I lost my Hisense TV remote and need a free iPhone app that actually works as a replacement. I tried a couple of iOS remote apps, but they either would not connect or asked for payment after install. Looking for help finding a free Hisense TV remote app for iPhone that is reliable and easy to set up.
If you want a free Hisense TV remote app on iPhone, the right pick depends on what system your TV is running. I ran into this with a Hisense set in the bedroom, and the app situation was messier than I expected.
https://apps.apple.com/us/app/tvrem-universal-tv-remote/id6746162794
This one felt like the least annoying option because it works across more than one Hisense platform. A lot of apps only match one OS, then you install it and figure out your TV uses something else. Bit of a waste.
What stood out to me with TVRem:
Supports Hisense Google TV
Supports Hisense Fire TV
Supports Hisense Roku TV
Pairs over Wi-Fi pretty fast when your phone and TV are on the same network
Gives you the usual remote controls, navigation, volume, channel switching, playback, and the rest
Has touchpad controls, which I found easier for menus
Includes a keyboard, so typing into YouTube or Netflix is less painful
Layout is simple, no hunting around for basic buttons
Also works with other TV brands, if you’ve got a mixed setup at home
Free features were available without gutting the app
The main reason I’d point people there is simple. If you do not know whether your Hisense is running Google TV, Fire TV, or Roku TV, this app has a better shot at working on the first try.
Universal Remote TV Smart
I tried stuff in this category too. It handles basic remote functions and it supports a bunch of brands, including some Hisense models. My issue was the experience felt more generic. It worked, though it didn’t feel tuned for Hisense sets.
VIDAA
This one is a different case. It is meant for Hisense TVs running VIDAA OS.
If your TV uses VIDAA, this app makes sense and it should do the job fine. If your Hisense runs Google TV, Fire TV, or Roku TV, then this is mostly the wrong lane. Newer Hisense TVs often ship with those platforms instead, so checking your TV settings first saves time.
For most people, TVRem seems like the safer pick because it covers the widest spread of Hisense TVs and includes the stuff people miss first when the physical remote goes missing, touch controls, keyboard entry, and standard remote buttons.
VIDAA fits one specific group, people with a VIDAA-based Hisense TV. If you want one free iPhone remote app with broader Hisense support, including different Hisense systems, TVRem is the more flexible option.
I’d split it by TV OS first, because most “free” iPhone remote apps fail there.
If your Hisense is Roku TV, use the official Roku app. It’s free, stable, and works better than most third-party stuff. If your set is Fire TV, use the Amazon Fire TV app. If it’s Google TV or Android TV, try Google TV on iPhone. Those three usually beat random remote apps.
I slightly disagree with @mikeappsreviewer on one part. Universal apps are fine for a fast try, but the official app for your TV system often connects faster and nags less.
If your Hisense runs VIDAA, then yeah, a VIDAA-focused app makes more sense.
Quick check:
Settings, Device Preferences, or System.
Look for Roku, Fire TV, Google TV, Android TV, or VIDAA.
Also, your iPhone and TV need the same Wi-Fi. A lot of failed pairing issues come from this. I missed that once and felt dumb lol.
If you want one app to test first, a universal one is fine. If you want the best free option, match the app to your TV OS. That’s the part people skip.
I’d actually start one step earlier than @mikeappsreviewer and @cacadordeestrelas suggested: make sure your Hisense even supports network remote control right now. A lot of people get stuck because the TV was fully powered off, not in standby, or “TV Control by Mobile Apps” is disabled somewhere in settings. Then every app looks broken.
Also, if your iPhone has never been paired before, some Hisense models want the first connection confirmed on the TV screen. Kinda hard when the remote is gone, which is super annoying.
A couple things that helped me in this exact mess:
- Try the built-in remote inside a streaming app if you use one already, like Roku or Fire TV
- Check if your TV is connected by ethernet while your iPhone is on Wi-Fi. Usually fine, but some router settings can still block discovery
- Restart the router, not just the TV. Sounds dumb, but it fixed mine
- If your Hisense supports Apple AirPlay/HomeKit, add it in the Home app. Sometimes you can at least wake it or control playback there
My honest take: truly free iPhone remote apps are rare now. Most are “free” until you tap volume once lol. If you want no nonsense, the official app for the TV platform is still the least scammy route. If none connect, it may not be the app, it may be the TV settings. That part gets skipped alot.
I’m with @cacadordeestrelas on checking the TV system first, but I’ll push back a little on the “official app only” idea. Sometimes official apps are great, sometimes they are weirdly limited if your exact Hisense variant is old, rebranded, or half-updated.
What I’d do instead:
- Figure out whether your Hisense is Roku, Fire TV, Google TV, Android TV, or VIDAA.
- If you know it already, use the matching official app first.
- If you do not know, try a universal app like TVRem before wasting time installing three separate apps.
Why TVRem is worth a shot on iPhone:
- Pros: broad Hisense support, simple layout, keyboard input, touch controls, free basic use, works with mixed-brand homes
- Cons: universal apps can be less reliable than the exact official app
Where I agree with @andarilhonoturno and @mikeappsreviewer is that connection failures are often not the app’s fault. One extra thing people miss: if your TV was removed from power recently, it may boot into a state where network wake is disabled until you turn it on once manually.
Two workarounds nobody mentioned much:
- Try the physical power button under the TV bezel to get it fully on before pairing
- If you have a game console or streaming box connected with HDMI-CEC, its remote might control enough to navigate settings
So yeah, official app if you know the OS. TVRem if you want one quick free test across multiple Hisense types.
The replies already cover apps and Wi-Fi checks. I’d try a different route before installing anything else.
If you have a cable or satellite remote, check its manual for TV programming and Hisense codes. Hisense documents this option for supported models. Follow your remote’s setup steps, then test power and volume.
Use a remote you already own, so theres no extra purchase. Check compatibility first, tho, and test the arrow keys and OK button before relying on it for menus.
Set your expectations low on the ‘free and clean’ part. Most of these iPhone remote apps are ad funded, so even the ones that connect will throw a popup the second you tap volume or try to close them. That is not a scam exactly, it is just how the free tier pays for itself. If an app actually controls your TV and only bugs you with the odd ad, that is about as good as it gets right now.
The point @andarilhonoturno raised about the first pairing needing confirmation on the TV screen is the real wall here, and I think it is bigger than the app choice. On a lot of Hisense sets the very first phone connection pops a prompt you have to accept with the physical remote. No remote, no accept, no pairing. If your TV runs Roku, you can usually get around that because the Roku app pairs over the network without an on screen yes. Google TV and Fire TV are more hit or miss depending on how locked down the set is.
So before you install a fourth app, check two things. Whether the TV is fully on, not sitting in a standby state where network wake is off, and whether mobile app control is actually enabled in settings. If you cannot even reach settings because the remote is gone, that is the trap, and no app fixes it.
Honestly, for the pairing-confirmation case, the fastest route is a cheap generic Hisense replacement remote. You can grab one for a few dollars and it just works out of the box, no Wi-Fi, no account, no ad nag. Use it once to flip on mobile app control, and then switch to a phone app if you still want one. The universal apps like TVRem are a fine quick test if your TV happens to allow silent pairing, but I would not keep buying time fighting app after app when a basic physical remote sidesteps the whole mess.
One small thing people skip: a lot of Hisense models respond to a plain infrared universal remote too, so if you already own one from an old cable box or a cheap all-in-one, program it with the Hisense code before spending anything. Test power and volume first, then the arrow keys, since IR remotes sometimes nail power but miss menu navigation.
