Paying for FileZilla Pro but thinking about switching, worth it?
I upgraded to FileZilla Pro a few months ago mainly because I needed the S3 and Google Drive support for work, and didn’t want to keep juggling separate apps for regular FTP stuff and cloud storage. The problem is it’s been kind of a letdown honestly. It disconnects randomly when I’m pulling from S3, and a couple times it just froze mid transfer and I had to force quit and start over. For something I’m paying yearly for that’s annoying.
I’m on Windows at the office and Mac at home so whatever I switch to needs to work on both. Doesn’t have to be free, I don’t mind paying if it actually works well, I just want something that handles regular servers and cloud accounts without falling over. So can you suggest a good FileZilla Pro alternative?
I ended up canceling Pro after about six months for the same basic reason. The cloud features never felt fully integrated. It seemed more like an app originally built around FTP and SFTP, with cloud storage added later. That was hard to justify at the price.
I gave Cyberduck a shot first. It's free, works on both platforms, and supports S3, Google Drive, Dropbox, OneDrive, Backblaze, and the usual server protocols. It was more stable day to day than what you're dealing with, but the interface still feels like a file browser attached to a transfer client. So it didn't really solve the main problem for me.
What I kept using was CloudMounter. It mounts your FTP or SFTP server, S3 bucket, Google Drive account, and other storage as regular drives in Finder or File Explorer. You don't have to open a separate client whenever you want to move something. You can drag files around like they're in a normal folder.
It supports FTP, SFTP, FTPS, WebDAV, and the usual cloud storage services. It's been solid for me so far, including larger transfers, with no random disconnects. It isn't free, but the annual price is close to what you're already paying for Pro, so at least fixing the issue shouldn't cost much more.
Mounting remote storage as a normal drive has a hidden cost: Finder, Explorer, antivirus tools, and other apps may create metadata or temporary files without making it obvious. CloudMounter can be convenient, but I’d be cautious about using a mounted connection for production sites or permission-sensitive server work.
If your main need is SFTP rather than several cloud services, a regular transfer client is usually simpler. WinSCP is the obvious free choice on Windows. On macOS, Transmit and ForkLift are worth comparing if you want a cleaner dual-pane workflow. Cyberduck makes more sense when broad cloud support matters more than a traditional FTP interface.
Before canceling FileZilla Pro, test the replacement with a large folder, an interrupted upload, hidden files, timestamps, and file permissions. That tells you more than a feature list. For security, prefer SFTP, verify host keys, and avoid plain FTP unless you are stuck supporting an old server.
If you only use FileZilla Pro for FTP, FTPS, or SFTP, the simplest move is to downgrade to the regular free FileZilla Client. You keep the familiar queue, site manager, directory comparison, permission controls, and transfer behavior. Pro mainly earns its keep when you need its extra cloud connections.
That distinction matters because CloudMounter is not really a drop-in FTP client replacement. It makes remote storage available to other applications, which is convenient for opening or copying individual files. For a site deployment or a large batch transfer, though, I would rather have a visible queue, retry controls, logs, filters, and a clear view of which files failed. Mounted storage can make that information less obvious.
I would base the decision on the work you actually do:
  • Mostly manual SFTP transfers: free FileZilla may be enough.
  • Windows-heavy workflow: WinSCP is hard to beat, especially if scripting or synchronization matters.
  • Frequent cloud storage access from several applications: CloudMounter may be more convenient.
  • Repetitive or scheduled transfers: consider a tool built for automation rather than replacing one graphical client with another.
  • Mac workflow where interface quality matters: Transmit or ForkLift may justify paying, but that is more about usability than raw transfer speed.
I would not expect a dramatic performance increase merely from changing clients. The server, connection, encryption overhead, number of small files, and simultaneous transfer settings usually matter more. A different client can feel faster because it handles queues or reconnects better, but that is not the same as having a higher transfer ceiling.
