Need help fixing issues in my mobile app
I’m running into bugs and performance issues in my mobile app after a recent update. Some features are crashing, and load times are much slower than before. I’m not sure if it’s my code changes, dependencies, or build settings causing this. Can someone guide me on how to properly debug and optimize my mobile app so it runs smoothly again?
First thing, collect data instead of guessing.
  1. Add logging and crash reports
  • If you use Crashlytics or Sentry, check new crashes by version.
  • Compare stack traces with your last commit diff.
  • Log screen load start and end timestamps. Measure load time in ms, not vibes.
  1. Check what changed in the update
  • Dependencies: look at package.json / pubspec / Gradle / CocoaPods diff.
  • Turn off new features behind flags.
    • If performance gets better, you know the culprit lives in new code.
  • Roll back one dependency at a time to the previous version.
  1. Profile on a real device
  • Android Studio profiler or Xcode Instruments.
  • Look for:
    • High CPU usage on main thread.
    • Long GC pauses.
    • Massive object allocations in one frame.
    • Big network requests on app start.
  • Watch FPS / frame time. Anything over 16 ms per frame hits smoothness.
  1. Check common perf killers
  • Heavy work on UI thread:
    • JSON parsing, encryption, image decoding should go to background threads.
  • Overdraw in layouts, too many nested Views or recompositions.
  • Large images with no caching. Use caches for images and API data.
  • Unbatched network calls at startup. Group calls or lazy load after first screen.
  1. Verify build configs
  • Compare your release and debug configs.
    • Minify / Proguard / R8 changes.
    • Different JS bundle or Hermes config if React Native.
  • Turn on “Enable strict mode” in dev to catch main thread violations.
  1. Narrow crash causes
  • Reproduce on a clean install. Then again on an update install.
  • Try with and without old local data.
    • If only updated installs crash, you likely broke a migration.
  • Check nulls from API changes, removed fields, or changed types.
  1. Binary search your own change
    If your repo history is clean, use git bisect.
  • Mark last good commit, mark bad commit.
  • Let bisect find the exact commit that broke perf or stability.
  1. Quick triage plan
  • Step 1: Get crash logs and perf numbers.
  • Step 2: Turn off new features behind flags.
  • Step 3: Profile hot screens.
  • Step 4: Revert or patch the single worst offender.
If you share stack traces, platform (iOS / Android / RN / Flutter / native), and which screen feels slow, people here can point at more specific fixes.
If the app suddenly regressed after an update, I’d treat this less like “optimize” and more like “incident response.”
@nachtdromer covered the classic profiling & logging side really well, so I’ll hit some different angles:
1. Confirm it’s actually the new build, not data or backend
Recent update + crashes + slow loads can easily be:
  • A backend change that only the new client triggers
  • A data / schema issue that only appears once users have “old data + new app”
Try:
  • Install previous APK/IPA on a test device that already has the new version’s data.
    • If the old version is also slow or broken now, your backend or stored data is the real culprit.
  • Hit your backend with tools like Postman/Insomnia and check response times and payload sizes.
    • Look for a single endpoint that suddenly returns way more data or nested JSON.
If your backend got slower, you can stare at the app all day and never fix it.
2. Watch for “hidden” migrations and version checks
Stuff people forget:
  • DB migrations (Room/CoreData/Realm/SQLite) that:
    • Run on app start
    • Are O(n²) by accident
    • Block the main thread “just for a moment” which becomes 3–10s on real devices
  • “First launch after update” logic:
    • Resyncs everything
    • Re-downloads full media
    • Rebuilds caches or indices
To test this:
  • Clear app data, then install new version and check startup time.
  • Update from old version → new version and compare.
  • Temporarily skip migrations and heavy “first run after update” tasks by early returning behind a flag. If perf magically improves, you know the problem is in that path.
3. Check for “helpful” new features that run constantly
Typical silent killers:
  • New global listeners:
    • Network reachability observers
    • Auth state observers
    • Location / sensor listeners
    • App lifecycle subscribers
If any of these run expensive callbacks every few seconds or every frame, you’ll see sluggishness and maybe memory churn.
