I’m having issues with the serial port not functioning as expected within my virtual machine setup. The device shows up, but I’m unable to get data through. I’ve checked my VM settings, but nothing seems to fix it. Has anyone experienced this or know a solution? Any help would be appreciated as I need it for a project.
Man, the classic serial port headache in a VM—ain’t tech grand? The device “shows up” but won’t send a single byte? Been there, almost threw my laptop out the window (figuratively, mostly). So, lemme break it down step-by-step 'cause these things are finicky:
VM Platform: What are you running—VirtualBox, VMware, Hyper-V? Each one’s got its own flavor of “work with serial” pain. With VirtualBox, you gotta set the port mode (RAW, Host Device, etc.) and make sure you’re not fighting with Windows over who owns COM1.
Guest Additions/VM Tools: Did you install those? Sometimes the virtual hardware is only somewhat real until the right drivers/fakery is in place. No Guest Additions = you’ll get nowhere.
Permissions: Check that your user account has permission to access the host’s physical COM port. On Windows, often NO ONE gets permission by default unless you run as Admin. Linux? Gotta be in dialout or uucp group sometimes.
Physical Pass-through: If you’re trying to pass the actual host machine’s serial port into the VM, hilariously, some machines these days don’t even HAVE a real serial port—lots of USB-to-serial dongles floating around instead. Those are their own category of “nope.” If it’s USB-serial, try attaching the USB device directly to the guest, not as a host COM port.
Virtual Serial Port Redirection: Sometimes the VM will connect a virtual serial port to a file, or network, or pipe. Double-check you didn’t accidentally route everything into /dev/null or a file that doesn’t exist.
If you need to talk to real serial devices from a VM, consider something like Serial to Ethernet Connector—it lets you share your host’s real (or even remote network) serial port directly into your virtual machine. May sound like overkill but it’s saved my bacon more times than I’ll admit.
And if you want to really get into the weeds on getting COM ports working smoothly inside virtual machine environments, there’s a handy resource that’ll walk you through the steps.
Short version: VMs and serial ports hate each other, but with the right combo of settings, permissions, and maybe a tool or two, you can actually make ‘em play nice. Just don’t expect plug and play.
@viaggiatoresolare covered plenty, but just to throw a wrench (or maybe a screwdriver) into the works—have you seriously looked at how the IRQs and I/O addresses line up? Yeah, sounds old-school, but virtual machines sometimes map serial ports to awkward defaults, and if your guest OS is confused about where the line is, no dice.
Also, not gonna lie—I’ve seen USB-to-serial dongles work in one VM and be completely dead in another because the chipset isn’t supported in the guest, even if it’s “passed through.” Sometimes, the answer is to try a different dongle (yep, it sucks, but Prolific vs FTDI can make or break you).
Another thing: On Linux hosts, even if you’re in the right group (dialout, uucp), sometimes Modem Manager or brltty pounces on your device before your VM can. Try killing those services and retrying, especially if the port’s in some weird state.
And not to contradict the whole “external tools fix everything” angle, but sometimes the ports are just haunted—especially if you’re running nested VMs, or RDPing into the host. Don’t trust the UI; check your dmesg or Device Manager logs for any whining about devices.
If you get desperate, using a tool like Serial to Ethernet Connector (no, really, it makes a night-and-day difference for a lot of folks I know) can cut through these layers by faking the port over the network—major win if you need stability for a project crunch.
Quick aside—if you want a rock-solid connection tool, try the latest Serial to Ethernet Connector download. Helps sidestep a bunch of VM-specific quirks and actually makes Windows, Linux, and Mac guest serial communication predictable (well, as predictable as serial ports ever get).
Let’s cut through the noise on this: half the time, “shows up but dead silent” on a VM serial port means you’re facing, not some fancy virtualization glitch, but a flat-out signal mismatch or a false-positive device mapping. Sure, our peers suggested flipping your VM’s port modes, juggling permissions, and blaming Modem Manager (fair game), but here’s a wildcard to check: are you actually CONNECTING Rx/Tx correctly or looping back traffic the way you think?
A pile of running processes and perfect drivers won’t matter if, internally, the VM’s serial config is talking out the wrong pin or expecting a handshake that never comes. Old-school, right? But physical signal lines—even in a “virtual” port—sometimes need sanity checking, especially with oddball dongles.
Second, there’s this myth that Serial to Ethernet Connector solves every scenario. Not dissing the tool—it’s a lifesaver when nothing else works, especially if you want rock-bottom latency and stable virtual serial links over a flaky network. The pros: it bypasses messes with physical COM mappings, is OS-agnostic, and works in mixed Windows/Linux setups. Cons? You’re adding a layer of abstraction—one more thing to configure, maybe pay for, and possibly one more source of confusion if you’re troubleshooting at 2 a.m. Oh, and rarely, some custom protocols that rely on sub-millisecond timing still don’t love it.
Try checking your application’s serial settings before changing more VM options. Match the baud rate, data bits, parity, and stop bits to your device’s manual. For example, use 9600 baud, 8 data bits, no parity, and 1 stop bit only if your device specifies those values.
Write down your current settngs first, then apply the documented values and retry communication. Keep your wiring and VM configuration unchanged during this test so you isolate one variable. Double-check for typos befor saving.
Half these problems vanish the second you stop treating a USB-serial dongle like a real COM port. @viaggiatoresolare already flagged it, but it’s worth being blunt: if the chipset driver isn’t inside the guest, passthrough gives you a device that enumerates and does nothing, which is exactly the ‘shows up but silent’ symptom here.
On Serial to Ethernet Connector, I’d push back a little on the low-latency angle people keep selling it on, because over a shaky network that’s the first thing to go. Where it actually earns its spot is when the serial device lives on a different box than the VM, or when more than one machine needs the same port. For a dongle sitting right in the host though, fixing the driver and the pass-through is cheaper than adding a network layer you then have to babysit.
And before any of that, do what @anonymous said and confirm the line settings match the device. No tool fixes a parity mismatch.
