Need help picking a reliable VPN app for privacy and streaming
I’m trying to choose a VPN app that’s safe, truly private, and fast enough for streaming, but the reviews online are confusing and often sponsored. I’d really appreciate honest recommendations based on real experience, plus any tips on what features or settings I should focus on to stay secure without slowing my connection too much.
I went through the same mess with sponsored reviews. Here is what worked for me and what I’d avoid.
My priorities:
  1. No logs.
  2. Works with Netflix / Prime / etc.
  3. Decent speed.
  4. Not owned by some shady ad company.
Good options from my use:
  1. Mullvad
  • Jurisdiction: Sweden, strong privacy culture, but part of 14 Eyes.
  • No email needed. You get a random account number and pay.
  • Accepts cash and crypto.
  • Open source apps. Independent audits.
  • Great for privacy, torrenting, general use.
  • Streaming is hit or miss. Netflix sometimes works through certain servers, often breaks.
  • Speeds: on 500 Mbps line, I usually see 350 to 430 Mbps with WireGuard.
    Pick Mullvad if privacy is top priority and streaming is “nice to have”.
  1. IVPN
  • Jurisdiction: Gibraltar.
  • Clear ownership, no shady parent company.
  • Strong no logs policy. Independent audits.
  • Anti-tracking and ad blocking built-in.
  • Apps are clean, not bloated.
  • Streaming support weaker than “big commercial” VPNs.
  • My speeds on WireGuard: 300 to 420 Mbps.
    Best if you want privacy and a simple interface, and do not rely on unblocking every streaming site.
  1. Proton VPN
  • Based in Switzerland.
  • Good privacy policy. Open source apps. Regular audits.
  • Decent for streaming. US Netflix, some other regions work.
  • Free tier is slow and limited. Paid Plus plan is much better.
  • My speeds: 250 to 380 Mbps on Plus servers.
    Better balance between privacy and streaming, though not the fastest for me.
  1. AirVPN
  • Techy, not pretty.
  • Great for privacy and torrents.
  • Advanced config, port forwarding, etc.
  • Streaming is inconsistent.
  • Interface feels old.
    Use it if you like tweaking stuff and care about privacy more than streaming.
If streaming is your top focus and you accept weaker transparency:
  1. ExpressVPN
  • Works with Netflix, Disney+, Hulu, BBC iPlayer for me.
  • Speeds solid, around 350 to 450 Mbps on a gigabit line.
  • Audited no logs.
  • Owned by Kape, ex Crossrider, which had an adware history. I do not like this.
  • Apps are smooth though.
    Good if you want “plug and play” streaming, less ideal if you distrust Kape.
  1. NordVPN
  • Strong marketing. Lots of sponsored reviews, which is annoying.
  • Works with tons of streaming services.
  • Audited no logs policy.
  • Not as clean on privacy reputation as Mullvad or IVPN, but not awful either.
  • My speeds: 350 to 480 Mbps with NordLynx.
    I treat Nord as a streaming / casual use VPN, not my primary for privacy.
Stuff to check before you pay:
  1. Logging and audits
  • Look for independent audits of no logs policy.
  • Read the privacy policy. If they log IPs, timestamps, bandwidth, skip it.
    Good audited choices: Mullvad, IVPN, Proton, Express, Nord.
  1. Jurisdiction
  • Avoid VPNs based in countries with weak privacy laws and no transparency.
  • Sweden, Switzerland, Gibraltar, Panama, British Virgin Islands are common picks for privacy.
    Jurisdiction is not everything, but it matters.
  1. Ownership
  • Many random VPNs are owned by marketing or ad-tech groups.
  • Kape owns ExpressVPN, CyberGhost, Private Internet Access.
    If you want max trust, pick ones with clear, small teams and no adware history, like Mullvad or IVPN.
  1. Protocols
  • Prefer WireGuard or modern variants like NordLynx. Faster and simpler than OpenVPN.
  • If a VPN still focuses on PPTP or L2TP, skip it.
    For streaming, WireGuard gives better speeds and lower latency.
  1. Streaming tests
  • Use free trials or money-back windows.
    Checklist you can try during the trial:
    • US Netflix works on at least 2 servers.
    • Your favorite platform (Hulu, Disney+, BBC, whatever) loads.
    • Streams at 1080p or 4K without constant buffering.
    • No aggressive captcha on normal browsing.
  1. Kill switch and leaks
    Once you pick a VPN, run some quick tests:
  • Go to ipleak.net or similar with VPN on.
  • Check IP, DNS, and WebRTC.
  • Make sure your ISP DNS is not showing.
  • Enable kill switch so your traffic stops if the VPN drops.
My current setup:
  • Primary privacy VPN: Mullvad.
