Recover Deleted Photos From Canon Camera, Is It Still Possible?
I accidentally deleted important photos from my Canon camera before backing them up, and I’m trying to find out if recovery is still possible. The images are really important, and I need help with the best way to recover deleted Canon camera photos without making things worse.
I did this once on a Canon card after a bad button press, and the first move is simple. Stop using the camera now. Don’t shoot one more frame. Don’t record video. Pull the SD card out. If the card has a lock tab, slide it to read-only.
The reason is boring but important. On most Canon bodies, delete and quick format do not scrub the photo data right away. The camera marks the space as free. Your files often still sit on the card until new shots land on top of them. Canon does not give you a trash folder on the camera, so once new data overwrites the old blocks, you’re done. Keep the card out until recovery is finished.
Before you install anything, check the easy stuff.
If you used image.canon on your phone, look there first. I’ve seen people forget it held copies in the cloud for up to 30 days. If the files were removed on your computer after import, check Recycle Bin on Windows or Trash on macOS. Sounds dumb, saves time.
If no backup exists, use recovery software on a computer with an SD card reader. I would not connect the camera by USB for this. In a lot of cases, the camera exposes the card through a transfer mode that recovery apps don’t scan well. A direct card reader works better.
Out of the tools I’ve tried, Disk Drill gave me the least grief for camera cards. It reads Canon RAW formats like CR2 and CR3, plus JPEG and video, and the preview saved me from restoring junk files I didn’t need. On Windows, you also get a small free recovery allowance, which helps if you want proof before paying.
If your budget is zero, PhotoRec is the old forum answer for a reason. It’s free, open source, and good at pulling image data off damaged or formatted cards. The catch is the interface. It runs in a text window, and it spits recovered files into bulk folders with renamed files, so sorting afterward is a mess. Recuva is easier to look at on Windows, but when I tested it on RAW-heavy cards, it missed stuff I expected it to find.
The recovery steps are mostly the same no matter which app you pick.
  1. Install the recovery app on your computer, not on the SD card.
  2. Insert the SD card with a reader, pick the card in the app, then run a deep scan. Large cards take time.
  3. Save recovered files to your computer or another drive. Do not write them back to the same SD card.
If the scan shows previews of your photos, that’s a good sign. I’d recover the most important files first, then sort the rest later.
After you get your shots back, back them up somewhere else before touching the card again. For future shoots, I’d format the card in-camera after you’ve copied everything off, instead of deleting images one by one. My cards behaved better after I started doing that. Hope you get lucky, I did.
Yes, recovery is still possible if the card has not been overwritten. I agree with @mikeappsreviewer on the big rule, stop using the card. I disagree a bit on one point though. I would not spend much time checking cloud sync first if these photos are urgent. Every minute is better spent making a full image of the SD card on your computer so you work from a copy, not the original. That gives you one safer shot at recovery.
My order would be:
  1. Remove the SD card.
  2. Put it in a card reader.
  3. Create a byte-for-byte image of the card first.
  4. Scan the image, not the card, with recovery software.
Why image first? If the card is failing, repeated scans make things worse. A card image keeps the raw data frozen. On Linux or macOS, dd or ddrescue works. On Windows, USB Image Tool or similar works fine. It sounds nerdy, but it saves people from making a bad situtation worse.
For software, Disk Drill is a solid pick because it handles CR2, CR3, JPEG, and many Canon video formats well, and previews help you avoid restoring junk. If Disk Drill finds file names and folder structure, recover those first. If it only finds files by signature, your photos are still salvageable, but sorting will be annoyng after.
One more thing people miss. If the card was ‘formatted’ in camera, recovery odds are often still decent after a quick format. If you ran a low-level format, odds drop hard.
If you want a short walkthrough, this helps:
how to recover deleted photos from an SD card
If nothing shows up in software, a pro lab is the next step. Stop there and do not keep rescanning it 10 times.
Yep, still possible, but I’d add one thing to what @mikeappsreviewer and @himmelsjager said: check whether the photos were actually deleted from the card, or just hidden by a catalog/import app. I’ve seen Canon users think files were gone when Lightroom, EOS Utility, or even a flaky card reader was the real problem. Pop the card into a different reader and look at the DCIM folders before assuming total disaster.
Also, if these were RAW+JPEG, sometimes recovery apps only surface one set at first unless you filter by file type. People miss that and think half the shoot vanished.
I mostly agree with imaging the card first, but if someone isn’t comfortable doing that, fumbling with dd commands can be its own disaster lol. For most normal users, a solid app like Disk Drill on a computer is the practical route. It tends to find Canon CR2/CR3, JPEG, and video pretty well, and the preview helps a ton.
One more thing: if the card starts asking to be formatted, stop. Don’t click yes. That’s where people make a bad day worse.
Related example here if you want a real-world case: Canon photo recovery success story from a memory card mishap
If recovery software finds nothing, then I’d stop DIY attempts beacuse repeated messing around can lower your odds.