Security is similar. Moving away from FileZilla Pro does not automatically make the setup safer. SFTP or properly configured FTPS, host-key verification, current software, and sensible credential storage matter more than the logo on the client. Check whether the replacement exports or encrypts saved passwords before moving your entire site list into it.
So I would downgrade before making a full switch. If free FileZilla handles the server connections and you only occasionally need cloud storage, use the cloud provider’s own app or a separate mounting tool for that part. That avoids paying for Pro without forcing every transfer into a completely different workflow.
Do not cancel or uninstall FileZilla Pro until you have confirmed that every saved connection can be rebuilt in the replacement. Site profiles are easy to overlook until you need an odd proxy setting, a custom port, a remote starting directory, or a server key you accepted months ago. Export what you can, but treat exported credentials carefully because they may not be protected the way you expect.
I slightly disagree with making the free FileZilla Client the automatic first stop. That makes sense if the subscription price is your only complaint. If you are leaving because of connection behavior, the interface, or how transfers recover after a failure, downgrading keeps most of the same underlying workflow. You save money, but you may still be annoyed by the exact thing that prompted the switch.
The real cost is the time spent checking that a new client behaves correctly with your servers. Run both clients for a week or two. Upload a directory containing hidden files, rename something remotely, interrupt a transfer, and see whether the replacement resumes cleanly or starts over. Check symbolic links and permissions if you manage Linux servers. For web work, pay attention to whether it preserves timestamps and whether its synchronization feature might delete remote files without a very obvious warning. That last one can turn a convenient sync button into a bad afternoon.
I would choose around the annoying task you repeat most often. If that is maintaining several Windows servers, WinSCP is probably the sensible switch because its synchronization and scripting features are more useful than a prettier file browser. If you mostly move files manually on a Mac, paying for Transmit or ForkLift can be reasonable because you are buying a less clumsy daily workflow. If cloud accounts are the main reason you bought Pro, Cyberduck is worth testing, but broad service support does not guarantee that every provider behaves equally well.
Don’t expect a new client to suddenly double transfer speed. The better reason to switch is fewer failed jobs, clearer logs, safer synchronization, or less time fighting the interface. If another client fixes a recurring annoyance, the switch is worth it. If FileZilla Pro is stable and you are only trying to trim the bill, cancel Pro and keep the free client around while testing alternatives. There is no prize for completing the migration in one afternoon.
The hidden trap is that a client that looks great during a bulk upload can be terrible when you edit remote files. Some handle external-editor saves, temporary files, and overwrite conflicts cleanly. Others turn a two-line CSS change into a guessing game about whether the server received the latest copy. Nothing says “premium workflow” like refreshing a page six times to find out.
Before switching, test your normal edit-save-upload cycle and two people modifying the same file. Check whether the client warns about newer remote versions, uploads temporary files safely, and reconnects without losing pending changes. Those details matter more than shaving a few seconds off a large transfer, especially if you touch production servers.
If FileZilla Pro is reliable and cloud access is only occasional, dropping to the free version still seems like the least painful answer. If the workflow itself annoys you, then test WinSCP on Windows or Transmit/ForkLift on Mac, but judge them by daily file editing and conflict handling rather than the feature checklist. Paying for another client only makes sense if it removes friction you actually encounter.
Switching clients rarely fixes anything if the actual pain is the server on the other end. @vibergirl nailed the real test, the edit-save-upload cycle, and that alone decides more than any feature list. If Pro is stable and cloud is occasional, keep the free client and mount cloud with CloudMounter only for the odd file grab, not for deployments.
Don’t replace one paid bundle with another by default. I agree with @novaloop1619 on splitting the jobs, but I’d skip mounting cloud storage if you mainly run planned transfers: use free FileZilla for FTP/SFTP and rclone for S3 and Google Drive. Rclone is less friendly at first because configuration and commands take some setup, but it gives you repeatable copy, sync, checksum, and retry behavior without another subscription. Just test sync commands carefully on disposable folders, since a reversed source and destination can delete the wrong files.
