is encrypted too.
Microsoft adds a few extras people bring up for work use. OneDrive uses BitLocker for synced local storage in some Windows scenarios, and it has Personal Vault for files you want behind another verification step.
Both also support two-factor authentication.
OneDrive supports Microsoft Authenticator, SMS, voice calls, and biometrics.
Google supports phone prompts, authenticator apps, SMS, and hardware security keys through Advanced Protection.
The part people skip over is the part I would not skip. Neither service gives you true zero-knowledge encryption by default. Microsoft and Google do hold the technical ability to access stored content under legal process or service-side handling rules. If you’re storing medical records, legal files, research data, or anything touchy, know what you’re agreeing to.
FTP and the old protocol mess
Neither Google Drive nor OneDrive supports plain FTP out of the box.
Good. FTP is old and unencrypted. I would not use it for anything sensitive.
What you do get through third-party tools is access through safer options like SFTP, FTPS, or FTPES. Those are the ones worth using if you need file transfer tooling around cloud storage.
For business setups, Microsoft says data moving into OneDrive and between datacenters is protected with TLS. Files at rest are encrypted with unique keys, with key management tied into Azure systems. Google Workspace also offers client-side encryption for Drive, Docs, Sheets, and Slides, which matters if your company wants tighter control over encryption keys instead of leaving all of it with Google.
Where I landed
If you mostly work alone, use Gmail all day, bounce between devices, or want the larger free tier, Google Drive makes more sense.
If you already pay for Microsoft 365, spend your day in Windows, or need better control over shared links, OneDrive felt easier to live with.
Both worked. I did not come away thinking one destroys the other. I came away thinking people pick the wrong one when they ignore the ecosystem part and stare only at storage numbers.
I’d split this by your pain points, not by brand.
If sync bugs are your main issue, OneDrive tends to behave better on Windows. Files On-Demand is solid. Finder on Mac is more mixed. Google Drive feels smoother in a browser and across Android devices, but I’ve seen its desktop app get weird with large folder trees.
On storage limits, Google is easier for free use. 15 GB beats 5 GB. I agree with @mikeappsreviewer there. I disagree a bit on sharing though. Google Drive is less fussy for quick sharing with non-tech people. OneDrive has more controls, but more knobs also means more ways to set it wrong.
For backups, I would not treat either as your only backup. Sync is not backup. Delete a file locally, and sync might delete it everywhere. Keep a second copy on an external drive or Backblaze or somthing similar.
My short version:
Google Drive for personal use, mixed devices, easy sharing.
OneDrive for Windows, Office files, and if you already pay for Microsoft 365.
If you say which devices you use, people here can be more specific.
I’d split it by what keeps annoying you most, not by brand loyalty.
If your biggest issue is access across devices, Google Drive usually feels less “stuck” because it’s more browser-native. Open a tab, sign in, your stuff is there. OneDrive is fine too, but it really shines when your life already revolves around Windows + Office. On an iPhone, Android tablet, Mac, work PC mix, I’d lean Google.
Where I kinda disagree with @yozora a bit: OneDrive sharing controls are better, yes, but for normal humans that can also become “why can’t my mom open the file” territory. Google Drive is dumber in a useful way. Fewer options, fewer chances to misclick a permission setting.
For sync issues, my personal experience:
  • OneDrive is more stable on Windows
  • Google Drive is less annoying in a web-only workflow
  • both can get weird with giant folders and lots of tiny files
For backups, neither should be your only backup. This is where people get burned. Sync is convenience, not backup. If ransomware, accidental delete, or corrupted files happen, cloud sync can happily spread the damage everywhere. So yeah, use one of them, but keep another copy too.
My blunt version:
  • Pick OneDrive if you use Windows every day, Office docs matter, and you already pay for Microsoft 365.
  • Pick Google Drive if you want simpler access, better free space, mixed devices, and less fiddly sharing.
Also, @mikeappsreviewer is right to call out storage confusion. Microsoft’s free storage feels tiny way faster than you expect. That part alone makes OneDrive hard to reccomend for casual personal use unless you’re already in the Microsoft ecosystem.
If you want the least headache for everyday personal stuff, I’d probly say Google Drive. If you want the best fit for a Windows/Office household, OneDrive.
I’d decide based on your “failure mode,” not just features.
If your biggest frustration is files not showing up where you need them, Google Drive is usually less stressful on mixed devices because the web app is the real product. OneDrive still feels best when the device itself is part of the Microsoft setup. That sounds small, but it matters a lot when switching between phone, laptop, and browser.
Tiny disagreement with @yozora and @mike34: I do not think OneDrive is automatically the better choice just because you use Windows. It is better integrated, yes. Better for you, not always. I’ve seen people get tripped up by Known Folder Backup, desktop syncing, and the way local vs cloud status icons are explained badly. Google Drive is less “native,” but sometimes that makes it easier to understand.
My rough rule:
  • pick Google Drive if you want simpler everyday storage
  • pick OneDrive if Office is central to your life
  • pick neither as your only backup
What I’d compare before choosing:
  1. File types
    If you mostly store photos, PDFs, scans, and random personal files, Google Drive feels cleaner.
    If you constantly edit Word, Excel, and PowerPoint, OneDrive is more natural.
  2. Sharing habits
    Google Drive wins for “send this to family/friends fast.”
    OneDrive wins if you care about tighter permission controls.
    That said, more controls also means more chances to break access, which @mikeappsreviewer touched on indirectly.
  3. Storage anxiety
    Google’s free tier is just easier to live with.
    OneDrive free space disappears fast, especially if your Microsoft account is doing double duty.
  4. Recovery
    Check version history and recycle bin behavior before committing. That matters more than people think after accidental overwrites.
Pros for the ‘’:
  • easy access from anywhere
  • helps centralize files and cut device clutter
  • can simplify sharing and light backup workflows
Cons for the ‘’:
  • sync confusion can still happen
  • not a true backup by itself
  • storage tiers and permissions may still be annoying depending on platform
If you want the least annoying default for personal use, I’d lean Google Drive. If you already pay for Microsoft 365, OneDrive probably makes more financial sense than starting fresh somewhere else.