Look through your last diff for “evergreen” code:
  • setInterval / Timer / Handler.postDelayed loops
  • Lifecycle hooks like onResume, onAppear, useEffect without correct deps
  • Global event buses or notification listeners that never unsubscribe
Comment them out temporarily and see if the app suddenly feels normal again.
4. Memory & leaks angle instead of just CPU
Profiling CPU is nice, but a lot of “slow and crashy after some use” issues are memory-related:
  • New screen creates big objects and never releases them
  • New image loading path leaks references to Activities / ViewControllers
  • Caching logic that never evicts
Symptoms:
  • App OK on first launch, then gradually more sluggish
  • Crashes happen after some navigation or after leaving the app in background for a while
Try:
  • Navigate through the app for 5–10 minutes while watching memory usage climb.
  • Use the memory profiler / Instruments’ Allocations & Leaks.
  • Specifically look for:
    • Repeated instances of the same screen class not being freed
    • Large bitmaps / decoded images sticking around
If you see a staircase memory pattern, you have leaks.
5. Don’t blindly trust “release = faster”
I slightly disagree with relying too much on the typical “release build will be fine” idea. Sometimes:
  • Minification / R8 / Proguard breaks reflection or dynamic DI
  • Symbol stripping changes behavior in native libs
  • Different JS engine usage between debug and release (React Native / Flutter) can turn small issues into runtime bombs
So compare:
  • Debug vs release behavior side by side:
    • Is only release crashing? Check for:
      • Reflection-based frameworks
      • Serialization libraries that rely on field names
  • Statically link vs dynamically link changes (iOS frameworks) if you touched build settings
If you updated tooling (Gradle, Xcode, SDK), treat those like suspects too, not just your own code.
6. Check your “nice to have” visual tweaks
Last releases often add “little” UI niceties that absolutely wreck performance:
  • Blurs, drop shadows, gradients layered over complex lists
  • Animated backgrounds or parallax
  • High frequency animations updated in onDraw / onLayout / global recomposition
Turn off:
  • Complex list decorations
  • Live shadows / blur views
  • Any animation that runs continuously instead of on user interaction
If scrolling suddenly becomes smooth, you know it’s cosmetic stuff, not business logic.
7. Validate that you didn’t change default behaviors
Some sneaky changes:
  • New network client default timeouts or retry strategy
    • Now every slow call retries 3x, which looks like “slow app”
  • Switched from lazy loading to eager loading:
    • Pre-fetching a ton of data on app start “to be fast later” but killing initial load time
  • Changed image decoding options:
    • Decoding full-resolution images on main thread now
Compare config files:
  • Network client / HTTP library config diffs
  • Image loader config (caching, decode format, placeholders)
  • Feature flags around “preload”, “warmup”, “prefetch”
Sometimes just flipping a prefetch back to lazy loading is the big win.
8. Reproduce like a user, not a dev
Engineers tend to test:
  • Fresh install
  • Ideal network
  • New phones
Try:
  • Mid-tier or low-end device
  • 3G / throttled connection
  • Dirty app state: old cache, partial downloads, user logged in for a long time
You might find the slow path is “user has 10k records” or “user with half-updated data from the previous version,” which you’ll never see on a clean simulator.
If you can share:
  • One stack trace from a top crash
  • One “slow screen” with what it loads on start (API / DB / images)
  • Whether the issue happens mostly after an update vs fresh install
you’ll get more targeted suggestions than just “profile & log everything” like @nachtdromer mentioned.
Short version: you’re past the “guessing” phase. You now need to remove variables and stabilize the release, not just profile endlessly.
Here’s how I’d tackle it, trying not to repeat what @cacadordeestrelas and @nachtdromer already covered.
1. Treat this as a broken release, not a tuning problem
Profiling and logging are great, but if real users are already hurting, your priority is:
  1. Stop the bleeding
  2. Buy time to investigate
Concrete moves:
  • Ship a “stability hotfix” that:
    • Disables the riskiest new features with feature flags.
    • Wraps the most used entry points in defensive guards (null checks, try/catch with sane fallbacks).
