I’m considering a Transmit replacement after uploading a revised stylesheet to the wrong remote folder while switching between client sites. My connection notes are in a text file, and the staging and live folders have nearly identical names.
Is replacing the client likely to help with this workflow, or should I first change how I organize connections in Transmit? If a replacement makes sense, what should I look for to make the destination clearer before uploading?
I’d pick CloudMounter if my main goal were working with remote files without babysitting a separate transfer window. I wouldn’t call it a better FTP client across the board, because that misses the actual distinction.
What matters to me is where the work happens. Uploading and downloading through a dedicated app is one approach. Having remote storage available alongside my normal Mac folders is another. I’m tired of those getting lumped together as though everyone wants the same thing with a different interface.
For opening, saving, and editing files, the Finder approach makes more sense to me. That’s a workflow preference, not a claim that ordinary transfer apps have suddenly become useless.
Spare me the “no software” pitch
The useful part is mounting FTP, SFTP, and cloud accounts in native macOS Finder so they appear like local drives. That lets you work with files through the folders you already use instead of opening a separate client for the transfer step.
But “no dedicated transfer window” isn’t the same as “no extra software.” You’re still using an app to make that arrangement possible. I’d keep that distinction intact rather than dress up a different way of accessing files as the disappearance of software altogether.
What interests me is how CloudMounter handles access, because the point is keeping file work inside Finder, not replacing one transfer screen with another.
My verdict: I’d choose CloudMounter for that Finder workflow, not because basic FTP apps need replacing.
A replacement won’t prevent much if staging and live still look interchangeable. I get @tom1994’s preference, but I’d prioritize separating access over changing where the files appear. Whether you use CloudMounter or stay with Transmit, make staging your everyday connection and keep live out of the routine upload path. If your hosting setup allows it, use a staging account that can’t write to production, with a separate login for publishing. Clear connection names help, but I’d rather have a mistaken upload blocked than depend on noticing the folder name every time.
Make the destination part of the project. For this particular mistake, I’d want a publish action tied to that client’s local folder, with the remote path saved in its configuration. Before sending anything, it should show the destination and the files about to change. That’s what I’d look for before replacing Transmit, rather than choosing by how comfortable the file browser feels.
@tom1994, I get the appeal of staying in Finder, but I’d rather keep publishing separate from ordinary file handling. My preference would be to edit locally, then deliberately publish a small batch. For a stylesheet correction, I’d want to see that stylesheet in the pending upload, not have to remember which client I was working on before lunch.
CloudMounter gets my recommendation for its macOS Keychain integration: connected-service credentials go into Keychain, which is a useful detail if your text notes contain passwords as well as paths. For the upload mix-up itself, though, my deciding question would be whether I can stop choosing the destination from memory every time.
Don’t test a replacement by simply uploading to the right place. Use disposable folders and overwrite the wrong file to see how much work it will take to put everything back. That’s my comparison of choice before moving all your client connections.
@isla’s access restrictions would be my first choice for prevention. My missing requirement is recovery: before publishing, I’d keep a known-good copy of the remote stylesheet, labeled with its client and destination. Your revised local copy isn’t the file you need when you’ve accidentally overwritten a different client’s CSS.
I would like to say that you have done a great job by including separate activity log window for the application. In my opinion, it is always helpful to have access to such information as it helps determine the progress of the upload process. Thus, if I had an issue with mistyping the file while uploading, for my next trial, I would make ‘restore the accidentally overwritten file’ my primary objective.
A replacement can give you a much nicer view of the wrong folder. Before moving all your connections, I’d check whether the destination stays obvious while you’re actually working, rather than only looking clear in the connection chooser. A beautifully labeled bookmark doesn’t help much if the upload window reduces everything to “css.” Very informative. Definitely no other client has that folder.
@thread759’s preview requirement gets at this, but I’d be picky about what the preview shows. “Upload stylesheet.css?” barely qualifies as a question. I’d want the client, environment, and remote path visible together, without hovering over a tab or opening another panel. That’s my main requirement for a replacement: can I tell where this file is going at a glance, in the window size I actually use?
For a trial, I’d recreate the interruption rather than concentrate on the transfer itself. Open a couple of disposable destinations with similar folder structures, navigate into both, then switch away to your editor and come back. Try it with the transfer window squeezed beside the editor, too. Check what remains visible and what gets shortened. If you have to click around to establish which destination is active, the new app hasn’t earned the migration effort. It has given you different buttons to remember.
I wouldn’t move from Transmit solely for this mistake unless another interface made that distinction noticeably harder to miss. And I’m less sold on the Finder approach here: I’d want remote publishing to look different from moving ordinary local files, not blend in more smoothly. Convenience is attractive right up until the wrong upload becomes convenient. Access restrictions would still matter, but for choosing the app itself, I’d judge the screen you return to after an interruption, not the tidy setup screen.
Check which local copy you’re uploading too. The discussion so far has focused on the remote folder, but a clear indication of the production connection won’t help you if you send it some other clients stylesheet. Same file name, different mistake.
@thread759’s project-based approach appeals to me for that reason. I’d keep each client’s working files in a separate local project folder and stop using any shared “ready to upload” folder. If your connection notes contain paths, pair the local project path with its remote destination rather than keeping a loose list of server folders. Downloads and emergency edits need a home in that structure as well. Otherwise you end up choosing between several copies by modification time. Newest does not mean correct.
For a replacement, my requirement would be that it is possible to see the source and destination together before you upload the file. Just the remote destination with a name next to it doesn’t cut it. I wouldn’t leave Transmit alone in regards to this issue, and I wouldn’t fix it by migrating all of your connections as a first step. Fix the working copies on the local side for the affected projects first. Switching transfer apps while keeping the same pile of ambiguous files sounds like paperwork and a purchase thrown in.
Realistically, no app saves you from a mistake you make while rushing between clients, so set your expectations lower than the feature list suggests. The quiet risk nobody flagged is muscle memory: when you’re hurrying, you confirm whatever dialog pops up without reading it, no matter how clear the destination looks. I’d run everything through staging in CloudMounter and treat the live push as a separate, deliberate step you can’t do on autopilot.
A mistaken drag-and-drop and an editor uploading on save need different fixes. Before replacing Transmit, check exactly what triggered the upload, including whether an open editor document was still associated with a remote file from the previous client. @techchizkid’s separate live-push step makes sense, but I’d check for any save-to-server behavior that could bypass it.
A saved starting folder isn’t a safeguard if the next session restores your last browsing location instead. Before replacing Transmit, I’d check a candidate’s reconnect behavior: leave a disposable connection in another directory, quit, then open it again through the saved connection. If you expect “open this project” and get “resume wherever I wandered,” that’s a caveat worth catching before migrating your client settings.
