I’m struggling with dead zones and weak WiFi in a few rooms, and my current router doesn’t cover the whole house. I’m confused by all the different WiFi extenders, mesh systems, and repeaters on the market. What should I look for in a WiFi extender, and which models actually work well for improving coverage and speed without constantly dropping the connection?
Short version. If you own the router and can move it, do that first. If not, you pick between:
- Cheap WiFi extender / repeater
- Powerline + WiFi
- Proper mesh system
Here is how to choose without going nuts.
- Check your house size and walls
- Under 1,500 sq ft, light walls: a single decent dual band extender usually works.
- 1,500–3,000 sq ft or concrete / brick walls: mesh or powerline with WiFi access point works better.
- More than 3,000 sq ft: go mesh and stop fighting it.
- Single extender vs mesh
- Pros: cheap, easy, plugs in a wall outlet.
- Cons: speed often drops by 50 percent on the extended network. Sometimes uses a different SSID, so devices jump between networks.
- Look for:
- Dual band at least, WiFi 5 or WiFi 6.
- Ethernet port, so you can use it as a wired access point later.
- Same brand as your router helps, but not required.
Mesh system
- Pros: one network name, better roaming, more stable in bigger homes.
- Cons: costs more, needs at least two or three units for full coverage.
- Good picks: TP Link Deco, Eero, Asus AiMesh, Google Nest Wifi.
- If you do much video calling or gaming in those dead rooms, mesh pays off fast.
- Router location
Before spending money:
- Place router in a more central spot if possible.
- Keep it away from thick walls, metal racks, aquariums, and microwaves.
- Put it higher, not on the floor.
Use a WiFi heatmap so you know where the signal dies
Most people guess where to put extenders and then complain when it sucks.
Use something like NetSpot to map your WiFi. It shows you signal strength per room, so you know exact weak areas and where to place extenders or mesh nodes.
Link here: analyzing and improving your home WiFi coverage -
Concrete upgrade paths
If you want to spend as little as possible:
- Get 1 dual band WiFi 5 or WiFi 6 extender with Ethernet port.
- Plug it about halfway between router and dead room, not in the dead room.
- Use the same SSID and password as your main WiFi if the extender allows that.
If you want stable, whole home coverage:
- Turn off WiFi on your existing router, keep it only as modem or gateway if needed.
- Buy a 2 or 3 node WiFi 6 mesh kit.
- Put one node near the modem, one near the center of the house, one upstairs or near the far rooms.
- Use a wired backhaul if you have Ethernet in the walls, speeds get much better.
If your house wiring is ok and power outlets are on the same phase:
- Use a powerline adapter kit with WiFi AP.
- Main adapter near router, second one in the dead zone room.
- Good for houses where wireless signal drops hard due to walls.
- What you should check before buying
- Internet speed from your ISP. No point buying WiFi 6E kit for a 50 Mbps plan.
- Number of devices in your home. More than 15 devices online at once, mesh is safer.
- What matters more to you, speed or cost.
Simple rule of thumb:
- Apartment or small home, few users: WiFi extender.
- Average home, many users and streaming: mesh.
- Thick walls, no Ethernet: powerline + WiFi or mesh with extra nodes.
If you tell the router model, house size, and internet speed, people here can give more precise suggestions.
Short version: don’t buy anything yet. First figure out where your WiFi actually sucks and why, or you’ll just be collecting plastic bricks.
@stellacadente covered the main “what to buy” paths pretty well. I’ll disagree on one small thing though: I don’t think “house size” alone is a great guide. I’ve seen tiny apartments with garbage coverage because the router was buried behind a TV in a metal cabinet, and 2‑story homes that were fine with one good router placed well.
Here’s how I’d approach it, skipping the stuff they already said:
1. Check if your current router is the real problem
Before extenders/mesh/repeaters:
- How old is the router? If it’s some ISP box from 2016 running WiFi 4 / 802.11n, a single modern WiFi 6 router in a good spot often beats a cheap extender tacked onto junk.
