Need help understanding how Granola Ai actually works
I recently started using Granola Ai to help with my daily tasks and planning, but I’m confused about what it really does behind the scenes and how to get accurate, reliable results. Sometimes the suggestions feel off or inconsistent, and I’m not sure if I’m using the features correctly or missing key settings. Can someone walk me through how Granola Ai is supposed to be used, the best practices to get good outputs, and any common mistakes new users make so I can actually trust and benefit from it?
Granola AI is mostly a “wrapper” around large language models plus some logic for planning and memory. Think of it as an AI text model plus task glue, not a magic brain.
What it does behind the scenes, in simple terms:
  1. Input parsing
    • It reads your prompt and guesses your intent.
    • It labels it as “plan”, “summarize”, “schedule”, “write”, etc.
    • If your prompt is vague, the guess is worse, so results feel off.
  2. Planning step
    • For bigger tasks, it breaks the problem into smaller substeps.
    • Example: “Plan my week”
      Step 1: Extract your events.
      Step 2: Guess your priorities.
      Step 3: Build a schedule.
    • If your past data is thin or messy, the plan leans on guesses.
  3. Model call
    • It sends a structured prompt to an LLM like GPT or similar.
    • The prompt includes some of your history, like tasks, notes, or previous chats.
    • If there is not enough context, it fills the gaps with assumptions. That is where it feels “wrong”.
  4. Post processing
    • It tries to convert free text into structured stuff.
    • Example: turns “Workout 3x this week” into three calendar tasks.
    • Sometimes it misreads time, priority, or frequency.
  5. Memory and personalization
    • It stores some of your preferences, tasks, and previous outputs.
    • Over time it tries to reuse that, like “user wakes up at 7” or “user likes time blocking”.
    • If you do not correct it, it keeps a wrong mental model of you.
How to get more accurate and reliable results:
  1. Give hard facts, not vibes
    Bad: “Help me plan my day”
    Better: “I work 9 to 5, need 2 hours for deep work, 30 mins for lunch around 12, 1 hour for exercise after 6, and I have these fixed meetings: …”
    The more constraints, the less guessing.
  2. Use bullet lists for inputs
    • List your tasks with:
      • Deadline
      • Duration estimate
      • Priority
      Example:
    • Write report, due Wed, 2h, high
    • Email followups, due today, 30m, medium
  3. Tell it your constraints every time for important stuff
    • Time window you want to work.
    • Hard deadlines.
    • Energy patterns if relevant, like “mornings are best for focus”.
  4. Correct it in plain language
    When it gives a bad plan, reply with:
    • “This does not match my schedule. I work 10 to 6. Move all deep work to before 2 pm, keep meetings where they are.”
      These corrections help future outputs, as long as it stores enough context.
  5. Avoid huge, fuzzy requests
    • Split things:
      Step 1: “List and organize my tasks from this text dump.”
      Step 2: “Prioritize them with deadlines.”
      Step 3: “Build a schedule for today only from that list.”
      This step by step approach is more stable than one giant “fix my life” prompt.
  6. Spot when it is hallucinating
    • It sometimes invents routines or preferences you never said.
    • If it says “as you usually do yoga in the morning” and you do not, tell it so.
    • Treat it like an intern, not an expert.
  7. Use it for structure, not truth
    • Great for:
      • Breaking tasks into steps
      • Draft daily / weekly plans
      • Writing first drafts of emails or docs
    • Weak for:
      • Detailed factual stuff without verification
      • Perfect time estimates
      • Reading your mind
Example of a strong prompt for Granola:
“I work 9 to 5, Monday to Friday. I have these tasks today:
  • Finish Q1 report, 3h, due tomorrow, high
  • Respond to 15 emails, 45m, medium
  • 1:1 with manager at 2 pm, 30m, fixed
  • Team standup at 10 am, 15m, fixed
Plan my workday from 9 to 5 with 2 blocks of deep work in the morning for the report, keep meetings at fixed times, short break every 90 minutes, and leave 30 minutes at the end for email.”
You will get a tighter schedule and fewer weird suggestions.
If your results keep feeling off, try:
  • Shorter prompts, but with more specific details.
  • Asking it to “show the reasoning step by step” so you see where it went wrong.
  • Reusing the same phrasing when you find something that works.
It is a pattern matcher with some planning logic on top, not a planner that understands your life by default. The more precise data you feed it, the less it needs to guess.
Think of Granola as three things glued together:
  1. a note/task database
  2. a planner script
  3. a rented brain (LLM like GPT)
@shizuka already walked through the pipeline pretty well, so I’ll skip repeating that and poke at a few angles they didn’t dig into.
1. What it’s actually “thinking” with
Granola itself isn’t smart. The “intelligence” is almost entirely the LLM it’s calling. Granola’s own code mostly:
  • Decides what kind of prompt to send
  • Decides what context to include from your past stuff
  • Tries to turn the answer into tasks / events / notes
If the “router” or “context chooser” guesses wrong, your results feel off even if the base model is great.