  • Add a kill switch for heavy background tasks via remote config so you can turn them off without a new build.
This is less elegant than deep root cause analysis, but it keeps ratings and churn from spiraling while you debug.
2. Create two minimal repro builds
Instead of endlessly inspecting your full app:
  1. Perf repro build
    • Start from current HEAD.
    • Strip everything that is not used in the first slow screen:
      • Remove experiments, analytics, fancy UI, unnecessary startup services.
    • If this trimmed build is suddenly fast:
      • Reintroduce things in small chunks until perf regresses.
    • If it is still slow:
      • You know the bottleneck is in the core path, not “extra” features.
  2. Crash repro build
    • Comment out or stub anything touching:
      • DB migrations
      • New network endpoints
      • New 3rd‑party SDKs
    • Keep just the navigation to the crashing feature.
    • Gradually re-enable those systems one by one until it crashes again.
This beats trying to reason about a gigantic diff. You are effectively hand-rolling a targeted “bisect” that is easier to manage than pure git bisect when you have env or data dependencies.
3. Suspect third party SDKs and “SDK creep”
One thing I do disagree with a bit from the other replies is how much they emphasize your own code. After a big update, I put 50% suspicion on dependencies, especially:
  • Analytics and attribution SDKs
  • Ad SDKs
  • In‑app messaging / remote config packages
  • “Convenience” wrappers for networking or images
Patterns to look for:
  • New SDK initialized in Application / AppDelegate or root of your React Native / Flutter tree.
  • SDK that auto-starts:
    • Session tracking
    • Periodic pings
    • Heavy disk I/O for “smart caching”
Quick check:
  • Temporarily stub the SDK init calls with no‑ops.
  • Comment out or feature‑flag their usage.
  • Build a branch where all nonessential SDKs are removed from the build.
If that fixes both perf and stability, the next step is to bring each SDK back, one at a time, with conservative config (no aggressive prefetching, less logging, etc.).
4. Validate the app lifecycle behavior
Things that look harmless in code reviews but wreck real devices:
  • Work scheduled in onStart / onResume / viewDidAppear instead of one‑time init.
  • React / Flutter / RN hooks firing on every re-render due to missing dependency arrays or improper keys.
  • Global singletons that keep observers alive forever.
Checklist:
  • Confirm heavy tasks run exactly once where intended.
  • Ensure observers are removed in onStop / onDestroy / equivalent unmount hooks.
  • Watch for “cleanup on background” logic that actually does big I/O when the app goes to background.
Try an experiment: navigate in circles between 2 or 3 key screens for 5 minutes. If memory or CPU usage keeps ramping, you likely have lifecycle or listener leaks, not just “slow code.”
5. Add user-centric safeguards
Besides technical tuning, add protections that make the app feel less broken even before you fully solve it:
  • Time-box expensive operations
    • If a data sync or rebuild takes longer than X seconds, cancel and show partial data with a “refresh” button instead of blocking the screen.
  • Progressive loading
    • Show UI shell immediately, then load data in clearly separated chunks.
  • Graceful degradation
    • If a new, heavier layout is laggy, temporarily fall back to the old simpler layout for large datasets or low‑end devices.
This shifts the experience from “stuck / crashed” to “works but with some limitations,” which is much more tolerable while you fix the core issues.
6. About tooling & comparison with others
You already got strong advice:
  • @cacadordeestrelas went deep on basic observability and code diff analysis.
  • @nachtdromer pulled in good angles on backend impact, migrations, and leaks.
Where I’d push slightly differently:
  • Do not over-invest in elaborate profiling traces before you:
    • Strip the app to a minimal repro.
    • Temporarily remove nonessential SDKs.
  • Do not assume that fixing one hot path is enough. If the update touched build tools, SDK versions, and app logic all at once, you may have multiple moderate regressions that add up.
If you can paste:
  • One crash stack trace
  • The name of the first screen that became slow
  • The main dependencies you updated in this release (e.g., “image lib X from 3 → 4, analytics Y from 1.2 → 2.0”)
it should be possible to pinpoint 1–2 likely culprits instead of hunting in the dark.