- Look at the antenna layout and placement. If it’s stuck:
- On the floor
- Inside a TV stand
- Next to a giant aquarium, mirror, or fridge
It doesn’t matter what extender you buy, signal will still be trash.
Sometimes spending ~$100 on a solid WiFi 6 router helps more than stacking $40 extenders on top of a bad base.
2. Actually map the dead zones instead of guessing
This is where most people go wrong and then blame “WiFi extenders” in general.
Install a WiFi survey tool, walk around, and see where the signal nosedives. NetSpot is really good for this kind of thing, on both Mac and Windows. It lets you:
- Draw your floor plan
- Walk your house
- Get a color‑coded map of signal strength
That way you know if the issue is:
- Just one far bedroom
- A vertical problem (upstairs vs downstairs)
- A specific wall (concrete, chimney, etc.)
If you’re curious, check out something like
boosting your home WiFi coverage step by step
to visualize your coverage before buying gear.
3. Decide based on backhaul, not just “extender vs mesh”
Everyone talks about “WiFi extender vs mesh,” but the real decider is: how do the nodes talk to each other?
Wireless backhaul
Nodes talk to each other over WiFi. Easy, but cuts into total bandwidth. Modern WiFi 6 mesh systems handle this better than random cheap extenders. -
Wired backhaul (Ethernet)
If you have Ethernet in the walls, or can run a couple of cables, this is king. You can:- Use a basic access point or old router in AP mode instead of fancy mesh
- Or use mesh nodes but they’ll run at full speed
Powerline backhaul
Here’s where I slightly disagree with @stellacadente: powerline is extremely hit‑or‑miss. In some homes it’s great, in others it’s just another headache. It depends on:- Electrical wiring age
- Noise from appliances
- Whether the outlets are on the same circuit / phase in practice
I’d treat powerline as “last resort if WiFi cannot cross your walls and you can’t run Ethernet.”
If you can run even one Ethernet cable to the worst area, a wired access point or mesh node there will usually beat a random extender.
4. Picking the actual gear, with your sanity intact
Use this logic tree:
One or two rooms weak, rest of house fine
- Try a single WiFi 6 extender, but:
- Buy one with Ethernet port
- Place it where your router signal is still strong, not in the dead spot
- If it supports it, use same SSID & password
If you hate roaming glitches or see weird device behavior, that’s your sign to graduate to mesh.
Multiple rooms or floors flaky, lots of devices
- Go for a modest WiFi 6 mesh kit (2 or 3 nodes)
- Ignore 6E unless you already have lots of 6E devices or >1 Gbps internet
- Do not cheap out to a WiFi 4/5 mesh just to “save” $30
You stream, game, or work from the problem rooms
- Lean toward mesh or a wired AP
- Classic repeater/extender is fine for casual browsing, but latency and speed drops will annoy you if you do Zoom or gaming in those rooms
5. A word on ISP combo boxes
If your router is the ISP’s all‑in‑one box:
- Check if you can:
- Put it in “bridge mode”
- Or at least turn off its WiFi and use your own router/mesh
- Many mesh kits work fine just plugged into the ISP box, but double‑NAT can break some games / VPNs. Not always, but enough to be annoying.
If your ISP box has trash WiFi, trying to fix everything with extenders is like putting a turbo on a 20‑year‑old minivan.
6. What I’d do if I were in your shoes
Assuming:
- Normal‑sized house
- A few dead rooms
- Current router is middle‑aged or ISP‑provided
I’d:
- Use NetSpot or a similar tool to map coverage so I know where the weak zones and strong zones really are.
- If router is old or ISP junk, replace it with a solid WiFi 6 router in a better central location and test again.
- If there are still weak spots:
- If it’s just one corner room and budget is tight: grab a decent WiFi 6 extender.
- If multiple spots: get a 2‑ or 3‑node WiFi 6 mesh, turn off WiFi on the ISP box, let the mesh handle everything.
If you post your router model, internet speed, approximate house size, and what’s in the dead rooms (TV, work laptop, gaming, etc.), people can point you at specific models instead of guessing.