Where this bites you:
  • It might pull old context instead of the thing you care about today
  • It might miss key details from your last message and default to generic advice
  • It might over-personalize from one comment you made once
So when it’s weird, it’s often a context selection failure, not “Granola is dumb.”
2. Why suggestions suddenly feel wrong
Some patterns I’ve seen:
a) State drift
It builds a fake picture of your life over time: your “usual” wake time, habits, energy etc.
If that model is wrong and never corrected, everything after will be slightly sideways.
Fix: Periodically reset its perspective:
“Ignore previous assumptions about my routine. Here’s my current situation: …”
You’d be surprised how much cleaner results get after explicitly telling it to wipe assumptions for this session.
b) Misunderstanding what’s fixed vs flexible
LLMs are terrible at knowing what’s negotiable unless you scream it.
It might move:
  • gym instead of meetings
  • family time instead of low priority work
  • or it schedules “deep work” around stuff that’s actually locked in
Be very explicit:
“Meetings and commute are hard constraints. Exercise and reading are flexible. Do not move X and Y under any circumstances.”
3. How to “train” it without a million corrections
I slightly disagree with @shizuka on having to correct every little thing. That works, but it’s exhausting.
What I’ve found more efficient:
a) Canonical preferences message
Once, write a long, boring “About how I work” paragraph and reuse it:
  • Work hours
  • Focus hours
  • Break style (Pomodoro, 90-minute blocks, etc.)
  • Stuff that is sacrosanct (sleep, family, meals)
  • How you like tasks grouped
Then paste it in or say:
“Use my standard work rules: [paste] when planning anything.”
You don’t need to trust that its long-term memory will always recall this correctly. You just re-attach the brain each time.
b) Force it to show structure
Instead of only:
“Plan my day”
Use:
“Plan my day and present the output as:
  1. Assumptions about my schedule
  2. List of tasks with times
  3. Conflicts or uncertainties”
The “assumptions” section is gold. You immediately see where it misunderstood you.
4. What Granola is good for vs what you probably expect from it
Where it shines:
  • Turning messy brain-dump into a task list
  • Creating first-pass schedules you can tweak in 2 minutes
  • Breaking down big vague tasks into concrete steps
Where it will consistently disappoint:
  • Perfectly optimized calendars
  • “Knowing you” without frequent re-statement of constraints
  • Being right about how long your work takes
Use it as:
“Give me something 70% decent I can quickly edit”
Not:
“Generate The One True Schedule for my life today”
Once I lowered my expectations to “assistant that drafts plans I override,” its value went way up.
5. Concrete way to work with it day to day
Here’s a flow that works really well for me:
  1. Morning:
    • I paste a list of tasks / meetings.
    • I include rough timeboxes, energy levels, and any hard “no work” windows.
  2. Prompt style:
    • “Create 2 alternate day plans:
      Version A: conservative, lots of buffer
      Version B: aggressive, minimal buffer
      Show both in a table.”
    Multiple versions expose its weird choices and let you cherry-pick.
  3. After seeing the output:
    • I don’t say “this is wrong.”
    • I say: “Keep Version A, but move all creative work to before lunch and push admin to after 3 pm. Don’t schedule anything later than 6 pm.”
  4. Final step:
    • I manually tweak in my calendar / task app.
    • I do not rely on it to be the single source of truth.
6. Red flags that mean “don’t trust this output”
When you see any of these, treat the plan as a draft only:
  • It references habits you never mentioned
  • It confidently assigns times to tasks you never time-estimated
  • It compresses 8 hours of work into 3 because “you can probably do it quickly”
  • It ignores stuff you said was non-negotiable
When that happens, literally tell it:
“You are overconfident here. Rebuild the plan and:
  • Use my own duration estimates only
  • Leave uncertain tasks as ‘floating blocks’
  • List what you’re not sure about explicitly”
LLMs actually behave a lot better when you call out their overconfidence.
TL;DR version:
Granola is a planner UI + memory + LLM. The LLM is guessing around missing constraints, and the planner logic sometimes picks the wrong context or misreads what is fixed vs flexible. Treat it like a slightly overeager junior assistant: give it strict rules, make it expose assumptions, and use its output as a draft, not gospel.
Think of Granola Ai as a “planner skin” on top of a generic LLM. It is useful, but only if you treat it like a tool that you actively drive, not an autopilot.
Instead of rehashing what @himmelsjager and @shizuka already broke down, I will focus on three things they mostly skimmed over:
1. What Granola Ai is not doing
Everyone talks about the pipeline, but the dangerous misconception is what it never actually learns:
  • It does not build a robust, structured model of your life like a real calendar system would.
  • Its “memory” is mostly text snippets and a few structured fields, not a stable database of rules.
  • It does not simulate tradeoffs like “if I accept this 2‑hour task, what breaks later in the week.”
So when you ask “Why are the suggestions off?” a lot of the time the answer is:
Because there is no real constraint solver or scheduling engine, just pattern matching with a bit of glue.
That is why Granola Ai will happily:
  • Ignore tomorrow’s crunch in favor of “self care” today
  • Schedule deep work in 30 minute shards
  • Overpack your day because it is not checking total load very rigorously
Use it as a suggestion generator, not as a system that understands overload.