    I pay with cash code, no account info. Use it on desktop and for torrenting.
  • Secondary streaming VPN: NordVPN.
    I use it on TV and Fire Stick because it unblocks almost every streaming app I use.
So one for strict privacy, one for streaming. Splitting roles helps a lot.
What I would avoid:
  • Lifetime VPN deals. They often oversell, clog servers, then die.
  • Random VPNs from app stores with few reviews and no transparency.
  • “Free unlimited VPN” services. Data has to pay the bills, and if you are not paying, you are product, not customer.
Quick shortlist by use case:
Privacy first
  • Mullvad
  • IVPN
  • Proton VPN (Plus)
Streaming first
  • NordVPN
  • ExpressVPN
Balance of both
  • Proton VPN Plus
  • Mullvad if the streaming you want happens to work from your region
If you share your country, platforms you stream on, and your base internet speed, people here can narrow it down even more.
I’m mostly on the same page as @andarilhonoturno, but I’d tilt the recommendation slightly differently if streaming really matters to you.
Short version:
  • One VPN for privacy
  • One VPN for streaming
    Trying to get “perfect privacy + perfect streaming” from a single provider usually ends in frustration.
Stuff I personally use / tested:
  1. Privacy-focused picks
  • Mullvad: Agree with them, this is privacy gold. The account-number system and cash/crypto options are about as de-anonymous as consumer VPNs get. Where I slightly disagree: Sweden + 14 Eyes gets overhyped in discussions. If a VPN truly does not log, the jurisdiction becomes a second-order concern. For me their transparency, open source, and audits outweigh the 14 Eyes angle.
  • IVPN: Criminally underrated. Their whole threat-model documentation is one of the only ones that feels written by actual engineers rather than marketing. If you’re paranoid about data collection and want sane defaults, this one’s hard to beat. Streaming though is kinda meh, same as mentioned already.
  1. “Balance” pick that’s actually practical
  • Proton VPN Plus: If you want one service and do not want to juggle two: this is the only provider where I’ve had a decent combo of “works with Netflix and still takes privacy somewhat seriously.” I’d actually rank it higher for your use case than Mullvad, because Mullvad streaming is too flaky unless you get lucky with your region.
    Where I mildly disagree with @andarilhonoturno is speed: on my 600 Mbps line with WireGuard I regularly get around 450 Mbps on nearby Proton “Plus” servers, so results will vary a lot by location.
  1. Streaming-first
  • NordVPN: Their marketing is awful, but for sheer ‘turn on, Netflix works, done,’ they are still one of the easiest options. I treat them like a smart DNS service with encryption, not as a serious privacy shield. Log audits are nice, but they are too big and too commercial for me to trust like Mullvad/IVPN.
  • ExpressVPN: I personally dropped them after the Kape acquisition. Not saying they are bad, but with that adware lineage and so many solid alternatives, they fell out of my “recommended” column. If you value polished apps over ownership history, you might still like them, but I’m more picky here than @andarilhonoturno.
  1. Stuff that’s overrated or I’d be careful with
  • Any “top 10 VPN” list with the same 4 sponsors up front. If the first thing a provider pushes is an affiliate program instead of technical docs, that’s my red flag.
  • The whole “lifetime VPN” thing: agree completely, but I’d add that even some “lifetime” plans from semi-known brands slowed to a crawl after 1–2 years for me. They’re counting on breakage or overselling.
  1. Extra angles not really mentioned yet
  • App bloat & tracking: Some big VPNs pack telemetry and crash analytics into the client. Check their docs for what they send back. Mullvad and IVPN are very conservative here; others are less so.
  • Account reset / recovery: Mullvad’s account-number approach is great for privacy but terrible if you lose that number. If you’re forgetful, this can bite you. Proton / Nord with standard email login are more forgiving.
  • Device variety: If you use Fire TV, smart TVs, consoles, etc., Nord and Express simply support more “non-techy” platforms without weird manual config. Privacy-first VPNs are better on desktops/phones, less smooth on TVs.
How I’d pick in your situation:
  • If privacy is top priority and streaming is secondary:
    • Mullvad or IVPN as main
    • Accept that some streaming stuff just will not work every time
  • If you want one VPN and hate fiddling:
    • Proton VPN Plus
  • If streaming is critical and you’re ok with “good but not perfect” privacy:
    • NordVPN for everything
    • Use built‑in OS tools (encrypted DNS, per-app VPN, etc.) to tighten things a bit
And honestly, whatever you choose, use the trial / refund window like a benchmark test:
Netflix, Prime, Disney or whatever you actually watch, at your normal time of day, for 2–3 evenings. If you see constant captchas, weird logouts, or random buffering at 1080p, refund and try the next one. No review or forum post is as honest as your own connection.