Skip the extender vs mesh debate for a second and think in terms of “diagnose first, buy once.”
1. Actually measure, not guess
Both @reveurdenuit and @stellacadente mentioned mapping, but I’d lean even harder on that. Before you buy hardware, install something like NetSpot on a laptop or Mac and walk your place:
Pros of NetSpot:
- Visual heatmaps so you literally see where signal drops.
- Helps you find the best outlet for an extender / mesh node instead of “that empty socket by the plant.”
- Lets you compare before/after if you upgrade gear.
Cons of NetSpot:
- Takes 15–30 minutes to do a decent survey.
- Desktop only, so not as quick as waving a phone app around.
- Can be overkill if you just have one small dead corner and do not care about fine tuning.
Competitors tend to gloss over this and go straight to “buy this model.” Using NetSpot once keeps you from playing extender roulette.
2. How this changes what you buy
Once you see the map:
- If the signal is strong almost everywhere and just one corner is weak, a cheap dual band extender really might be enough.
- If you see a clear “wall of red” cutting the house in half, extenders will fight that same wall. At that point, either:
- One mesh node just past that wall, or
- A wired access point / mesh node if you can run a single Ethernet cable.
I slightly disagree with the heavy focus on “house size” others mentioned. The heatmap will tell you more in 5 minutes than square footage guesses ever will.
3. Concrete playbook using NetSpot data
- Run a quick survey with NetSpot.
- Identify:
- Strong area near the router.
- Last place where signal is still decent on the way to the bad room.
- Place your extender or mesh node in that “last good” zone, not inside the dead room.
- Re‑survey. If the new map still shows big gaps or weird holes, that is your sign that a single extender is not enough and you should step up to mesh or a wired node.
So instead of “which extender should I buy,” the better question is “what does my current signal actually look like?” A 20 minute run with NetSpot gives you that answer and keeps you from stacking random extenders that never quite fix the problem.
Try moving your existing router befor buying hardware or installing survey software. Place it on an open shelf, closer to the rooms with weak coverage, ideally near your home’s center. Keep it away from metal cabinets, large appliances, and enclosed cupboards.
Then test your usual activities in each problem room, such as a video call or streaming a show. Use the same device each time. If your conection stays stable after the move, hold off on buying an extender.
Half the extender complaints I see come down to one thing nobody warned the buyer about: your phone doesn’t automatically jump to the stronger signal. It latches onto whatever it connected to first and holds on until that signal basically dies. So you walk from the living room into the dead bedroom, the extender is sitting right there pumping out a strong signal, and your phone is still clinging to the weak router bars from two rooms back. People then say ‘the extender did nothing,’ when really their device just refused to switch. Same SSID doesn’t fully fix it either, phones are stubborn about handoff.
That’s actually the strongest argument for mesh over a plain extender, and I think it got undersold above. Decent mesh systems do band steering and nudge your devices onto the closest node. A cheap repeater doesn’t, so you end up toggling WiFi off and on just to force a reconnect. If you mostly sit still in each room it won’t bother you. If you wander around on a call, it will drive you up the wall.
@codecrafter is right that moving the router first is free and worth doing, but I’d add the thing people forget while testing: your dead zone might not be about distance at all. It can be your neighbors parked on the same channel. In an apartment stack especially, five routers all fighting over the same 2.4GHz channel will tank your speed no matter where you put your box. When you run NetSpot or whatever, look at the channel overlap view too, not only the coverage colors. Sometimes the fix is just forcing your router to a clean channel and the ‘dead zone’ quietly comes back to life.
One more realistic expectation: if the far room is for a TV or a desktop that never moves, stop thinking wireless entirely. A single Ethernet run plus a cheap old router in access point mode will beat any extender and most mesh nodes, for less money. Wireless gear is for things that move. Stuff that sits in one spot should be wired if you can manage it at all.
So my order would be: clear the channel and reposition first, wire anything stationary if you can, and only then decide between a repeater (fine if you don’t roam) and mesh (worth it the moment handoff annoys you).