2. Why “more detail” is not always the fix
Both earlier replies tell you to add more constraints and detail, which is often right but not always.
Situations where more detail backfires:
  • Very long prompts
    The routing and model sometimes focus on the wrong part of a giant prompt. You bury your real request under backstory.
  • Too many soft rules
    “I like deep work in the morning, but also exercise, but also calls, but also reading, but also quiet time” gives it no clear priority. It guesses.
  • Contradictory instructions
    “I do not want to work after 6” + “Schedule 7 hours of stuff after my 3 pm meeting” is common. It will pick one and not tell you clearly what it dropped.
What tends to work better than raw detail is priority:
“If you cannot satisfy everything, prioritize in this order:
  1. Deadlines
  2. Sleep
  3. Deep work
  4. Exercise
  5. Admin tasks”
This gives Granola Ai permission to throw things overboard instead of silently shoehorning them in.
3. Pros & cons of Granola Ai in practice
Pros
  • Fast from brain dump to structure
    Paste chaos, get a semi structured task list or rough plan. This is where it beats using a plain LLM chat, because the task glue saves you clicks.
  • Good at turning vague goals into step lists
    For “launch a side project” or “prepare for exam,” it is decent at turning fog into a checklist.
  • Lightweight habit for daily planning
    Asking “Plan my day from these 6 tasks” is low friction and feels nicer than rebuilding a calendar every morning.
  • Better than raw LLM for recurring flows
    Having a consistent “Plan today / summarize / next actions” workflow is more stable than improvising a new prompt to a generic model each time.
  • No real notion of capacity
    It does not say “This is impossible, you have too much work.” It just tries to be helpful and squeezes everything in.
  • Memory that ages badly
    Old assumptions stick around and slowly poison plans if you change jobs, schedule, or priorities.
  • Opaque decision making
    Even with “show your reasoning,” the internal routing and context selection are hidden, so weird outputs can be hard to debug.
  • Weak cross day reasoning
    Weekly plans often look like a nice wishlist instead of a realistic distribution of difficult work.
4. How to use Granola Ai differently so it stops feeling random
Here are some patterns that complement what was already suggested, not duplicates:
A. Force explicit tradeoffs
Instead of:
“Plan my afternoon with these tasks.”
Use:
“I have 4 hours available and 7 hours of work:
  • Task A: 3h, hard deadline tomorrow
  • Task B: 2h, deadline next week
  • Task C: 2h, optional
    Plan my afternoon and explicitly list which tasks you are not scheduling and why.”
The key is that last line. Granola Ai is bad at open admission of “this does not fit” unless you make it part of the job.
B. Separate “organize” from “schedule”
A mistake I see a lot: one huge prompt that asks Granola Ai to clean tasks, prioritize, estimate, and schedule in one shot.
Try this three stage pattern:
  1. “Here is a messy list.
    • Normalize each task into: title, deadline, duration, priority.
    • If missing, ask me for only what you really need.”
  2. “Given this normalized list, sort by: hard deadlines first, then importance, then effort.”
  3. “Now schedule only the top N tasks for today, given: [hours, breaks, fixed events].”
You get fewer “off” plans because the model makes fewer guesses per step.
C. Use it to interrogate your own plan
Another use that Granola Ai is quietly good at: critic, not planner.
You can draft your own schedule and then say:
“Here is my plan for today.
  1. Try to find conflicts, unrealistic duration assumptions, or back‑to‑back heavy tasks.
  2. Suggest only 3 concrete edits to make it more realistic.
  3. Do not rewrite the whole plan.”
This avoids the “wow, that came out of nowhere” feeling and uses the LLM’s strength as a pattern spotter rather than full planner.
5. Where Granola Ai sits vs “competitors”
Not talking about better/worse here, just different focuses of approaches that people often combine:
  • Granola Ai
    Tries to glue an LLM to daily planning workflows. Nice if you want AI integrated with tasks rather than opening a separate chat all the time.
  • What @himmelsjager pushes
    Strong on explaining what is going on under the hood and how to phrase prompts so the router + planner behave. Good if you like understanding systems.
  • What @shizuka emphasizes
    More focused on forming stable prompt patterns and using explicit assumptions. Helpful if you want repeatable recipes you can rely on.
People often mix: use something like Granola Ai for day plans, a plain LLM for deep reasoning, and manual tools for the actual calendar and deadlines.
6. Quick mental model so it stops feeling mysterious
When you type into Granola Ai, imagine this sequence in your head:
  1. A tiny script tags your message: “planning request.”
  2. Another script grabs some history and tasks, sometimes the wrong ones.
  3. It stuffs all that into a prompt and sends it to a rented brain.
  4. The brain replies in text, guessing about missing info.
  5. Granola Ai tries to turn that text into tasks and schedule blocks.
Where things feel off, it is almost always because of:
  • Wrong or missing context in step 2
  • Overconfident guessing in step 3
  • Aggressive interpretation into structure in step 5
If you shape your requests to explicitly control those three points, Granola Ai becomes predictable enough to be useful, even if it is not magic.
